Fujitsu Siemens 23" LCD Scaleoview
    Re: Fujitsu Siemens 23" LCD Scaleoview
    Check and see if you do have dc Voltage (5V) on both ends of the fuse F1 with ref to the chassis/secondary side circuit ground. The connector is put back in correctly?
    • 0burn0
      • May 2014
      • 16
      • Serbia
      Ok I am having bigger problems than i thought
      two parts on panel PCB are missing on picture they are marked with red
      and theres 2 new parts installed marked with blue
      Now i dont know whats missing and i cant find pcb schematics
      • 0burn0
        • May 2014
        • 16
        • Serbia
        4,7V
        Yes connector is installed correctly
          OK, did this problem happen before or after the repair works? Or it was the original problem.
          • 0burn0
            • May 2014
            • 16
            • Serbia
            its my friends monitor and he used it
            when white screen started he told me that he only checked for bad capacitors
            and he give me monitor
            but i can see that soldering joints are bad
            i just hope he didnt destroy panel
              It can be that the main board is not sending the signals (All the signals, which is unlikely unless the chip on the main board is completely dead) so you may want to verify that you do have correct voltages on the main board by at least checking the voltages of the LDO first, if the problem is on the T-CON board, then you also need to check the LDOs and the switching power supplies on that T-CON, you can see some of the voltage test points on the T-CON board.
              • 0burn0
                • May 2014
                • 16
                • Serbia
                #27
                Ok i will
                I did a research and i found that i am missing one component TC74A5-3.3VCT
                its Temperature sensor
                Tomorrow i will replace all Capacitors and i will check everything
                If T-CON board is dead can i use another board to replace it i have two monitors with broken display but they are LG Flatron 19"
                  The T-CON is part of the LCD panel glass assembly, you will have to replace the panel with the same model.
                  • R_J
                    • 9591
                    Is that a CHI MEI panel? model A220Z5 ? On mine that cap. is also not installed and U2 is marked:
                    MT
                    8J
                    04
                    • 0burn0
                      • May 2014
                      • 16
                      • Serbia
                      #30
                      MT
                      8J
                      04
                      it's A220Z1-P01 model
                      i tested panel with LG LS20WS MB and PSU and same results White Screen
                      Panel died
                      • selldoor
                        Slow Learner
                        • 7870
                        #31
                        Are you testing it with a signal source - vga or dvi
                        • bammbammfran
                          • Apr 2014
                          • 476
                          I just checked two M220z-L01 that I have here and both have the 5 pin part at u5 which I think is part # BD5237G-TR
                          The part in your orange circle is also not installed on mine
                          and the 3 pin part that looks resoldered is a K1P and probabaly part number MMBT2222A
                          • R_J
                            • 9591
                            On my board the 5 pin device is labeled U2, on yours its labeled U5
                            • selldoor
                              Slow Learner
                              • 7870
                              #34
                              If you are getting a white screen did you check the fuse/s on the panel board.
                              What voltage do you get on each side of the fuse with respect to ground.
                              • 0burn0
                                • May 2014
                                • 16
                                • Serbia
                                #35
                                I did, on first fuse it's showing 4.7v before and after fuse
                                on second fuse 13.8v
                                but when display is disconnected and orange indicator light start on second fuse voltage bump up to 19.8V
                                • selldoor
                                  Slow Learner
                                  • 7870
                                  #36
                                  Sorry -I now see I duplicated Budms question fuse is ok - as regards the 14v, it is unregulated so it is normal for it to be higher when the heavy load of the panel light is removed.
                                  I did ask if you have a source connected when testing? some monitors revert to a white screen or a sequence of white blue green red or just sleep instead of displaying " No Signal
                                  • 0burn0
                                    • May 2014
                                    • 16
                                    • Serbia
                                    #37
                                    i didn't have panel connected when i was testing PSU voltage because when i connect panel there's no space to measure voltage and i cant see what i'm doing
                                    It was connected to my MacBook Pro when i was testing
                                    • Thermaltake
                                      Fujitsu Siemens Amilo Xa 3530
                                      by Thermaltake
                                      Hi, I got this Fujitsu Siemens Amilo Xa 3530 Model: MS2244. from a friend and it is powering On, but only functional keys lights up, fan spins and nothing else, screen is black no backlight, and it's staying like that forever. I tried other memory that I know is working, I tried to empty capacitors by holding power button without battery but still nothing. I didn't try new cmos battery, need to disassemble it first to try that. But I don't think even if cmos battery is dead it would give some backlight and picture...I kind of think it's chipset or gpu dead.
                                      I read something on google that...
                                      02-01-2024, 12:34 PM
                                      Fujitsu LIFEBOOK LIFEBOOK U7411 Notebook U Specification for Upgrade or Repair
                                      This specification for the Fujitsu LIFEBOOK LIFEBOOK U7411 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LIFEBOOK U7411 boardview and LIFEBOOK U7411 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-07-2024, 03:40 AM
                                      Fujitsu LIFEBOOK LIFEBOOK U7511 Notebook U Specification for Upgrade or Repair
                                      This specification for the Fujitsu LIFEBOOK LIFEBOOK U7511 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LIFEBOOK U7511 boardview and LIFEBOOK U7511 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      Fujitsu LIFEBOOK LIFEBOOK U9311 Notebook U Specification for Upgrade or Repair
                                      This specification for the Fujitsu LIFEBOOK LIFEBOOK U9311 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LIFEBOOK U9311 boardview and LIFEBOOK U9311 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
