Syncmaster SA350 is DOA even after attempting FW upgrade
  • axlmastr
    • Aug 2005
    • 158
    I received a Syncmaster SA350 (LED type) that is two months out of warranty for a symptom of no display, as in black screen with no signal icons dancing, and a blinking red power light. According to many posts over the last 18 months a common solution is to flash the display with new firmware. I connected this to a laptop and desktop and performed a dual display check to see if a known working display signal could be sent to this and "wake it up" as some web results claimed this monitor and it's siblings are known to go into sleep mode and not come out. This monitor was unresponsive to both output signal sources. I looked further and found that a common issue is with a 8-legged Winbond controller IC (25X40BVSIG located at about 2 o'clock of the Magic Color chip) on the logic board that needs to either be flashed with a firmware available on Samsung's site or replace the IC. Numerous posters claimed to reflash using the external VGA of a laptop and the monitor came to life again. I understand that if the firmware flash fails the monitor is locked up and the above mentioned IC has to be replaced. This reminds me of the old AMI BIOS, Phoenix BIOS, Award BIOS days when your BIOS crapped because of a failed update by way of poor flash installers and buggy code. I downloaded the firmware and it's installer and made the attempt to flash with a know working desktop that has dual display capability. While attempting the firmware update the software recognizes the SA350 and attempts to flash but the procedure never makes it beyond 10% as indicated by the progress meter. There are a few YouTube videos on this procedure and it seems straight forward though none of them ever showed an unsuccessful procedure. As with most firmware upgrades the warning of power loss or turning off the hardware during the procedure is eminent as it will leave the device dead. At that point the mentioned IC must be replaced. I really would like to know if any here have heard of this model's issue or similar. Also have any of you done the firmware update or know of the IC I mentioned? I have accounts at Digikey, Mouser, and Allied so I don't mind grabbing a replacement and flashing it if this is really plausible.
  • axlmastr
    • Aug 2005
    • 158
    <Solution> Syncmaster SA350 is DOA even after attempting FW upgrade
    Solution:
    I solved this myself by doing enough Googling and locating an obscure YouTube video about this common problem. The video led back to the supply source mentioned below.
    To "un-brick" a SA350 or one of it's sister models you can carefully separate the plastic clamshell housing/bezel that encases the LCD panel and circuit board inside taking great care to use a plastic tool to "pop" the interlocks. Once you are able to gain access to the circuit board the very small 8-legged SOIC flash chip (IC401 location on the PCB) must be replaced with another pre-programmed one from http://daitech.ca ---> Store ---> Samsung & look up based on model# with or without HDMI. You may not see your exact model# listed based on the size of your screen but the model series will be the same. I have successfully repaired my model using the MX chip from the website mentioned instead of the unavailable Winbond version in my original post. The chip arrives in 7 days from order and the repair takes about 15 minutes including dis-assembly/re-assembly. There are supposedly some programmed Winbond chips available from China through eBay but I prefer not to take the chance on that versus the above mentioned source.
    • AzianAssassin
      • Dec 2013
      • US
      Re: Syncmaster SA350 is DOA even after attempting FW upgrade
      Hey sir, thank you for posting this. I too have researched countless hours to no avail. I found maybe 80% of what you have found. I emailed daitech since they no longer sell that IC. It may be a lost cause since I'd also have to buy a hot air station and learn how to replace ICs.
      But anyways, thanks for the descriptive, helpful post.
      • moateez
        • Jun 2014
        • 119
        • algeria
        ihave aproblem with samsung syncmaster sa350
        • moateez
          • Jun 2014
          • 119
          • algeria
          [QUOTE=moateez;458027]
          this is a picteur for the mother board who show the problem
          https://www.sendspace.com/file/6o8wmx
          • selldoor
            Slow Learner
            • 7870
            Ok You need to post your pictures on this site using add attachments
            Ok Vous avez besoin de publier vos photos sur ce site en utilisant "add attachments"
            There are no good pictures of these boards to look at.
