When replacing fuses in monitor power supplies, should you use the slow-blow kind or the normal kind?
fuse question
Re: fuse question
If its SMD then most of the time i see them as fast blow. If its the main fuse right after the power input then most of those are slow-blow. It just depends on the application. -
Re: fuse question
It often tells you on the board - there is a message saying use ONLY the same type of fuse?Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
Re: fuse question
If you look on the metal shoulders on the fuse it might say more.
What I am thinking is that if it is a slow blow it is usually described as a T4A 250v T= Time delay. Otherwise its a normal fuse - you should replace glass with glass ceramic with ceramic. (Not that I always do)Please upload pictures using attachment function when ask for help on the repair
Re: fuse question
If you are working on a board that repeatedly blow fuses put a filament light bulb
across where the fuse would go. If this is a mains fuse use a 40 or 60 watt 240v bulb.
If there is a short the bulb will light bright if not it will light then dim as the board powers up saving fuses.Please upload pictures using attachment function when ask for help on the repair
Re: fuse question
Well I'm hoping that it won't repeatedly blow. I just got the monitor (was turned in for recycling) and after replacing the caps since there were bad ones, it was still dead. I checked the fuse and it was bad so I figure it won't hurt to get a few extras "just in case" since I have to place an order anyway.Comment
Re: fuse question
ThanksComment
Re: fuse question
aqibi2000 - here is a link with more info.
8Amps is quite hefty what are you working on? - Perhaps you need to start a thread? and ask for help.
http://www.ea8ay.com/fairbanks_morse...ts/dimbulb.htmPlease upload pictures using attachment function when ask for help on the repair
TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...-
Channel: Common Parts Library - Datasheets
10-07-2024, 06:07 AM -
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
TF-FUSE Thin Film Surface Mount Fuses
FF Series (Very Fast Acting), 0603 Size
Features
● Very fast acting at 200% overload current levels
● Low DCR
● High inrush current withstanding capability
● Fiberglass enforced epoxy fuse body
● Copper termination with nickel and tin plating
● Halogen free, RoHS compliance and lead-free
Applications
● Notebook computers and tablets
● Digital cameras
● Memory cards
● Toys
● Bluetooth earphones
● Portable electronic devices...-
10-07-2024, 05:50 AM -
by wattageHello Badcaps Community,
The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...-
by ant3202Hi Everyone
Lately I am experiencing the deja-vu incident on one of the led monitor like this.
https://www.badcaps.net/forum/troubl...lashing-on-off
The monitor is HP 27es LED Monitor
https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
The monitor will randomly blackout and display no signal and will recover again.
Sometimes need to power and off again to restore the display but...-
- Loading...
