Asus MK241H no power
  • tibimakai
    • Jan 2012
    • 3680
    I have picked up this monitor and it seems dead. No standby led, no standby voltage.
    The only voltage I can measure is the 170V on the big cap.
    I have found a bad FET transistor(Q101) which I have replaced and all the capacitors, just to be sure.
    What else can I check?
    I have made some pictures, they are not the best. I can make new ones tomorrow if needed.
  • selldoor
    Slow Learner
    • 7870
    Re: Asus MK241H no power
    Hi - I dont know how you can get pictures so good and pictures so bad in the same series. Anyway if you have 170Vdc at the big cap and nothing else. Id first check the
    voltages coming out of the transformer.
    On the pic of the back for the board bottom left just above the 16pin connector there is a component that looks to have
    A1 or 1V on it - is its a fuse - can you test it.
    • tibimakai
      • Jan 2012
      • 3680
      The pictures made from above were done on a stand and the side onese from hand.
      The fuse checks out good. There are two more on the bottom, F101, F102 they are good too.
      • jetadm123
        • 2169
        Q101 was shorted, correct? There may be other components shorted, preventing the power supply from starting. What is the part number for IC200 (located on bottom of board)? And is it connected to Q101?
        • tibimakai
          • Jan 2012
          • 3680
          It was shorted in every direction. Most likely you are right that is not only this Fet is out.
          I will check it when I will get home.
          • tibimakai
            • Jan 2012
            • 3680
            The IC is AS324AM-E1.
            • retiredcaps
              • Apr 2010
              • 9271
              See if the SMPS IC is shorted between Vcc and GND.
              --- begin sig file ---
              --- end sig file ---
              • tibimakai
                • Jan 2012
                • 3680
                There is 75.5kohm, so I guess it's not shorted.
                • jetadm123
                  • 2169
                  As odd as it sounds, the AS324 is a quad op amp. Not what we're looking for. We're looking for the pwm controller that drives Q101. On the heatsink that Q101 is mounted on there's another device mounted to it on the opposite side. What's the part number of it?
                  • tibimakai
                    • Jan 2012
                    • 3680
                    K3568
                    • tibimakai
                      • Jan 2012
                      • 3680
                      Q101 has
                      G=0.040V
                      D=168V
                      S=0.045V
                      Q(otherside)(hooked up flipped over can't see the number right now)
                      G=0.068V
                      D=168V
                      S=0V
                      • jetadm123
                        • 2169
                        Not it either. Okay, on your fourth photo, there are two 8-legged chips towards the bottom. Looks like IC100 and IC102? How about their part numbers?
                        • tibimakai
                          • Jan 2012
                          • 3680
                          If I measure between pin 1 and pin 4 on A324, I'm not getting anything 0V.
                          • tibimakai
                            • Jan 2012
                            • 3680
                            There are two more ICs on the bottom:
                            EA1530A VCC=0V
                            L6562D VCC=0.133V
                            • jetadm123
                              • 2169
                              EA1530A
                              L6562D
                              Great!
                              EA1530A is a TEA1530A power supply controller and the L6562D ia a power factor (PFC) controller.
                              You can test across pins 1 and 2 of the TEA1530 to test if Vcc and ground are shorted.
                              Test across pins 6 and 8 of the LD6562 to test Vcc and ground for a short.
                              At this point, I suspect pin 6 of the TEA1530 or pin 7 of the LD6562 are connected to the Gate of Q101. You can try using your meter to perform a continuity check to verify this. Sorry, but I must sign off for now. Hopefully, another member can take over.
                                OK, I look at the pictures, you will need to get the P/N on the SMPS and PFC IC.
                                Edited: OK, I see you got the P/N for the ICs.
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  Found these two resistors suspect to me. The previuos owner mentioned about a pop before all went south.
                                    They sure do look burnt up, cannot read the values any more, you will have to find out what pin of the IC they are connected to, then download the spec sheet of the IC to see what that pin/s do.
                                    Man! Good pictures? What camera do you use? Is it that USB Micro scope? I forgot the model number you gave me.
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      Forum is back and it's much more snappier, yeahh!
                                      The pictures are made with the USB Microscope. This one, which is 2MP:
                                      http://www.amazon.com/Celestron-Delu...usn+microscope
                                      The resistors are from pin #5. I can't find resistor values anywhere on the net.
                                      I have found some values from another Asus 19" monitor.
                                      The resistors still have a value, one is 180KOhm and the other is 2.5MOhm(this one I haven't removed yet, it may have other value removed).
                                      While the forum was down and I couldn't work on the monitors/TVs from the forum, I have fixed a LG L227WTG 22" monitor, and a Samsung 226BW 22" monitor, bad caps.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        Should I replace the resistors, or just leave them, since they have a value?
                                        The values that I have found in another service manual for a 17" monitor, had much smaller values(1K and 22K).
                                        I will just replace the EA1530A chip, it's cheap anyway and go from there.
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • ShadowAi
                                          ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                                          by ShadowAi
                                          Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                                          Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                                          After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                                          03-15-2024, 10:46 AM
                                        • meraklinetx
                                          Asus Z97-a power cycle, no boot no cpu voltage
                                          by meraklinetx
                                          Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                          05-10-2023, 06:08 AM
                                        • conghuyms
                                          Request for Help – ASUS G531GW Rev 1.6 – No Power On
                                          by conghuyms
                                          I need your support with an ASUS G531GW Rev 1.6 laptop.
                                          When I plug in the charger, the battery charging LED turns on, but the board does not power on when pressing the power button.
                                          Here’s what I’ve checked so far:
                                          • Motherboard has been removed for inspection.
                                          • 3V and 5V always-on rails are present (3V/5V_ALW).
                                          • 1.8V and 1.09V at the PCH are present.
                                          • I don’t have the boardview/schematic, so troubleshooting is limited.
                                          • I tried checking the power button signal from the
                                          07-20-2025, 09:14 PM
