Benq Q7T3 - No Power
  • matthmal
    • Nov 2012
    • 306
    • Malta
    I have this Benq Q7T3 monitor that has no power.
    What I have done:
    - I checked the fuse and it seems fine
    - I looked at the caps and their appearance is fine
    - I tested the C5707 transistors and their resistance is much more than 20 although at the back of the board they don't look good.
    - tested the big cap and the voltage is 320V
    Any help please?
    Thanks,
    Matthew
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Benq Q7T3 - No Power
    Check Q805 and Q812 for shorts. They are likely FU9024. See if PF801 fuse is open or not.
    PS. This board is widely documented with all the known problems.
    --- begin sig file ---
    --- end sig file ---
    • matthmal
      • Nov 2012
      • 306
      • Malta
      POWER OFF 2000ohms
      Q805
      Pin 1 to Pin 2 -> 687
      Pin 1 to Pin 3 -> 981
      Pin 2 to Pin 3 -> It will start to give a reading, until it goes up to 1998 but it will then end up with 1 (out of range)
      Q812
      Pin 1 to Pin 2 -> 684
      Pin 1 to Pin 3 -> 957
      PF801
      Result is 000
      The reading that there was on those transisters is:
      D1OPF
      06
      GKOLS508
      Note: I have just noted a little leak with one leg of the big cap. When i tested the big cap it read 320V but on the cap is supposed to be 450V 100uF
      • matthmal
        • Nov 2012
        • 306
        • Malta
        I have done the following four tests on the transformers, results are posted below:
        Tranformer 1 Test (T801):
        Pin 1 to Pin 2 -> 204
        Pin 1 to Pin 3 -> 1
        Pin 1 to Pin 4 -> 391
        Pin 1 to Pin 5 -> 391
        Pin 1 to Pin 6 -> 392
        Pin 1 to Pin 7 -> 391
        Pin 1 to Pin 8 -> 1
        Pin 2 to Pin 3 -> 1
        Pin 2 to Pin 4 -> 1
        Pin 2 to Pin 5 -> 1
        Pin 2 to Pin 6 -> 1
        Pin 2 to Pin 7 -> 1
        Pin 2 to Pin 8 -> 1
        Pin 3 to Pin 4 -> 745
        Pin 3 to Pin 5 -> 745
        Pin 3 to Pin 6 -> 745
        Pin 3 to Pin 7 -> 745
        Pin 3 to Pin 8 -> 000
        Pin 4 to Pin 5 -> 000
        Pin 4 to Pin 6 -> 000
        Pin 4 to Pin 7 -> 000
        Pin 4 to Pin 8 -> 1653
        Pin 5 to Pin 6 -> 000
        Pin 5 to Pin 7 -> 000
        Pin 5 to Pin 8 -> 1651
        Pin 6 to Pin 7 -> 000
        Pin 6 to Pin 8 -> 1651
        Pin 7 to Pin 8 -> 1653
        • matthmal
          • Nov 2012
          • 306
          • Malta
          Tranformer 2 Test (T802):
          Pin 1 to Pin 2 -> 203
          Pin 1 to Pin 3 -> 1
          Pin 1 to Pin 4 -> 1371
          Pin 1 to Pin 5 -> 1371
          Pin 1 to Pin 6 -> 1371
          Pin 1 to Pin 7 -> 1371
          Pin 1 to Pin 8 -> 1
          Pin 2 to Pin 3 -> 1
          Pin 2 to Pin 4 -> 1
          Pin 2 to Pin 5 -> 1
          Pin 2 to Pin 6 -> 1
          Pin 2 to Pin 7 -> 1
          Pin 2 to Pin 8 -> 1
          Pin 3 to Pin 4 -> 1
          Pin 3 to Pin 5 -> 1
          Pin 3 to Pin 6 -> 1
          Pin 3 to Pin 7 -> 1
          Pin 4 to Pin 8 -> 1
          Pin 5 to Pin 8 -> 1
          Pin 6 to Pin 8 -> 1
          Pin 7 to Pin 8 -> 1
          • matthmal
            • Nov 2012
            • 306
            • Malta
            Tranformer 3 Test (T803):
            Pin 1 to Pin 2 -> 205
            Pin 1 to Pin 3 -> 1
            Pin 1 to Pin 4 -> 1
            Pin 1 to Pin 5 -> 1
            Pin 1 to Pin 6 -> 1
            Pin 1 to Pin 7 -> 1
            Pin 1 to Pin 8 -> 1
            Pin 2 to Pin 3 -> 1
            Pin 2 to Pin 4 -> 1
            Pin 2 to Pin 5 -> 1
            Pin 2 to Pin 6 -> 1
            Pin 2 to Pin 7 -> 1
            Pin 2 to Pin 8 -> 1
            Pin 3 to Pin 4 -> 739
            Pin 3 to Pin 5 -> 739
            Pin 3 to Pin 6 -> 740
            Pin 3 to Pin 7 -> 739
            Pin 4 to Pin 8 -> 1651
            Pin 7 to Pin 8 -> 1650
            • matthmal
              • Nov 2012
              • 306
              • Malta
              Tranformer 4 Test (T804):
              Pin 1 to Pin 2 -> 199
              Pin 1 to Pin 3 -> 1
              Pin 1 to Pin 4 -> 1
              Pin 1 to Pin 5 -> 1
              Pin 1 to Pin 6 -> 1
              Pin 1 to Pin 7 -> 1
              Pin 1 to Pin 8 -> 1
              Pin 2 to Pin 3 -> 1
              Pin 2 to Pin 4 -> 1
              Pin 2 to Pin 5 -> 1
              Pin 2 to Pin 6 -> 1
              Pin 2 to Pin 7 -> 1
              Pin 2 to Pin 8 -> 1
              Pin 3 to Pin 4 -> 1
              Pin 3 to Pin 5 -> 1
              Pin 3 to Pin 6 -> 1
              Pin 3 to Pin 7 -> 1
              Pin 4 to Pin 8 -> 1
              Pin 5 to Pin 8 -> 1
              Pin 6 to Pin 8 -> 1
              Pin 7 to Pin 8 -> 1
              • matthmal
                • Nov 2012
                • 306
                • Malta
                can someone please help?
