HP LP2065 Buzzing noise / other issues
  • ConD
    • Jul 2012
    • 6
    • Finland
    Hi everyone.
    I had opportunity to get one HP LP2065 for free from our company's IT department. I quickly took a look that monitor showed picture and took it home. After switching on monitor at home everything seemed to be ok...
    ...however monitor wasn't ok. After it had warmed up a buzzing noise started to strengthen. After fully warmed up that buzzing is annoying and cannot be normal behaviour. Picture is fine, no flashing or anything else. Power-up is instant.
    Then i took some time googling for possible solution and i found badcaps.net and issues with other monitor that had bad capacitor problem. Ok... i disassembled power-supply card out from the monitor and thought big caps would be the problem and replaced them first.
    https://www.dropbox.com/s/1adp624rr54itvj/IMG_1398.JPG
    https://www.dropbox.com/s/c6d2xpzdct2u4ip/IMG_1399.JPG
    That was the starting stage. However replacing those Samxon caps did nothing good, in fact monitor started to shut down after it had warmed up. Time to order all the remaining smaller caps.
    https://www.dropbox.com/s/welllpq180q1b65/IMG_1587.JPG
    https://www.dropbox.com/s/rmy1of30w7mnr6q/IMG_1588.JPG
    https://www.dropbox.com/s/o3vpigxfxppg73p/IMG_1589.JPG
    https://www.dropbox.com/s/9i9j3vghohimb6t/IMG_1590.JPG
    Today i changed all those smaller c(r?)apxion caps to rubycon ones...
    Powered up monitor and complete silence. Ahhh... Would that solve my problem? After a 15min i had answer. No! That buzzing noise is still there. Picture is fine as it was in the beginning...
    What's up next?
    I've read that sometimes that big yellow transformer between AC and DC sides of circuit board may fail. It also looks like it have had some heat. Protective coating seems to be melted sometime and is in some places a bit brownish. Could that be the problem source? All other components are looking good, however i haven't tested all components separately.
    Can someone help me finding that transformer or any information or specifications concerning it? Thank you all for your help in advance! All help is respected!
  • ConD
    • Jul 2012
    • 6
    • Finland
    Re: HP LP2065 Buzzing noise / other issues
    I took my time trying to look for some information of that transformer but i got stuck again.
    However i tried to adjust brightness and contrast from OSD and when i turned brightness to 100% buzzing noise (it begins after ~10min) disappeared almost completely. Small "humming" is still audible, but that is not as annoying as the loud one. If i turn brightness from 100% to 97% (from OSD) buzzing comes back getting louder every step from 100 to 97.
    As i mentioned earlier, picture is fine. I found some information from OSD. Power on time is about 34700h and backlight time about 5870h. Are those numbers so big that i should try to look new ccfl lamps for example?
    • ConD
      • Jul 2012
      • 6
      • Finland
      Hi again...
      I uploaded pictures of circuit board. I also measured resistances of those inverter CCFL transformers. Here are the measurements from upper left to lower right:
      1: 8.89Mohm, 8.89Mohm, 0.89komh
      2: 8.89Mohm, 8.92Mohm, 0.892kohm
      3: 8.99Mohm, 9.01Mohm, 0.882kohm
      4: 0.874kohm, 9,01Mohm, 9,27Mohm
      5: 0.875kohm, 8.75Mohm, 8.85Mohm *
      6: 0.894kohm, 8.92Mohm, 8.92Mohm *
      Sometimes two transformers marked with * showed ~200-300kohm instead of 8...10Mohm. Small tap to circuit board changed readings. Are those broken? If so, where can i find spare parts? Google didn't help me with those SPI 8TP00011 transformers.
      • Rtech
        • Jul 2010
        • 1095
        Because the transformers are fitted differently,then the secondaries on Your 1,2 and 3 are 0.89K,0.892K,0.882K,whereas the secondaries on your 4,5 and 6 are 0.874K,0.875K and 0.894K...they all look fine,suspect they are not your problem.
        • ConD
          • Jul 2012
          • 6
          • Finland
          Thank you for your answer.
          Something wrong there are in those two transformers. I just made very simple microphone-headphones test with monitor interiors visible. When buzzing noise began, two of the inverter-side transformers were making much more noise than other four. After i gently tap those transformers with microphone, buzzing noise disappeared.
          Do i have to start hitting my monitor every time buzzing begins?
          The real problem is however, where can i get replacement transformers since i don't believe that those are repairable.
          • retiredcaps
            • Apr 2010
            • 9271
            The last digit is off, but it may not matter?
            http://www.lcdparts.net/TransformerD...ProductID=3355
            --- begin sig file ---
            --- end sig file ---
            • Rtech
              • Jul 2010
              • 1095
              What you could try is give them a good soaking in Varnish,and seen if that stops them vibrating, if that is what they are doing .
              • ConD
                • Jul 2012
                • 6
                • Finland
                I have to try that. Small, hardly audible buzzing is still there, but that loud one is still gone after 1 hours from that gentle tap with mic. Looks like it begins somehow after it reaches some critical temperature point.
                I have to ask more accurate dimensions to that 8TP00010 since it looks a bit smaller than my ...11 versions. Still 13$ isn't bad if it will fix that buzzing.
                • selldoor
                  Slow Learner
                  • 7870
                  Hi - You could also try de soldering and putting a small packing piece under
                  then resolder so the transformer is under some tension.
                  Size wise this site has a picture of a ...10 against a rule.
                  http://tda2000.ru/catalog/passiw_tra...ACL-TSM/61122/
                  Click on the image to make it bigger
                    May be the switching power supply is running at the wrong frequency, due the cap for frequency control is drifting in value after warm up.
                    • b700029
                      Banned
                      • Sep 2010
                      • 640
                      Loose coils or a cracked core can make that sound. I'd also recommend the varnish soak.
                        by momaka
                        03-15-2023, 10:17 PM
                      • Jesus Coder
                        Issues Reviving Old Dell 2408WFPb Monitor
                        by Jesus Coder
                        I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
                        06-25-2023, 02:33 PM
                      • ttmi100x
                        HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                        by ttmi100x
                        Greetings everyone,
                        I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                        The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                        Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                        Upon closer inspection...
                        07-31-2024, 06:36 PM
                      • wattage
                        AOC AG493UCX 49-inch monitor - Firmware request
                        by wattage
                        Hello Badcaps Community,
                        The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                        07-13-2025, 04:41 PM
                      • Rick_1234
                        LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                        by Rick_1234
                        Good evening, gentlemen.
                        I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                        To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                        https://drive.google.com/file/d/1L6S...ew?usp=sharing
                        Things I tried
                        - Bought a new AC adapter thinking that was the problem but the problem...
                        06-22-2024, 04:44 PM
