LG L246WH No Backlight
  • canadaboy25
    What is normal?
    • May 2013
    • 509
    Hello everyone I have a LG monitor that I picked up for free because it had no power. Opened it up did some testing and found that it had a blown MOSFET, diode, and fuse. I replaced all and it worked great. I took it on an RV trip for use as a tv (since it was HD). On the ride it must have got bumped because when I plug it in I get no backlight. The screen image is ok but just no backlight. At first if i would bump the back of the monitor it would come on until bumped again. Now I can't get any backlight (I'm assuming it's still the same problem. I have tested the voltages on the connectors on the power supply board and the connector to the logic board is fine but there is no power going to the backlight inverter board. I would go along testing components but this is odd because it worked when it was bumped. It is obviously the power board cuz thee is no power coming out. Any help getting pointed in the right direction would be appreciated.
    canadaboy25
    canadaboy25
    -Sometimes the light at the end of a tunnel is an on-coming train
  • lexwalker
    • Feb 2011
    • 307
    • Malaysia
    Re: LG L246WH No Backlight
    Look for cold/dry solder joints. Also possibly loose connection at the backlight connectors on both sides. As for the power issue, check the fuse and the rectifier diodes for the inverter section.
    • spidey
      climbs
      • Dec 2012
      • 644
      • Cyprus
      check on/off, brightness and vin voltages of inverter circuit.
      • canadaboy25
        What is normal?
        • May 2013
        • 509
        The inverter is a separate board with a fuse but its still fine. There are no diodes on the board so what am I to be looking for?
        canadaboy25
        canadaboy25
        • gary19610
          • Dec 2012
          • 74
          • uk
          any body out their can help me with a ps 50c96hd samsung as their will not let me use threads for some reason
          • canadaboy25
            What is normal?
            • May 2013
            • 509
            I just reflow soldered all the joints on the power supply board and still no luck I think it is a component.
            canadaboy25
            canadaboy25
            • Rtech
              • Jul 2010
              • 1095
              Put it in the correct Forum and you may get some help !!
              • canadaboy25
                What is normal?
                • May 2013
                • 509
                After about 5 posts they will let you.
                canadaboy25
                canadaboy25
                • lexwalker
                  • Feb 2011
                  • 307
                  • Malaysia
                  The rectifiers/diodes located right at the SMPS transformer (at the power supply side), usually higher voltage for for inverter power supply. Check the rectifiers/diodes to see if they're faulty (either open or short).
                  • canadaboy25
                    What is normal?
                    • May 2013
                    • 509
                    Ok so I have 3 of these transformers onthe power supply board so i dont know what to test. So basically you are telling me to test the diodes. When i was working on myfirst problem (no power) i already tested all transistors, MOSFET's, zener diodes, rectifier diodes, and capacitors. Is it very likely that another diode would have blown in that short of time (a month)? I am sill not quite sure how a blown coponent like a diode would make it only work when bumped. As stated in my first post it used to work when bumped and there was no power to the inverter so I know it is a power supply problem but what would cause it to only work when bumped other than a connector or solder. Please correct me if I am wrong but do components work like that too, work when bumped sometimes? This bump thing has really got me stumped.
                    canadaboy25
                    canadaboy25
                    • lexwalker
                      • Feb 2011
                      • 307
                      • Malaysia
                      When you mentioned earlier that there was no power going to the backlight inverter board, the first suspicions would be the rectifiers/diodes at the SMPS transformer. You can connect the board to the mains to power it up, then check the voltages at the rectifiers/diodes on the secondary side. If your power supply board uses multiple SMPS transformers, its possible that the power to the inverter section is controlled by a transistor which is controlled by a standby circuit. This is similar to some of the LCD/LED TV boards I've repaired before (e.g. recently a Sony 42", one of the schottky diodes at the +3.3V standby side was found shorted thus the standby circuit could not operate normally). As for the bump problem, I've already mentioned earlier about looking out for dry/cold solder joints (ie. cracked solder joints also under that category).
                      • canadaboy25
                        What is normal?
                        • May 2013
                        • 509
                        Ok thanks for more info but how would i go along testing the voltages? Would I just put my multimeter on each side of the diode and how would I tell if it was bad on the multimeter screen?
                        canadaboy25
                        canadaboy25
                        • canadaboy25
                          What is normal?
                          • May 2013
                          • 509
                          Anyone?
                          canadaboy25
                          • canadaboy25
                            What is normal?
                            • May 2013
                            • 509
                            Nobody knows?
                            canadaboy25
                            • t.j.
                              • Apr 2010
                              • 383
                              • canada
                              on psu/main there will be pin outs printed in white where cables come an go on boards! test those points for what is listed! you will be looking for psu/on , 3,5,12 ect! you should download service manual, will have trouble shooting section.
                              • canadaboy25
                                What is normal?
                                • May 2013
                                • 509
                                I already tested and there is power going to the main board but no power going to the inverter board.
                                canadaboy25
                                canadaboy25
                                  Can I get to see good clear pictures of the board, both side as whole, and as in small sections?
                                  • triplefour
                                    by triplefour
                                    09-13-2023, 10:43 PM
                                  • DanPoka
                                    by DanPoka
                                    02-15-2025, 05:05 AM
                                  • Comp_Pro
                                    No Backlight Macbook A1990 820-01041
                                    by Comp_Pro
                                    Hello all,
                                    Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                    Tests performed:
                                    There is no backlight even with a good screen.
                                    Backlight IC is receiving the correct support voltages.
                                    Fuse F8400 ok
                                    Current sense resistor R8400 ok
                                    Backlight IC is receiving 3.3V on enable pin.
                                    Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                    Backlight IC receiving 5V from PP5V_G3S
                                    Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                    I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                    05-06-2024, 10:23 PM
                                  • cheebster
                                    iPad Pro 12.9 5th Gen Backlight Issue
                                    by cheebster
                                    Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                    Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                    Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                    The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                    Anyone...
                                    05-20-2025, 09:17 AM
                                  • canadaboy25
                                    LG Flatron 24EN33TA No Backlight When Cold
                                    by canadaboy25
                                    I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                                    I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                                    03-07-2023, 12:23 AM