            Il n'y a pas de bonnes photos de ces cartes à regarder.
            Can you clean up the damage and take a close up picture.
            Pouvez-vous nettoyer les dégâts et prendre une photo en gros plan.
            Perhaps there is something we can discover
            Peut-être il ya quelque chose que nous pouvons découvrir
            • kpaxian
              • Jul 2014
              • poland
              I have the same problem exacly , upgrade stop on 10%
              s22a350h made :october 2011
              s/n : 0048H9MBA03910V
              When you replaced this IC normal re-upgrading is possible????????
              • Guti904
                • 71
                • Argentina
                Hi kpaxian... I have the same issue... 10% upgrading and stuck....now the monitor is dead, I've disoldered ic401 but i can't find this component here where i'am... so i'm still searching...
                • retiredcaps
                  • Apr 2010
                  • 9271
                  People need to work on their search skills.
                  http://www.ebay.com/itm/251607385770
                  --- begin sig file ---
                  --- end sig file ---
                  • selldoor
                    Slow Learner
                    • 7870
                    It would be useful if while your machines are in pieces you could post some really clear
                    pictures of the front and back of each board. Please use manage attachments jpgs less than 3mb upload well.
                    • kpaxian
                      • Jul 2014
                      • poland
                      Is it possible to use the same chip and re programm this chip??
                      • angel-boy
                        • 550
                        • Romania
                        hy , can some one give me the flash for samsung S23A350H
                        • rachidell
                          • Aug 2016
                          • 132
                          • algeria
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            maybe worth trying
                            http://www.ebay.co.uk/itm/Re-program...-/262319197672
                            • TheUser
                              Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                              by TheUser
                              Hello to everyone ,
                              This is my first post here, and i would like to share with you a small story in case you can help me.
                              Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                              All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                              I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                              02-10-2024, 02:07 PM
                            • gurj1979
                              Ubiquiti firmware help. US-8-150W POE
                              by gurj1979
                              Hi guys.
                              I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                              Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                              So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                              Got New chip and writes good.
                              THE PROBLEM...
                              It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                              Does anyone have a Good Firmware I can have?...
                              07-22-2024, 05:13 PM
                            • wattage
                              AOC AG493UCX 49-inch monitor - Firmware request
                              by wattage
                              Hello Badcaps Community,
                              The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                              07-13-2025, 04:41 PM
                            • sikocan
                              NP930XED Samsung Galaxy Book2 Pro Laptop PD Firmware Loop
                              by sikocan
                              I hope this message finds you well. I wanted to share a recent experience I had with a laptop that had a Type-C Port issue, specifically related to a PD (Power Delivery) controller problem. After replacing the damaged PD controller chip with a new one I purchased from AliExpress, the laptop now charges properly and negotiates power as expected, allowing the device to power up. I've replaced this chip twice just in case.
                              However, it seems that the laptop's BIOS is detecting an older version of the PD Firmware on the newly installed chip. As a result, it attempts...
                              01-11-2024, 01:47 AM
                            • skynetto
                              MSI Z590 MS-7D07 rev 2.1 EC Firmware
                              by skynetto
                              Hello there.
                              I have this mainboard (MSI Z590 Gaming edge - MS-7D07 rev 2.1) with these symptoms.
                              1. SIO_3VA ON
                              2. ATX_5VSB ON
                              3. 3VDSW ON
                              4. Mainboard stucked in Deep_S5 state
                              Problem:
                              RSMRST Incative. (Obviosly everything dead)
                              Tried just for fun to update the BIOS with its Bios flashback function (Push button and USB stick with bios in it).
                              Main Bios restored succesfully.
                              When updating Bios all the voltages comes on except PCH which is not needed.
                              EC Controller: NCT6687D-M
                              External SIO Firmware...
                              03-17-2023, 10:30 AM