                • selldoor
                  Slow Learner
                  • 7870
                  Too many numbers - Transformer 4 looks definitely off ( your not having much luck)
                  I attach a pic which I think shows the joints for the secondary windings
                  Power off meter on 2000 ohms test s1>s2 s3>s4 s5>s6 s7>s8
                  looks like there maybe 2 pins for each S number - just check that that are
                  connected together. If it is one of these:
                  http://www.ipertronica.it/catalogo/R...26038001-35586
                  ti parlano italiano?
                  • matthmal
                    • Nov 2012
                    • 306
                    • Malta
                    we for every s number there is only one leg, the other is only solder.
                    Here are the readings
                    S1 to S2 -> 203
                    S3 to S4 -> 202
                    S5 to S6 -> 203
                    S7 to S8 -> 198
                    Io non parlo molto italiano
                    • selldoor
                      Slow Learner
                      • 7870
                      Well they look a lot better - I dont think they often fail
                      on this board ( famous last words)
                      You did check all 4 5707s?
                      I cant see that you have listed any voltages out on CN 702
                      However I cant really advise you to carry on with any POWER ON Tests as you have said the Big Cap is Leaking. The voltage is actually ok but once air replaces the escaping electrolyte and it gets hot it could explode!!!
                      When you have got it replaced it would be useful if you can say what happens from switch on to stable fault stage.
                      What does the screen do what does the power light do any sounds clicks hisses and so on.
                      You could also do some none powered tests on the components
                      on the heatsinks and on the black barrel diodes D601 and one just behind the heatsink near the "15"
                      If you have not yet done so you need to resolder ALL the
                      joints on the inverter transformers the 5707s and the black box caps between the 5707s.It cannot be emphasised enough how important this is
                      • matthmal
                        • Nov 2012
                        • 306
                        • Malta
                        5707 Transister Test 1:
                        Pin 1 to Pin 2 -> 1641
                        Pin 1 to Pin 3 ->1966
                        Pin 2 to Pin 3 > 170
                        5707 Transister Test 2:
                        Pin 1 to Pin 2 -> 176
                        Pin 1 to Pin 3 -> 177
                        Pin 2 to Pin 3 > 1458
                        5707 Transister Test 3:
                        Pin 1 to Pin 2 -> 725
                        Pin 1 to Pin 3 ->725
                        Pin 2 to Pin 3 > 1403
                        5707 Transister Test 4:
                        Pin 1 to Pin 2 -> 726
                        Pin 1 to Pin 3 -> 726
                        Pin 2 to Pin 3 > 1408
                        D601 Test :
                        518
                        D602 Test :
                        580
                        Please note that all tests were carried out with POWER OFF and 2000ohms.
                        I will carry out more tests tomorrow and try to re-solder the C5707s
                          You should test these transistors out off the board, and try using ECB instead as shown here:
                          http://s807.photobucket.com/albums/y...t=DSCF0766.jpg
                          • matthmal
                            • Nov 2012
                            • 306
                            • Malta
                            will do and will let you know
                            • matthmal
                              • Nov 2012
                              • 306
                              • Malta
                              So i have removed the following transistors from the board:
                              - Q805 -> DLOPF
                              - Q812 -> DLOPF
                              - Q815 -> C5707
                              - Q816 -> C5707
                              - Q809 -> C5707
                              - Q808 -> C5707
                              they are all blown as when testing them the results where all 1 (meaning out of range)
                              I also tested the following diodes off the board, POWER OFF 2000ohms:
                              - D601 -> 530 on one side and 1 (meaning out of range) on the other side
                              - D602 -> 588 on one side and 1 (meaning out of range) on the other side
                              • matthmal
                                • Nov 2012
                                • 306
                                • Malta
                                i tested the transistors as you told me... the ECB mode all results returned the same -> 1 (out of range)
                                • matthmal
                                  • Nov 2012
                                  • 306
                                  • Malta
                                  any sort of feedback please?
                                    "all results returned the same -> 1 (out of range)" That means the resistance is too high for the meter to display, I expect to see 200 Ohms or less for the bad transistors. So your C5707 are OK.
                                    "- Q805 -> DLOPF
                                    - Q812 -> DLOPF"
                                    Not sure what the 'DLOPF' is.
                                    • Rtech
                                      • Jul 2010
                                      • 1095
                                      "- Q805 -> DLOPF
                                      - Q812 -> DLOPF"
                                      Presume he means STD10PF06...'P' Channel ,used instead of the FU9024N.
                                      • matthmal
                                        • Nov 2012
                                        • 306
                                        • Malta
                                        mmmm ok.... then what else could have gone wrong?
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • Noodneek
                                          Replacing all the caps on the BenQ SW2700pt's power board didn't help...
                                          by Noodneek
                                          My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
                                          I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
                                          08-30-2024, 12:52 PM
                                          09-06-2024, 05:59 AM
                                          HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 02:15 PM
                                        • meraklinetx
                                          Asus Z97-a power cycle, no boot no cpu voltage
                                          by meraklinetx
                                          Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                          05-10-2023, 06:08 AM
