Dell 1704FP LCD w/pwr but 2 secs to Dark
  • lestr
    • Nov 2011
    • 12
    I'm a noobie who has been successful in fixing a few LCD's with standard through-hole components, but this 1704FP LCD has quite a few SMD's, something I had not tinkered with before. It all started with a no power indication. Opened up the case and found power supply components to be ok, resoldered in places that looked marginal, and replaced the shorted four FET's in the top-side of the inverter section. Powering up the board by itself, I got the following voltages at the output diodes (mounted on heat sinks): 5.3v, 12.7v, and 20.0v. At the connector P802 with the wires that connects the main board: pins 1-3, 5.3v; 4-7, 0v (grd), 8-10, 0v. With such encouraging results, I reconnected everything and repowered to get the power led to light up and for a few seconds show the OSB on the screen. By examining of the underside of the board where the SMD's are found, resistors are easy to identify but condensers are not marked. I was also able to read the markings on the following three SMD components which I don't have details for:
    On the inverter side of the board,
    I801: SG6841SZ, KMA233305490g
    On the power supply side,
    I101: OZ9930g, S1090122T, 0S46A
    Q804: 13N06L
    Markings on the Power-Inverter board: 6832151100-02, PTB-1511, 8/19/05.
    Without a schematic and very little information on this model, it's hard to make much progress. The problem still seems to be in the inverter. Another burning question: are SMD components fairly easy to get and remove/install? Your insights and help to resolve this problem will be
    much appreciated. Thank you.
    Re: Dell 1704FP LCD w/pwr but 2 secs to Dark
    You may want to read this first:
    https://www.badcaps.net/forum/showthread.php?t=10419
    Check the resistance reading of the transformers. No bad caps, bad cap can look normal but will have high ESR. May be bad lamp assemblies.
    http://s807.photobucket.com/albums/y...ell%201704FPT/
    Bad lamps:
    http://s807.photobucket.com/albums/y...klight%20lamp/
    Inverter tester lamp:
    http://s807.photobucket.com/albums/y...g%20old%20CFL/
    SG6841SZ is SMPS IC
    OZ9930 PWM IC Pinout, see pciture/pdf
    • lestr
      • Nov 2011
      • 12
      Thanks budm for the links, pictures, and info on the components. I have a lot to read and study. The inverter tester lamp really got my eye and the thing to try. I will post my findings as progress is made.
      By the way, I found out that 13N06L is a Logic N-channel FET, rated 60v, and that there is also an N-channel FET with the number 13N06. I wonder what a logic fet is and what purpose it serves in the power board?
        Can you take the resistance reading on all the pins of the OZ9930 with ref to ground (black probe on the chassis).
        • smason
          • 1652
          Seems to me I have one or two of this model on my shelf waiting for transformers.
          It's a fairly common problem on this model.
          • Lumberjack777
            • 464
            Hey smason. Isn't this the same board used in the Dell 1905FP and Dell 1704FPt where they used the wrong capacitor near the transformer? The manufacturer missed a decimal point and they used a 22uF 50v where it should have been a 2.2uF 50v and it took out the transformer?
            https://www.badcaps.net/forum/showpo...8&postcount=55
            • lestr
              • Nov 2011
              • 12
              Readings are as follows. 1: 5.67M, 2: 5.68M, 3: 0 (GND), 4: 5.12M, 5: 5.12M, 6: readings are unstable; starts at about 1.5M, goes down to about 2k, comes up to about 0.5M, then comes down again in a period of about 2-3 mins., 7: 0.94M, and 8: 0.78M.
                Thanks! I am trying to see which one is the correct reading.
                https://www.badcaps.net/forum/showth...697#post280697
                What voltage are you getting on those pins. We may be able to fix both monitors.
                • lestr
                  • Nov 2011
                  • 12
                  The capacitance of C112 and C113 in the inverter section are rated respectively as stated in the quote. I also questioned the difference as I was checking the caps since I expected consistency if the circuits are to be symmetric. Do you recall where that information can be found to ascertain what the capacitance of each should be? Thanks for your inputs.
                  • Lumberjack777
                    • 464
                    So it does have a 2.2uF on one side and a 22uF on the other? Yes, I have repaired a few of these. The 22uF 50v needs to be replaced with a 2.2uF 50v. The boards where there was a 22uF was present tended to take out the inverter transformer.
                    • lestr
                      • Nov 2011
                      • 12
                      Thank you.
                      • lestr
                        • Nov 2011
                        • 12
                        Did the resistance readings reveal anything?
