Ceramic capacitor question
  • m3at
    • Nov 2012
    • 7
    • usa
    Burnt ceramic capacitor on lcd display. Print on capacitor reads "ly sl6kv 5d "
    Any ideas on what this means for specifications?
  • jetadm123
    • 2169
    Re: Ceramic capacitor question
    5pf 6000V Tolerance=+/- 0.5pf
    • m3at
      • Nov 2012
      • 7
      • usa
      Any place to buy these things in small quantities.
        http://www.mouser.com/ProductDetail/...5EWWkSSTxTE%3d
        • retiredcaps
          • Apr 2010
          • 9271
          For the future ...
          Digikey.com.
          They are based out of the same state you live in.
          Digi-Key Corporation
          701 Brooks Avenue South Thief River Falls, MN 56701 USA
          Phone: 1-800-344-4539 or 218-681-6674 Fax: 218-681-3380
          --- begin sig file ---
          --- end sig file ---
          • chth96
            Is it possible to test small ceramic disc capacitor with analogue meter?
            by chth96
            I read EBOOK of Testing Electronic Component and found that
            "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
            Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
            It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
            Is it really possible to test small ceramic disc capacitor with analogue...
            03-09-2024, 10:03 PM
          • NuclearSpartan
            Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
            by NuclearSpartan
            I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
            The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
            I don't see any other visible damage anywhere else on the board....
            11-14-2024, 02:32 PM
          • rictechie
            smd ceramic capacitor use in iphones
            by rictechie
            is there a brand of smd ceramic capacitor use in iphones? or they are generics
            07-26-2024, 08:28 PM
          • Prolog
            RTX 3080 FE Identifying capacitor
            by Prolog
            Hi people, I hope this is the correct spot to post this, I'm new to the forum.
            I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
            I hope these photos make it clear which component I am referring to:
            (yes, the soldering is a bit botched from removing the blown one, I know)
            I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
            12-01-2024, 08:27 PM
          • Sparklingx
            SMD ceramic capacitor capacitance & voltage
            by Sparklingx
            what is the easiest way to measure the capacitance of SMD ceramic capacitors and its rated voltage?...
            09-12-2024, 01:04 AM
