LG Flatron
  • polo-mk3
    • Apr 2015
    • 5
    Re: LG Flatron
    Originally posted by selldoor
    All you can do is test the transformer as above. post11.
    It is unlikely the transformer would work(even if it physically fits) you would need to ask the vendor.
    Do the lamps flash at all - what does the power led do.
    Can you see an very dark image on screen.
    Did you own the monitor or buy in to fix if owned did it have any other symptoms
    fllickering/ pink tinge/ sometimes not come on etc.
    Hi Selldoor,
    I own the monitor, it started to look like the backlight was fluctuating (if thats the right word) like a random ripple effect but only in the backlight.
    But then today it started turning itself off and the power led would stay lit. If i just turned it on and off would put the screen back but now it lasts about 5 to 10 secs then off again.
    Yes i can still see the image in the background. Caps look good but not tested them but there is a squealing sound when the backlight comes on.
    Just uploaded this video to youtube if it helps : https://www.youtube.com/watch?v=xZfNvBGiYZg
    When its powered on you can see the LG logo for a few sec's
    • selldoor
      Slow Learner
      • 7870
      Re: LG Flatron
      Really need good clear pictures of your boards front and back
      • polo-mk3
        • Apr 2015
        • 5
        Re: LG Flatron
        Any good?
        http://www.cdgold.co.uk/polo-mk3/rep...420_165617.jpg
        https://www.cdgold.co.uk/polo-mk3/re...420_165552.jpg
          • 30932
          Re: LG Flatron
          resolder:
          D203
          T101
          U302
          they all have cracked soldering
          • selldoor
            Slow Learner
            • 7870
            Re: LG Flatron
            Yes pictures are very good only thing is we ask that they are posted on site
            ( maybe you struggled because of the original size)
            I have re loaded them so that others can see what the remarks refer to when
            /if they are removed from the offsite.
            As well as the above resoldering is looks like C205 C207 C209 C203 have been
            moved or replaced at some point anyway if it gets back to working, there are so few caps you should replace all except the BIG one with good make new ones. Panasonic FR FM or FC or similar
            • polo-mk3
              • Apr 2015
              • 5
              Re: LG Flatron
              Cheers guys,
              I will re-solder the above components give it a try and get back to you. then I will order the new caps and see what happens
              • polo-mk3
                • Apr 2015
                • 5
                Re: LG Flatron
                Originally posted by polo-mk3
                Cheers guys,
                Morning,
                I re-soldered the components from above and its still doing the same. So I have just ordered some Panasonic caps.
                • selldoor
                  Slow Learner
                  • 7870
                  #28
                  Re: LG Flatron
                  While you wait perhaps make up a couple of these unless you have any spare bulbs
                  another monitor dead laptop.
                  https://www.badcaps.net/forum/showth...er+testing+cfl
                  • rpj7
                    • May 2015
                    • United Kingdom
                    #29
                    Re: LG Flatron
                    I have been following this thread whilst trying to sort out a Flatron W2246S of my own, I keep an eye out for scrap monitors at work and got 2 with a similar 2 faults:
                    1.Turned on shows the LG badge, turn off, turns on again briefly then dies.
                    2.Turns on and squeals like very high frequency arcing and worked for a while, then it would turned on for 2 seconds and turn off.
                    So it seems like 1 was dead and the other dying.
                    Found they both had 1 bad CFL bulb each. changed a tube over and I now have a working 24 in monitor and a box of spare bits !
                    Once I got it working I did swap the PSU & video boards over to prove they were OK. So I have a spare board (Although I cracked a screen being clumsy after I had stripped it down for the bulb) anyone is welcome the boards for the cost of the postage - I will hang onto it for a while an no doubt get rid of it just before it would come in useful!
                    (spare board with the now working screen)
                    • Ancient1
                      LG Flatron L1953TR : CCFL connectors confusion ( forgot to take a photo before disassembling )
                      by Ancient1
                      I forgot to take a photo and now I am not sure how to reconnect
                      As you can see , I have 2 pairs , each pair has 2 colored wires : the black_ish connector and blue_ish connector
                      There must be a convention to help decide , I assume
                      How do I reassemble ?
                      03-07-2024, 04:35 PM
                    • ttmi100x
                      HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                      by ttmi100x
                      Greetings everyone,
                      I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                      The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                      Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                      Upon closer inspection...
                      07-31-2024, 06:36 PM
                    • mikey5791
                      Help on Samsung Syncmaster T220 dead ccfl lamp
                      by mikey5791
                      This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
                      Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
                      10-18-2020, 03:17 AM
                    • dcbw
                      PowerMac G5 ACBel 614-0303 buzzing
                      by dcbw
                      The PSU works, but shortly after powering on (either in the G5, or by shorting the power-on pin to ground) it begins buzzing loudly. It also makes the LED lights connected to the same circuit flicker. It's definitely a buzzing, not a high pitched whine.
                      The buzzing seems to come from the high voltage side of the board, perhaps from the white relay. Could the relay be bad, or could the 5V supply be bad enough that it's unable to keep the relay on? Any pointers to help isolate the issue? Thanks!
                      Other info: API2FS34, ID 291, Date B0404
                      05-31-2024, 07:13 AM
                    • reessi
                      Hanns-G HG281D - LCD Monitor - Low B/L voltage and loud buzzing...
                      by reessi
                      The pics are off the other really long thread as they are much clearer than my phone will do.
                      The fault:
                      In standby there is no buzzing.
                      After signal input and turn on, a loud buzzing is emitted from the main transformer, no backlight.
                      It is because the 24v line is at 21v irrespective of whether the inverter is plugged in. There is a picture on the screen.
                      If you wait long enough the buzzing stops and the 24v line changes to 24v and the inverter comes on.
                      I have checked every single cap on the psu and logic board by un-soldering...
                      07-05-2020, 05:23 AM
