Dell Monitor blinking LED
  • retiredcaps
    replied
    Re: Dell Monitor blinking LED
    See if picofuse PF751 (right above the big filter cap) is blown after you replaced the c5707s.
    See if Q743 and Q751 are shorted. These may the FU9024s I refered to as per post #18 and post #2 by UniT3d.
    If the above are all good, then you will have to check the main board and make sure that BL_ON is > 3.0V DC.
  • Pentium4
    replied
    I replaced those transistors, replaced all the caps, and re-soldered all the joints of the 4 inverter transformers. Now it will turn on but I have to use a flashlight to see a picture. Could one of the inverters be bad?
  • selldoor
    replied
    I have skimmed through and cant see it - you should also resolder the joints on the capacitors between the 5707s
  • retiredcaps
    replied
    Link to
    http://www.thecapking.com/irfu9024npbf.html
    if the FU9024 are shorted.
    Did you test these as well?
  • Pentium4
    replied
    Awesome! Thank you very much retiredcaps. I ordered 12 of them so I will report back when I get them and test it out! Yeah I always redo the joints myself. Plus it looks better
  • Lumberjack777
    replied
    Originally posted by retiredcaps
    Resolder all your inverter transformers regardless how they look.
    Thanks RC. That's vitally important for the repair to last. And I might add that it doesn't mean just touching the joints with a solder iron and remelting the solder. You want to get your wick up there and remove most of the solder a side at a time. And resolder using good quality leaded solder. Then it should last quite awhile.
  • retiredcaps
    replied
    I forgot to mention that thecapking.com also sells the c5707 and FU9024. He is based in USA.
    http://thecapking.com/sanyoc5707.html
    $2 First Class USPS Shipping on All Orders in the US!
  • retiredcaps
    replied
    Originally posted by Pentium4
    Does it not matter which ones I get on that search list?
    I just buy from sort by lowest price + shipping. A while back I order about 5 "kits" so I have enough to repair anymore Benqs. I picked up 2 Benq's a couple of weeks ago, but I have been busy with other things. I'm sure it will be the "usual" fix.
    For future reference is it the high resistance that indicated those transistors were shorted?
    From my 2 seconds guide (post #19)
    2) Shorted Transistors/MOSFETs
    On some LCD brands (example: Benq) the transistors (C5707) are sometimes shorted. Transistors are usually marked with a "Q" designation.
    If you have a manual range multimeter, set it to 200 ohms (two hundred). You can test for shorted transistors "in circuit" (with power off and unplugged)
    a) put black probe on pin 1 and red probe on pin 2 - read/record ohm
    b) put black probe on pin 1 and red probe on pin 3 - read/record ohm
    c) put black probe on pin 2 and red probe on pin 3 - read/record ohm
    If any reading is less than 30 ohms you might have shorted transistor. Remove the transistor and repeat the tests out of circuit to verify.
    Note: a shorted transistor would likely cause a very brief flash of the backlight or no backlight.
    Mosfets
    If you have a manual range multimeter, set it to 200 ohms (two hundred). This is for 3 pin ICs only. You can test a mosfet (Q, IC designation) "in circuit" by (power off and unplugged)
    a) black on pin 1- red on pin 2 - record ohms
    b) black on pin 1- red on pin 3 - record ohms
    c) black on pin 2- red on pin 3 - record ohms
    If any reading is less than 30 ohms you might have shorted mosfet. Remove from circuit and repeat the tests to verify.
    Some mosfets are more than 3 pins. To test those, identify the part number and search for its datasheet. Once you find the datasheet, the pins will be designated source (S), gate (G), and drain (D). It will probably be documented as S1, S2, G1, G2, D1, D2.
    Simply test
    a) black on pin S1- red on pin G1 - record ohms
    b) black on pin S1- red on pin D1 - record ohms
    c) black on pin G1- red on pin D1 - record ohms
    Repeat for the "2" pins. That is S2-G2, S2-D2, G2-D2.
  • Pentium4
    replied
    Desolder all of them and verify out of circuit. We generally recommend they be replaced in pairs.
    The c5707s are sold as "kits" on ebay because these Benq have known problems.
    http://www.ebay.com/sch/i.html?_trks...313&_nkw=c5707
    Thank you very much for the link! Does it not matter which ones I get on that search list? Okay I will resolder the inverter transformers and I will also replace all of the smaller caps on the primary. For future reference is it the high resistance that indicated those transistors were shorted?
  • retiredcaps
    replied
    All of them? Do I need exact replacements? Oh and by the way I tested them still soldered to the board. Did I need to desolder them before I tested them?
  • Pentium4
    replied
    Shorted. They are bad.
  • retiredcaps
    replied
    All of those between C and E (going both ways) either tested ~7.3Ω or ~287Ω.
  • Pentium4
    replied
    Thanks for the reply. I checked the picofuse and it's good. I gave the readings for the transistors on post #7, does that indicate if any are bad?
  • Lumberjack777
    replied
    Yeah. retiredcaps knows this board very well. It's the "BenQ board". It's almost always one of the inverter transistors circled in red. Or 1 of the 2 circled in blue. And also check the picofuse circled in red.
  • Pentium4
    replied
    All of those between C and E (going both ways) either tested ~7.3Ω or ~287Ω. So I replaced just the secondary caps and now the voltage regulator on the main board is still drastically fluctuating but now the voltages are lower (the low and high) Can that indicate anything?
    replied
    These are the transistors that usually shorted out.
  • Pentium4
    replied
    #1 it gets < 1 Ω, and #2 gets 7.7 Ω
  • Pentium4
    replied
    It's a Dell E172FPb. All the joints look good on both boards, could they still be bad? When checking the transistors which legs are E and C? Well some are labeled some aren't
    replied
    Check those 4 inveter tansistors 2SC 5706/5707 for low resistance reding between E and C, and yes, the solder joints
    Which Dell is this?
    http://s807.photobucket.com/albums/yy352/budm/DELL/
  • UniT3d
    replied
    Hmmm .....
    This has so many revisions and yet they have the same common issue.
    If my memory isn't that fuzzy :
    - Check/replace Q739, Q740, Q759, Q760, Q743, Q751
    - Resolder T751, T752, T753, T754
    - Replace all secondary caps
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • DanPoka
    Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
    by DanPoka
    I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
    Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
    This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
    02-15-2025, 05:05 AM
  • artvandalai
    Help identifying voltage regulator on this concept 2 pm5 monitor pcb board?
    by artvandalai
    This Concept 2 rower pm5 monitor doesn't shut down. It keeps turning on and stays on after being turned off. I read on another forum by another user that replaced the same component to check the voltage regulator.
    The monitor should pull around 35mA when turned on and in shutdown it should drops to around 0.060mA. Any advice on finding the voltage regulator on this board to check if it needs to be replaced?
    11-05-2024, 07:38 AM
  • Jesus Coder
    Issues Reviving Old Dell 2408WFPb Monitor
    by Jesus Coder
    I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
    06-25-2023, 02:33 PM
  • deep000
    Burned Voltage Regulator in Monitor – How to Identify and Repair?
    by deep000
    My computer monitor ASUS VP249H stopped working, and smoke came out of it.
    I opened it and found that a voltage regulator had burned out.
    The problem is that I can't identify its reference.
    I searched online for schematics or photos of similar boards that people are selling, but without success (no schematics, bad quality of the board or lack of the reference when it's a good quality 😅).
    How can I find its reference, and do you think it's repairable?
    Monitor: Asus VP249H
    Board reference: 0171 - 2271 - 6083
    09-08-2024, 01:13 PM
