Proview PL926Wbi, no power
  • jetadm123
    • 2169
    #41
    Re: Proview PL926Wbi, no power
    Diode D28 located right above the voltage regulator, what is that brownish color on it?
    • retiredcaps
      • Apr 2010
      • 9271
      #42
      You can narrow down the problem by disconnecting all your boards and hooking up the ccfls to the power board. Then apply 3V to the BL_ON pin using a CR2032 battery or two AA batteries in series.
      If the backlight comes on, then you know the problem is somewhere on the main board. If the backlight does not come on, you know the problem is in the inverter section. If the mosfets are good, it could be the inverter pwm chip?
      --- begin sig file ---
      --- end sig file ---
      • maybenever
        • 158
        Don't know, I'll check it out.
        I'll try this ASAP. Thanks.
        • selldoor
          Slow Learner
          • 7870
          #44
          On the power supply fuse F203 can you test the voltage on each side .
          Meter on 20vdc black lead on ground red on each end of fuse. CARE do not touch the heatsink.
          • maybenever
            • 158
            I've checked voltage on both those fuses. I can't remember which is which, but one was 14.5v and the other was 4.98v. I've never checked a "should be" 5v pin that didn't check at least 5.1v to 5.5v. Wonder why this 5v is a little less?
            • maybenever
              • 158
              Connected 3v to BL_ON pin and got nothing. Connected 5v to BL_ON pin and got nothing. I'm about ready to remove the good caps off this thing and move on.
              • Rtech
                • Jul 2010
                • 1095
                #47
                Perhap a silly question BUT we all make errors occasionally...I assume that when you applied the voltage btween the BL_On pin and GND...you did have the mains Power switched on ??
                • maybenever
                  • 158
                  Yes, I had the AC power cord connected. When I was checking the MOSFETs, I was told to set my mm to 200ohm, but I got out of range readings, I had to go to 20k to get readings, is that right?
                  Measured mosfets Q5 & Q6, part # K3615 7F. With meter set on 20k, pin 1 to 2 = starts at zero and just keeps climbing, pin 1 to 3 = 5.64, pin 2 to 3 = 2.66. Both parts test the same.
                  • selldoor
                    Slow Learner
                    • 7870
                    #49
                    Yes that is correct. The test is only for shorts so a reading of less than 30
                    ohms may be a short. More than 200 should be ok so as long as it is over 200 ohms that is all that is required.
                    • Rtech
                      • Jul 2010
                      • 1095
                      #50
                      It may be right,BUT I have exactly the same Board,in my case working,and measuring resistance between Pins 1 and 3,on Q5 and Q6,and irrespective of which way around you have the neg and pos leads of your meter,I get in excess of 10KΩ,so suggest you try again !!
                      • jetadm123
                        • 2169
                        #51
                        Here's what I see so far:
                        1) the main doesn't seem to output a constant BL_ON voltage.
                        2) you can't get the backlights to turn oun even with an external power source.
                        3) the mosfets are questionable.
                        4) the power supply seems to output the proper 5V and 12V.
                        bad ccfl(s)? bad mosfet? short on mainboard?
                        • maybenever
                          • 158
                          Right, maybe all the above. I've got the backlight assy. removed, connected to a working mainboard, no light. Those mosfets, I check them with 200k range on the DMM, 9.8k reading. 20k range, 5.64k reading, that's -lead on pin 1, +lead on pin 3. My meter is good, I can test a 10k resistor on 200k range, I get 9.8k reading, 20k range, I get 9.84k reading, so the meter is working OK, right. It don't make sense to me. Anyway, putting this project in the experence folder and moving on. Thanks to all.
                          • maybenever
                            • 158
                            A correction, that "good" board I tested my ccfls with, in fact was not working I guess. It was out of a working monitor with a small problem, so I was going to recap it and put it back together which I did. Before puting the back on, I connected the Proview lamps, I'll be dog, they both work. So now I have working lamps for future testing.
                            • joliver82
                              Sony XR-65A95L no power due to logic board issue
                              by joliver82
                              Hi guys!
                              I'm trying to repair a TV that a friend gave me recently. Lightning struck next to his house and broke the TV apart from more electronic devices.
                              First of all I've checked the power supply and it works as expected. I removed the logic board and shorted the 3.3v standby output to TCON_ON and POWER_ON and every voltage was generated as expected (12v and 25v for logic board and 32v for TCON).
                              When trying to boot the TV normally (having the board connected), the TCON_ON signal is not generated from it which made me think there's some issue in the logic...
                              11-26-2025, 04:57 PM
                            • Soulzink
                              Samsug washing machine. Power supply DC41-00189a board issue
                              by Soulzink
                              I am trying to fix a samsung washinmachine power supply main board.
                              I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                              Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                              The power supply board reference is the following: DC41-00189a
                              I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                              04-19-2025, 06:26 AM
                            • Dani_2024
                              by Dani_2024
                              10-28-2024, 05:06 PM
                              by sam_sam_sam
                              After all of...
                              07-13-2024, 08:14 PM
