HP lp3065 repair How to disassemble
  • HPLP3065
    • Jan 2012
    Can somebody help on how to disassemble this unit, on the easy way.
    I'm having bad times with this case, How can i open ?
    Regards
  • HPLP3065
    • Jan 2012
    Re: HP lp3065 repair How to disassemble
    Found the answer myself , since nobody helps
    HP LO3065 can be dissambled on this way
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Well no you didnt actually, you found the instructions for this
      HP ZR2740w 27-inch LED Backlit IPS Monitor.
      I personally spent a lot of time looking for the instructions for your set as probably did other members. If we are unable to find something we cannot guess another instruction will do- only you can do that as you you can tell if your set is similar. It would only be if someone who had worked on one knew.
      There is one post on the forum that says be careful with the clips but noone
      has posted instructions. If the one you are using is not correct please say so.
      Please can you also update your profile with country and mains voltage.
      We can often help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
      Examples of what is needed
      https://www.badcaps.net/forum/attach...7&d=1280167246
      https://www.badcaps.net/forum/attach...6&d=1280167246
      https://www.badcaps.net/forum/attach...4&d=1280167246
      It will be useful if you can say what the supposed fault was and a bit about yourself - skills tools etc.
      • Sheppma
        • Oct 2013
        • 8
        After removing the 4 corner screws and the 4 large mounting screws in the middle you have to unclip the front of the bezzel from the main part of the case which is held with the type of plastic clips that you find on your TV remote etc. To do this start (on the bottom is best as it wont show any marks if you make any) with a small flat blade screw driver and push it in between the front bezzel and the back and once you have made gap use a larger tool to prise it open (I found a smooth table knife worked well). Continue to work your way around the edge popping the clips as you go.
