SCEPTRE x22wg-Gamer - NO DVI (Factory Repaired Once)
  • RidleyRabbit
    • Mar 2013
    • 8
    I have read the previous threads and wanted to see get some feedback on my situation. I took my x22wg directly to Sceptre a couple years ago due to a power supply failure. No blue light at all. They repaired it free of charge after the warranty expired. I was pleased but a new problem has arisen. Now I have power but no DVI input. Strangely, it came back for a day but has since resumed with the "no signal" message.
    I opened my unit, removed the power board and examined the caps. Pictures are attached. It appears that the factory replaced 4-470uf capXons. When I flip the board over you can see evidence of previous soldering.
    To my eye, none of the capacitor look "puffy" or damaged. Am I advised to replace these 4 again, or replace all of them including the other 3 that weren't replaced originally?
    Also, is it worth my effort to remove the other board (the one where all the inputs go) and check it for bad capacitors?
    Forgive me if I've missed something from a previous thread.
    Thanks!
  • selldoor
    Slow Learner
    • 7870
    Re: SCEPTRE x22wg-Gamer - NO DVI (Factory Repaired Once)
    Are you able to try another monitor on the pc
    Are you able to try the monitor on another pc
    If neither remove the dvi cable and clean is as best you can and try again.
    Does the pc recognise the monitor.
    • RidleyRabbit
      • Mar 2013
      • 8
      I have two DVI monitors on the PC. What I did was I swapped the connections so the good monitor (Mac Studio Display) had the cable previously feeding the Sceptre. I got a picture on the Mac Studio Display ao I assume the cable is good.
      I also tried a different input on the Sceptre -- the HDMI -- and still got "no signal."
      I was not able to try the Sceptre on another computer.
      • selldoor
        Slow Learner
        • 7870
        Can you try the sceptre on the cable feedng the monitor that works
        Does the pc recognise it is connected.
        If windows - control panel - system- hardware- device manager-monitors
        EDIT
        I am off to bed now, these tests may seem a bit petty but No Signal quite often means
        a problem with the PC, Graphics card or cabling so its bets to try and eliminate those
        first - another test would be to make sure you have rebooted the PC preferable leaving it of for a few minutes.
        Anyway if all that is good then can you see if the on screen menu comes up.
        As you have a "No signal" message and I am assuming here that is stays on for more than 2-5 seconds then the back lights are working.
        If the back lights are working and the power light stays green then it look loke the power
        supply is ok. So the problem is most likely to be the main board so in answer to a previous
        comment you will need to take that off and post good clear pictures. There may be caps on there that have gone or voltage regulators to test.
        If it is currently all together you may want to wait to see if anyone suggests any other tests
        before you take it apart again
        • RidleyRabbit
          • Mar 2013
          • 8
          My video card has two DVI outputs. I swapped connections on the monitors so the Mac monitor received the video card output that resulted in "no signal" on the Sceptre and successfully got picture. So I believe that should rule out a bad output from the video card.
          Then I took the other cable and connected it to the DVI input on an Acer monitor and also got picture. Based on these tests it seems I have a good video card and good cables.
          To use a shotgun approach, I replaced all the capacitors on the power board. The Sceptre still says "no signal."
          Attached are photos of the other board. I don't see any puffy capacitors. Anybody have other ideas?
          • mockingbird
            • Dec 2008
            • 5484
            If it helps any, Sceptre added a small heatsink to the Pericom HDMI chip near the port in later revisions which may be telling.
            • selldoor
              Slow Learner
              • 7870
              Whilst this relates to viewsonic monitor it may apply to yours also - corrupt EDID
              http://blog.komeil.com/2008/06/fixin...no-signal.html
              • spleenharvester
                • Mar 2010
                • 901
                Is it just me or is one of those green caps looking bulged?
                Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
                • selldoor
                  Slow Learner
                  • 7870
                  SH - post 5 - "replaced all caps on power board"
                  RR You could try taking that brown chip out and starting the board
                  to see what happens. Then replace it and see what happens.
                  I think it is some sort of eeprom.
                  • jsog
                    • Feb 2011
                    • 220
                    Don't pull the brown chip, that's the processor.
