T220HD flashes off after 2 seconds.
+ More Options
Posts
  • ashmath
    • Apr 2013
    • england
    Hi turned my T220HD on this morning only to find it comes on for like 2 or 3 seconds then screen gos black the front LED stays on constantly and makes a strange noise before screen go's off. Anyhelp would be greatly appreciated?
  • JonathanAnon
    • Jul 2012
    • 457
    • Ireland
    Re: T220HD flashes off after 2 seconds.
    I had one of these that the inverter transformer went on... But it could be the usual electrolytic capacitors causing your problem.. You'll need to take good quality pictures of the boards back and front, and post them here.. Then we can help you diagnose the fault..
    • Benjaba
      • May 2013
      • netherlands
      Hi
      I have the same problem, after 2 seconds the blackligt is gone.
      With a lamp over he screen and a dark room you can still see some picture.
      I checked the caps on the powerboard but they are seems to be good.
      Sorry for my bad english.
      Benjaba
      • mariushm
        • May 2011
        • 3799
        If the inverter section works fine then it could be that one of the CFL tubes is dead or going bad or one of the wires is no longer soldered properly to the cfl tube.
        Checking the ends of the cfl lamps is a bit hard, sometimes you have to remove the metal panel, and you have to gently remove the silicone jacket from the ends and sometimes just this step alone makes the wires break off from the lamp..
        Ideally you would find use a second set of tubes and replace existing connectors with your test tubes and if your test tubes light up and monitor works showing pictures then you know the lamps inside are bad (or the connection to them)
        another forum member has some nice pictures of how the lamps are inside
        http://s807.photobucket.com/user/bud...cklight%20lamp
        and here's a way to make your own test lamp from old cfl lamps:
        http://s807.photobucket.com/user/bud...ng%20old%20CFL
          Please upload the pictures of your boards.
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • smic717394
            by smic717394
            07-25-2024, 10:16 AM
          • odie34
            Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
            by odie34
            I am a hobbyist (not a professional) so please be gentle...
            I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
            I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
            02-18-2024, 09:11 AM
          • Chrissygizmo
            by Chrissygizmo
            02-10-2025, 12:33 AM
          • ipatch
            ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
            by ipatch
            i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
            08-24-2024, 02:36 PM
