Dell U3011t
  • jharrop
    • Aug 2012
    • 5
    Dell U3011t
    I'm in the middle of taking a broken Dell 30" monitor to pieces, but I've got stuck trying to remove a couple of leads in the vicinity of the diffuser plate (LG LM300WQ5).
    Its a bit awkward to reach these, and my eyesight is not the best, so fumbling around I'm having trouble stumbling on the correct trick.
    If you could take a look at the attached pics, that'd be great. I don't want to damage things by forcing anything.
    thanks .. Jason
  • jharrop
    • Aug 2012
    • 5
    Re: Dell U3011t
    The product specification for LG LM300WQ5 says:
    3-2. Interface Connections
    This LCD employs three kinds of interface connections. A 30-pin connector is used for TMDS signals from the host computer. A 20-pin connector is used for LCD module power and LCM controls signal from external monitor control circuits. And 14-pin connector is used for the inverter for backlight system.
    3-2-1. Signal Interface
    The Dual TMDS signal interface connector is KDF71G-30S-1H(manufactured by Hirose) or
    FI-XL30SSL-HF(manufactured by JAE) or equivalent.
    2. Connector
    2.1 Connector(Receptacle) : KDF71G-30S-1H(Hirose) or
    FI-XL30SSL-HF(JAE) or Equivalent.
    2.2 Mating Connector(Plug) : FI-X30H and FI-X30HL or its equivalent.
    3-2-2.Power Connector
    The power connector is FI-XL20S-HF or equivalent.
    Notes : 1. Connector
    1) Connector(Receptacle) : DF19G-20P-1H or Equivalent.
    2) Mating Connector(Plug) : DF19G-20S-1C or Equivalent.
    Does this look consistent with the photos I posted?
    • selldoor
      Slow Learner
      • 7870
      Re: Dell U3011t
      Its difficult to tell how they work - usually there are tabs at each side that you push together then the plug just eases out. Check if the tape is just on the cable or if it is
      flat on the cable and connector holding it together.
        Re: Dell U3011t
        You squeeze the side metal tabs to unlock it, it is similar to LVDS connector with locking tabs, just thicker due to double-row contacts.
