I've been reading all the threads on this power board. Apparently, my monitor has same problem as others, no display, solid blue light. There is a lot of discussion on the BN44-00175A about bad resistors being the problem, caused by the brown goop they use to glue them in place on the board becoming conductive. I haven't tested any of the capacitors or resistors yet but I suspect the resistors in the attached photo may be the problem as the brown goop between them shows signs of some arcing. Can anyone tell me the value of these resistors? The brown goop has covered up the markings on them as well as the number on the board so I can't tell what they are. Thanks for your help.
Samsung 245BW - Power Board BN44-00195A - No display, solid blue light.
Re: Samsung 245BW - Power Board BN44-00195A - No display, solid blue light.
You can use alcohol to soften up all them glue on the board so you can remove them a bd be able to see the color code, I also see black arcing on the little blue cap caused by bad glue.
So far I cannot find any diagram for this BN44-00195A yet.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
--- begin sig file ---
--- end sig file ---Comment
Thank you for the replys. I did read the megathread and saw the mention of the cluster of 68 ohm resistors on the bottom of the board that go bad. However, I thought that referenced the BN-00173A board, not the BN-00195A board I have. As you can see by the picture, the 195A has a cluster of 2 by the large capacitor. Sorry about the picture, it is the best I could do with the equipment I have.Comment
I took another picture of the affected area of the board. I checked both resistors. They are open. I'm trying to get new ones but the color coding on the resistor is confusing me. I'm reading the colors as gold-yellow-black brown. Gold as the first bar isn't making any sense to me. Comments would be appreciated.Comment
Those two are 100,000 Ohms 5% resistors, i think they are OK, recheck the resistance reading again.Never stop learning
Yea, 100 kohms.
This is nice tool to use if confused:
http://www.dannyg.com/examples/res2/resistor.htmComment
I would remove all the glues, especially the one that is burnt by the blue cap and see if it will fire up after glues are removed.Never stop learning
Thanks for all the good information. I like the tool. I measured the resistors. One measured 89K, the other measured 46K. Seem to be out of spec. I'll be removing the glues and see if I can get it to fire up.Comment
Those reading may be due to other components are in parallel with the resistors.Never stop learning
How can the value go higher if you have other resistors/loads in PARALLEL?Never stop learning
Can I get good pictures of the bottom side of the boardNever stop learning
Well from my 30 years of experience, I have seen it goes both way, shorted out or goes open. So I always test resistor or anything else out off the circuits.Never stop learning
Sorry I haven't followed up on this post. I put the monitor aside for awhile while working on other projects. As suggested in other posts, I cleaned the brown goop off of all the components on the board. That crap must have been very corrosive as many of the components show significant affects from it. I put the monitor back together and it still exhibits the same problems, solid blue power light, black screen.
I did find a service manual with schematics on another post. I will see if I can isolate the problem board by taking resistance and voltage measurements as other posts indicate the problem could be in the main board, not the power board. However, seeing the damage that brown goop did to some of the components, I'm pretty sure it will be a power board issue.
After I do the investigation, I will report he progress and post the pictures you asked for. Thanks for your patience.Comment
Hi, i have same board (BN44-00195A) and monitor worked for few days and then black screen. Did anyone resolve this problem?
...the quieter you become the more you are able to hear...Comment
There are hundreds of posts regarding this monitor -
Please list what tests you have done and what results you got.
Welcome to the forum-
We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
Examples of what is needed
https://www.badcaps.net/forum/attach...7&d=1280167246
https://www.badcaps.net/forum/attach...6&d=1280167246
https://www.badcaps.net/forum/attach...4&d=1280167246
It will be useful if you can say what the supposed fault was and a bit about yourself - skills tools etc.
Please also update your profile with country and mains voltagePlease upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
i remove the 2 resistors, one is 100K and other infinite ohms, so i will replace them and let you know...the quieter you become the more you are able to hear...Comment
by cajoegHello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV... -
This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-07-2024, 05:50 AM
This specification for the Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 14 I7-1255U 8GB 512GB BLUE boardview and IP3 14 I7-1255U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...09-07-2024, 05:00 AM
This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...09-07-2024, 05:00 AM
This specification for the Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R5 5625U 8GB 256GB BLUE boardview and IP3 15 R5 5625U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...09-07-2024, 05:00 AM
- Loading...