                    With an ESR meter, you could check the capacitors on the digital board. They do fail sometimes, and can go bad without bulging.
                    • selldoor
                      Slow Learner
                      • 7870
                      Are you sure ? looks like a Bios chip to me which is programable which makes it nearer an eprom than a processor?
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        Usually tvs/monitors use an 8-pin eeprom chip. It is probably one or both of those chips between the socketed chip and the blue (vga?) connector.
                        I wonder though what the big chip in the middle does, or is this a combined mainboard/tcon unit?
                        Muh-soggy-knee
                        • RidleyRabbit
                          • Mar 2013
                          • 8
                          I don't see any green caps.
                          • RidleyRabbit
                            • Mar 2013
                            • 8
                            This monitor is going in the trash. I'm looking for a good deal on a 22 or 23
                            • selldoor
                              Slow Learner
                              • 7870
                              If you are going to trash it you could offer it on Freecycle - someone might be able to use it?
                              • RRice25541
                                Sharp Lc-50UB30U may be locked out of Service Mode and Factory Mode
                                by RRice25541
                                So i got this tv from my neighbor, when it wasn't working right for him,, he purchased another tv and gave his old to me.
                                the color is all outa wack, like the settings have been corupted,
                                I've already done a firmware search using the wifi connection update from the tv and it didn't find any new update so it's got the most recent version.
                                so
                                The issue is i can't get into service mode or factory mode, tried resetiing it from user mode and it didn't change anything.
                                when i bring up the menu and type the pass codes to access either mode the menu disappears...
                                05-13-2022, 10:44 PM
                              • masterm
                                JVC LT-43C888 (manufactured by Vestel) does not start after trying factory reset, details below
                                by masterm
                                TV: JVC LT-43C888 (purchased in 2018). This is a smart TV with Netflix, Youtube, Freeview and other applications via 'Viewd' app store
                                Problem with TV:
                                - Netflix stopped working so i tried to do factory reset from the TV menu.
                                - I confirmed on-screen but the factory reset did not happen even. It did not take me to 'first-time installation' screen as mentioned in the manual.
                                - After waiting for some time, the TV went into a boot loop.
                                - JVC logo comes on the screen and LED light flashes for some seconds, then it reboots again and the same thing happens
                                04-30-2024, 03:03 AM
                              • spirittoo
                                Sceptre 48" TV backlight LED`s
                                by spirittoo
                                Trying to fix a backlight problem with a Sceptre 48" TV.
                                I found replacement strips with the same part number as the strips in the Sceptre, but the new backlight strips have 5 leds per strip and the ones in the tv has 6.
                                So I decided to replace the leds instead. I found 3 bad ones. I had no problem removing the bad ones with a heat gun, they came right out. However the leds on the replacement strip would not come out with heat. I use my solder iron as well, they will not come off.
                                Anyone know how I can remove those leds without damaging them?
                                11-11-2023, 10:23 AM
                              • kchxaz
                                Sony XBR-55X930D - Stuck in svc/test mode? How to fix?
                                by kchxaz
                                Hi guys, this is my first post here so thanks for reading. Hopefully you all might have come across this issue before. first let me apologize for the length of the post but if you are to help me then it warrants giving you as much detail as possible, right?
                                So, I'm trying to bring back to life my Sony XBR-55X930D. Here is the situation: Removed and sent out power board for repair (due to no LED, red or otherwise, good power brick putting out the required 24V)). First time the board came back it did not work so I bitched at the place, mostly for not wanting to identify the parts...
                                05-16-2021, 05:24 PM
                              • tom_h
                                Sceptre X505BV, blue LED, no display
                                by tom_h
                                Hello all,
                                I have a Sceptre X505BV-FMDR8HJ1PE8 tv that had been gradually over time taking longer
                                and longer to come on, now it will no longer display any image. Original symptoms
                                are the red standby LED would turn to blue immediately when pressing the power on
                                button, but there would be a delay for the "SCEPTRE" image to appear on the screen
                                and backlight to come on. The delay kept getting longer, then it would go from blue
                                LED back to red. Then when I pressed the power on button again it would bring the
                                display up and work fine....
                                10-05-2023, 06:53 PM
