Backlight connectors incompatible
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    I found an IBM monitor with a faulty analog to digital board. The screen is compatible with that Nec LCD1703M that has broken LCD screen.
    I already connected the LCD signal connector to the Nec and it worked.
    The only problem is that the backlight connectors are different. The IBM screen uses 4x 2 pin connectors (see photo 1) while the Nec screen has 2x 4 pin connectors (see photo 2).
    I searched the web about conversion from one connector to another, but the most relevant info I found is this:
    http://www.ccflwarehouse.com/cclawiwi.html ("step #2")
    Has anyone done that before? Can you help me please?
  • Toasty
    • Jul 2007
    • 4171
    Re: Backlight connectors incompatible
    Let's see the backs of the boards.
    At first glance, I'd say the NEC uses a common return (small wire) and 2 "hots". The back should show if the IBM is common between the smaller wires. If so, I'd bet the IBM's could simply be tied together as common on the NEC, using the NEC connector.
    T
    veritas odium parit
    • goodpsusearch
      • Oct 2009
      • 2850
      • Greece
      T
      The 2 small wires are connected to a coil on the IBM board. There is space for that coil on the NEC board too (there is also space for the 2 pin connectors used by the IBM board) but instead of a coil there is jumper.
      Do you think I can still connect the small wires together?
      • Toasty
        • Jul 2007
        • 4171
        No need to quote on next post. Sorry, pet peeve.
        I would:
        1) Try what I suggested and see what happens. Are the IBM connector contact parts able to be swapped to the NEC?
        2) If it doesn't work or goes into shutdown, then try moving the 2 coils and 4 connectors over and rewire the NEC board to the IBM connector setup. The NEC is silk-screened for up to 6 tubes.
        T
        veritas odium parit
        • goodpsusearch
          • Oct 2009
          • 2850
          • Greece
          It worked!
          I soldered the connectors and the coils of the IBM psu on the NEC. I did that so I wouldn't have to change the connectors of the IBM panel. Thank you very much for your help!
          BTW the image is very good for a 2003 panel!
          • Toasty
            • Jul 2007
            • 4171
            Excellent!
            Now, please, stop serving alcohol to those caps. They appear to have had waaaay too much already... :P
            Cheers!
            T
            veritas odium parit
            • goodpsusearch
              • Oct 2009
              • 2850
              • Greece
              They try to escape from hot heatsink :P
              • HTR-Informatique
                by HTR-Informatique
                02-09-2025, 06:51 AM
              • turmix
                AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                by turmix
                Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                During another reassembly, I made a mistake, and...
                01-29-2024, 03:48 AM
              • FallenOne008
                Asus G712L No Screen Backlight
                by FallenOne008
                Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
                The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
                03-31-2025, 08:27 PM
              • trepachka
                HP Probook 450 G8 Boardview+Schematics - screen backlight issue
                by trepachka
                I am just wondering if anyone has boardview+schematics for HP Probook 450 G8.
                Computer is missing screen backlight. The backlight fuse must be kaput. I know the fuse is located on the motherboard because we tried a different working screen and it, too is missing backlight.
                Perhaps, if the boardview+schematics are not available, someone can point out where the screen backlight fuse is located. Thanks.
                03-16-2024, 12:32 AM
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
