LG Flatron W2042TQ Searching a place to buy mosfets
    Hi all!
    I have LG Flatron W2042TQ and i'm searching a place to buy that mosfet APM4048D = Anpec
    I don't wanna buy it from alibaba because I only need 4 of them and I need to buy a lot of 5 or 10 pieces, the shipping is too high to ship to canada...
    it's like 30usd + 5 for paypal and the items that are like 2.9 each :S
    Maybe there is a equivalent but I don't know.
    The only pdf I can find for the Datasheet is APM4048DU4 I think U4 is for the Package Code but i'm not sure.
    On www.digikey.ca I found this FDD8424H but there is some little difference :S
    Sorry for my bad english, I'm speak french.
    Ty for you help all! have a nice day!
    I found this on your forum : https://www.badcaps.net/forum/showth...light=FDD8424H
    So AP4525GEH is maybe my solution... !???
    Re: LG Flatron W2042TQ Searching a place to buy mosfets
    Well, from the link to that post, the AP4525GEH (TO-252-4 case style) Dual MOSFETs work as the replacement.
    The Fairchild FDD8424H should work also, same case style TO-252-4 (4 PINS PLUS TAB for Common Drains).
      Ty alot
        You should not start another post for the wiring.
        You have 4 individual lamps, two for the top side of the screen, two for the Bottom side of the screen. Color does not matter if the pair for the top lamps go, Pink can go to into P403, Blue can go to P404, or reverse since the two lamps are not tied together inside the lamp assembly other wise I will not be able to test the inverter circuit.
        https://www.badcaps.net/forum/showthread.php?t=19987
        Spec for the FAIRCHILD FDD8424H and AP4525GEH.
          By a quick look Anpec APM4048D looks very similar to Nikos P2804ND5G, which is quite easy to buy from Internet (figure yourself where). Nikos part is used for instance in Samsung 245B inverter board.
          Using Google you can find also preliminary datasheet with much smaller amperage values. I suppose the above is more recent (correct), although physical size of the part is pretty small.
