Re: DCLLCD DCL7A - quick flash of the back lights only
I replaced Q11 & Q12 and was able to get from just a flash of light to basically 2 seconds to black. The lights would stay on for varying lengths of time and there was a distinct arcing sound with the original ccfls and known good ccfls.
I removed both transformers and found the secondary winding of transformer 1 to be non conductive. I'm not sure if this occurred during the removal process or not since all 4 ccfls were working when the monitor was exhibiting the 2 seconds to black. It's probably not worth the cost of a replacement transformer for a 17" monitor.
Hmmm .....
Pardon me for butting in ...
Rtech is spot on for noting the differences in readings between Q6/Q7 with Q11/Q12.
This is a royer circuit. Those Q6+Q7 or Q11+Q12 is a Rohm part 2sc4672 (available from Digikey). The way the circuit is interlinked, if Q11 is shorted, Q12 readings will also be affected (and vice-versa). The only way to confirm is to test off-circuit.
Also while you're at it, check the tuning polycap tolerance. If its out-of-specs, that new transistor replacement will bork again.Leave a comment:
Yes, obviously remove the transformer and retest everything, but I was just suggesting that he ask the ebay seller for two reasons:
1) if epc-19 is bad, then he can compare that the replacement is indeed the correct part. Sometimes the part number, even though they are identical, is no guarantee they are the same.
2) we have a reference, however unlikely, in case both transformers are bad
I think we are both saying the same thing, but just from 2 different points of view.Leave a comment:
I think we are both saying the same thing, but just from 2 different points of view.Last edited by retiredcaps; 12-10-2012, 02:15 AM.Leave a comment:
I would suggest you have a look at Post 14.Leave a comment:
If you asking nicely, you might get this ebay seller to measure the resistance of epc-19.
http://www.ebay.com/itm/160917988500
I'm think I bought something from that seller before.Last edited by retiredcaps; 12-10-2012, 02:13 AM.Leave a comment:
Q9:
1 -4: 9.88 kohms
4-5: 14.55 kohms
1-5: 1.91 kohms
Q10:
1 -4: 9.99 kohms
4-5: 10.56 kohms
1-5: 0.60 kohms
The part number on the transformer is EPC-19
I have a couple of other monitors to work on and I'm sure I will be ordering capacitors for those. Since the transistors are fairly inexpensive parts, I will probably add them to my order and replace them. Hopefully that will help in determining if the problem is with the transistors or the transformers.Leave a comment:
Because the resistances of Q6 &Q7 are very different to Q11 & Q12,AND there is a significant difference in the transformer readings,as they are interlinked with the Q mosfets,then you really need to take the transformers out and measure them, and then decide if it is one of them or the pair of mosfets that are faulty.Leave a comment:
Your readings for the 2 transformers are radically different. Can you doublecheck your measurements and posting?
Also, what is the part number of the transformer?Leave a comment:
and I thank you for your work on that.
The datasheet can be seen here:
pins 1, 2, 3 are designated as S
pin 4 is designated as G
pins 5, 6, 7, 8 are designated as D
I've never checked one with more than 3 pins and this one is not designated with S1, G1, D1, S2, G2, D2, etc.Leave a comment:
Maybe it's too late or my eyes aren't working, but I can't find F1...
I don't see a label for Q9 or Q10, but if they are the ones below Q8, they don't appear to be shorted.
Q9:
2.733 kohms, 10.39 kohms, 12.11 kohms
Q10:
2.592 kohms, 10.46 kohms, 12.20 kohmsLeave a comment:
See if Q9 and Q10 are shorted.Leave a comment:
Did you check fuse F1 to see if it is open?Leave a comment:
Try disconnecting the cable from the main board to the panel. Do the backlights then stay on?
Have you check the secondary windings on the inverter transformersLeave a comment:
Forgot to mention, I have also tried 4 known good ccfl's with the same result.Leave a comment:
by corrizeHello, I'm stuck in troubleshooting…
The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
When I press the flash button, it's detected by the system, flash icon appear on LDC display.... -
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by tennno`Sound no picture RCA LED46C45RQ,Power Supply Board RE46HQ1301.
Has All voltages coming from main board.No voltage going to
Back lights from power board.Have no Schematic.Back lights work when
Led Back light Strip tester is used.Tester shows 110 volts from each
side.Also if you use the side controls and use the vol +or- tv shuts
down.
Thanks for any help -
by sam_sam_samThis happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
I am comparing them to a brand new one that I installed
The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
I going to let it run for several days before I remount back on the wall next to the... -
by JohnML1975Hello All
have seen posts on this model in here but my problem sounded different so thought i would create a thread
TV will not turn on
There is no standby light
When I press ON button for remote the red standby light does flash but no picture and no sound
From the back of the TV I can see the red light on the back of the mother board
Holding torch to the screen I cannot see a picture
I removed the back cover
Observing the boards I cannot see any damage
I disconnected the main board from the power supply
the back... - Loading...
