LG 23" W2361V-PF White Screen
  • JoeyJoe
    • Sep 2012
    • 76
    I have just bought this monitor from Ebay. Snapped it up for £10 so not a big loss if it can't be fixed.
    The screen comes on, but the top quarter of the screen flickers with the LG logo, and the bottom stays black, some times the whole thing goes black then the whole thing turns white.
    I have tested with another screen (22") and the logic / power board works fine with that.
    I took the screen apart, but no amount of fiddling sorted it. What could the problem be to do with?
    Joe
  • Rtech
    • Jul 2010
    • 1095
    Re: LG 23" W2361V-PF White Screen
    There is normally no tech info on screens LVDS board,and I would suggest that a replacement screen is probably the only solution.
    • JoeyJoe
      • Sep 2012
      • 76
      Ok Thank you.
      I actually only ended up paying 99p for it! The seller didn't post any images but I took the chance, turned out to be less than a year old. I could have returned on warranty but already took the thing apart
      • sabre504
        • May 2010
        • 449
        Whats the screen number may have one
        • JoeyJoe
          • Sep 2012
          • 76
          I'd have to open it up again. Ill check. From what I can see though, all of my cold cathode back lit LG monitors that are 20" - 24" all seem to have the same connectors and work fine with each other.
          • JoeyJoe
            • Sep 2012
            • 76
            Sabre504, The screen model number is LM230WF1
            • harp
              White screen repairs
              by harp
              To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
              Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
              On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
              05-13-2024, 03:43 AM
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • EazyBone
              Sharp LC-65Q620U White Screen
              by EazyBone
              Another TV topic!!
              I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
              The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
              Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
              08-21-2024, 12:56 PM
            • Chrissygizmo
              Panasonic TX-48CX350B backlights but white screen , blank screen
              by Chrissygizmo
              Hi all, I’ve got a problem I hope someone can help me fixi.
              I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
              01-11-2025, 03:18 PM
            • odi
              Sharp E50E41NKFMBXNNX white screen
              by odi
              I'm trying to fix this TV that I got from a friend. It displays a white screen only. What is weird though is that when I first turned it on it appeared to work for a few minutes but then got the white screen and I haven't got the picture back even for a second after that initial time. If I plug in an HDMI device, the audio is played through the TV speakers, and the power button turns the TV on and off.
              I've tested the caps on the power supply with an ESR meter while in circuit they seemed within spec.
              Tried wiggling the LVDS while on and no change to the white screen. Have removed...
              01-31-2022, 03:29 PM