                        Looking at the main board, I located two voltage regulators. I302 outputs 3.36v and I318 1.815v which matches their rating and shows the main board has power. I am not able to get voltages under operating conditions because the monitor does not stay on long enough to get a reading. However, by powering without turning on the monitor, the voltages at pins 6: 5.27v, 7: 2.52v with the remainder at zero.
                        Looking at your picture bucket there are some showing a miliamp meter being used to measure ESR with resistance measurements penciled in on the face of the meter. How did you figure what the ESR is with that setup? I used an AnaTek meter to test the caps in the power board and got zero for ESR on all of them. The capacitance with digital meter was ok. The caps are Capxons though. Any recommendations on this?
                          I am still trying to figure out since I am also helping another person with the same IC.
                          I use 1% resistor also the reading from my SENCORE 75 to verify my meter.
                          To be accurate you should remove the cap from the board since a lot of time there will be lots of caps in parallel.
                          • KRS
                            • Aug 2016
                            • 3
                            • DE
                            i have a problem with the power board 6832151100p03 ptb 1511 of the Dell monitor 1907FPVt.
                            For a projekt must die power board and the grafik board 15m away from the display.
                            The Problem ist now, the request of the backlight is coming to late.
                            Has someone a idea how can i bypassed it?
                            Or has someone the circuit diagram of this board?
                            Thank you for your help.
                            • boyebaran
                              • Sep 2015
                              • 249
                              • iran
                              Q804: 13N06L
                              hi
                              you can disable protection and see which part have a problem.most problems is in back light ccfls and high voltage transformer or mosfet driver (near high voltage trans).if u find damge mosfet check backlight and high voltage trans before replace mosfet
                              • boyebaran
                                • Sep 2015
                                • 249
                                • iran
                                what means protection?
                                when some parts have a problem the led ccfls controller ic gone to protection mode for
                                Prevention more damage in inverter board.
                                • KRS
                                  • Aug 2016
                                  • 3
                                  • DE
                                  Thank you for your answare.
                                  My problem is now how can i disable the protection mode.
                                  When i run the board with the normal cable (20cm) then is everything fine (display works). But with the 15m cable the board goes after 2 sec. in the protection mode.
                                  • boyebaran
                                    • Sep 2015
                                    • 249
                                    • iran
                                    sorry .what means about cable (20cm)?
                                    • KRS
                                      • Aug 2016
                                      • 3
                                      • DE
                                      The distance between power board and display is normaly ~20 centimeter. I want to stretch the distance up to 15 meters. If i do this, the request of the backlight is coming to late and the board goes into the protection mode.
                                      How can I disable the protection mode?
                                      • Bowline
                                        by Bowline
                                        06-11-2025, 10:13 AM
                                      • Chivo77
                                        DELL LATITUDE 5420, ST 20TFKN3, LA-K491P REV:2.0 (A01) powers on and die about 15 secs later, no video
                                        by Chivo77
                                        hello friends, I have a DELL LATITUDE 5420---MODEL P137G, ST 20TFKN3 LA-K491P REV:2.0 (A01) and its quite a challenge. It powers on with the battery disconnected, lasts on for about 15 secs, and then shuts off. It does the same with battery only (no adapter). With battery and adapter it sometimes starts after hitting the button several times. It displays nothing in every case. Since only the Boardview is available, I guided myself with schematics similar to this laptop (I'll add them down).Some measurements:
                                        1- After receiving power SIO_SLP_S0# goes high and never changes.
                                        2-every...
                                        07-03-2025, 09:20 AM
                                      • Akhlz001
                                        by Akhlz001
                                        09-20-2025, 07:15 PM
                                      • Shobos
                                        Dell E6420 XFR Rugged starts to boot but after 3 secs shuts down.
                                        by Shobos
                                        Hi, I bought 6420 XFR that tries to boot but shuts down after about 3 seconds, CPU gets warm, fan starts.
                                        So far I have tested all rails wich are good, BIOS flashed with CH341, 3.3,5, main rail present. multiple ram sticks tested. Sometimes it might stay on for longer like 4-5 seconds but not always, theres no picture whatsoever. Also on some rare occasions the caps lock flashes 1 time by itself.
                                        NOTE: I am using bench power supply not dell charger with ID pin and NO battery present, kinda doubtful this would cause this issue.
                                        Any help is welcome. Thanks !
                                        07-29-2025, 03:53 PM
                                      • master3112
                                        by master3112
                                        07-29-2025, 01:55 PM
