Lines on Viewsonic LCD Screen
  • hairykiore
    • Mar 2012
    • 83
    • New Zealand
    Hi...Can I get advise on the Viewsonic VX2235 picture attached...As you can see it has two lines on it left and right of centre ...I presume that this is the LCD Screen and cannot be repaired other than with a new screen BUT just to make sure I am seeking a definate opinion here with the experts... Thanks Hk
  • jetadm123
    • 2169
    Re: Lines on Viewsonic LCD Screen
    I agree with you. It looks like the panel itself is bad.
      second that.
      • Stanley1843
        by Stanley1843
        06-29-2024, 11:54 AM
      • jeyoung12
        Samsung QN50Q60t lines on screen
        by jeyoung12
        Hi all
        I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
        My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
        This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
        It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
        So....i don't know what end of the C ribbon to work with...
        02-26-2024, 10:38 AM
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • kdaniel
        Hitachi 58HK6100U - Horizontal Lines (Bottom third of the screen)
        by kdaniel
        As stated by the person I collected the TV from, it just stopped working overnight. However, I still gave it a go to try and repair it.
        There is a thread on the same TV but with slightly different issues where they had to tape connection points on the ribbon cable, so I want to see if this is repairable by any chance.
        After bringing it home and plugging it in, the TV turned on with its backlight working but had no picture. After removing the back cover, the first thing I tried is to unplug one of the ribbon cables and the situation is as follows.
        Left...
        11-16-2022, 09:23 AM
      • Chrissygizmo
        Sony KD-55XG9505 lines on screen problem
        by Chrissygizmo
        Hello again everyone,
        This is my latest mission, to try getting this Sony tv back to normal working order…
        I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
        02-19-2025, 11:31 AM
