Phillips monitor won't turn on
  • Snype32
    • Jun 2011
    • 76
    I have an older phillips lcd that has a strange problem. When I first plug it in after it has been sitting a while, it will not turn on. No green /orange led...nothing. I opened it up and all the caps look ok, and i found out that if I have the AC plugged in and disconnect and reconnect the power cable from the power supply to the board with the display connections, it will start right up. I can even power it off and on normally no problem. However, the problem shows up again if I leave the the LCD unplugged for a while. Any ideas?
    Thanks!
  • IamCanadian
    • Nov 2012
    • 119
    Re: Phillips monitor won't turn on
    What voltage do you get for Stb power? check when working and when not turning on.
    • Snype32
      • Jun 2011
      • 76
      Where do I check that? I don't see any label.
      Thanks!
        OK, the power supply will be running the minute you have it plugged it into the AC outlet, it only has single AC output that is rectified by the Common Cathode TO-200 Diode mounted on the heat sink, the center pin (Cathode) of that Diode should have about 12~18VDC (Black probe to the chassis ground for secondary ground ref. point). That 12~18vdc gets step down by the buck converters that convert it down to 5V and also may be 3.3V for running the logic board.
        I suspect the small start up cap, you can try heating that cap with hair dryer to see if the monitor will start right up every time you hit the power switch or might as well change out that cap. Second possibility will be some thing in the buck converter circuit.
        • imp
          • Aug 2010
          • 125
          • Sweden
          Every cap seem to be CapXon May be as simple as changing capacitors.
          • FIXITNOW
            • Jun 2008
            • 128
            model number as one of us may have done one ??
            • Snype32
              • Jun 2011
              • 76
              Thanks for all the replies! Sorry I have been busy and have not been online for a while. I tested the middle lead on the diode mentioned and got very close to 12v. I will try the heat on the cap and reporrt back.
              Thanks for all the help so far. This site is great!
              • Snype32
                • Jun 2011
                • 76
                As for model it's a Phillips 170b2. If it needs all new caps, I'm not sure its worth the time.
                • FIXITNOW
                  • Jun 2008
                  • 128
                  only seen a 170b4 on this i replaced all the caps apart from the big one
                  • wattage
                    AOC AG493UCX 49-inch monitor - Firmware request
                    by wattage
                    Hello Badcaps Community,
                    The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                    07-13-2025, 04:41 PM
                  • ant3202
                    HP 27es - LED monitor - Monitor Flashing On - Off
                    by ant3202
                    Hi Everyone
                    Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                    https://www.badcaps.net/forum/troubl...lashing-on-off
                    The monitor is HP 27es LED Monitor
                    https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                    The monitor will randomly blackout and display no signal and will recover again.
                    Sometimes need to power and off again to restore the display but...
                    03-20-2025, 07:30 PM
                  • pajdek
                    Lenovo Y700-17ISK turn on and off
                    by pajdek
                    Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                    09-20-2023, 02:49 AM
                  • sew333
                    Pc shutdown, monitor flickered with no signal after 10 seconds
                    by sew333
                    My pc:
                    10850K stock 4800mhz stock Kraken X73 good temps
                    2x16 GB DDR4 GSKILL 3000mhz XMP
                    Seasonic Tx-850 Ultra Titanium
                    Gigabyte Rtx 3090 Gaming OC
                    Aorus Z490 Pro Gaming
                    1 TB SSD
                    4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                    Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                    Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                    Power...
                    02-22-2022, 10:27 AM
                  • matthewmcconaughey
                    I need help with my friend Sony GDM-FW900 24” CRT
                    by matthewmcconaughey
                    Hello, Badcaps is my last resort. I am the first owner of the monitor. I reached almost every repair store in my area, but no one even wanted to hear about troubleshooting an old CRT monitor. At this point, I have been trying to figure it out by myself, but I have no idea where to start or look for.
                    I wish to know how to think and locate a failing component. I will put all my efforts to learn and contribute.
                    1. It started with a bright and greenish picture upon starting a cold monitor.
                    2. About 2 years ago, only on the cold boot, the screen started to occasionally flash with
                    05-16-2023, 03:15 PM
