Viewsonic VE710b Power on black screen
--- begin sig file ---
--- end sig file ---Comment
Re: Viewsonic VE710b Power on black screen
There are mutiple VE710b versions.the monitor should also have a model number on,and they are all different as far as I can tell.As different manufacturers can use different components, different layouts and circuits to obtain the same inputs and outputs,anything goes.So unless you got the above tfmr details from exactly the same board as this unit has then that is probably the differenceComment
Another number that Viewsonic uses to identify the different revisions of the same model can usually be found on a sticker in the back of the monitor. It will read something like model: VSxxxxx. What is this number? It should help ID the power supply.Comment
3) 240
4) Open circuit....
So, that means the transistor is ok?
When i power on the board sounds noisy, i don´t know if this is normal or is because a faulty component.--Comment
Hi - you will have to be more exact as to where the sound is from roll up paper or thin card tube and try and pinpoint where its comes from.
When you have put the mosfet back in (with it all connected up) what voltages do you get on the connector to the main board. I see the main cap seems to be a Ltec, they are not the best - what make are the smaller caps - if they are ltec they will need upgrading.
Bad caps can contribute to noise as the voltages on the board are not stable.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
I will solder the transistor and make a video to show you what happens...
selldoor, what do u think about the diode's readings??Comment
If you have
2) 1 (Infinite resistance)
3) 240
4) 240
5) 1 (Infinite resistance)
In accordance with retiredcaps test instructions then it is OK.
Better post a pic of the mainboard front and back and the board
on the back of the panel [if this model has one] take care in handling this.
Have you been able to retest the inverter transformers yet.Please upload pictures using attachment function when ask for help on the repair
Right inverter transformer:
P1-P2: continuity
P1-P3toP6: continuity
P2-P3, etc: continuity
P1-S1: 618
P1-S2: 822
P2-S1: 618
P2-S2: 822
Left inverter transformer:
P1-P2: continuity
P1-S1: 614
P1-S2: 818
P2-S1: 614
P2-S2: 818
Both have the same readings.
Here's two pics from the mainboardComment
The resistance and diode tests suggest it is okay, but there is still the question if it outputs the correct voltage.--- begin sig file ---
Perhaps we need to go back to basics here ! When you switch on the Monitor, I assume the Power Led comes on ?? then when you switch the Computer on and apply a signal, what happens to the Led ?? eg recognises the signal?, therefore changes colour ?, and stays that way?, or flashes all the time etc etc?. According to the resistance readings the Inverter tfmrs are OK.Outputs of 5v and 12v seem to be normal.I note this is the standard Royer type setup, so doubt,based on the symptoms,must be considered reference the timing caps and associated transistors, and of course the Backlights themselves.This really does highlight the importance of having some test Backlights,and unless these can be eliminated and/or confirmed as the problem,then,you are now going to have to test all the Royer components,and hope that they indicate where you go next.Comment
I uploaded a video to show you the little sound makes the power board after power on. In exact time the sound comes out, the screen partially blinks.
here's the video: http://www.youtube.com/watch?v=CHpzS...ature=youtu.beComment
another bulb on this monitor or these bulbs on another monitor.
If you cant you will have to try and get to the bulbs in the panel and see if the wiring or bulbs are burnt.
Can you identify where the sound comes from.Please upload pictures using attachment function when ask for help on the repair
I have in my work office a broken lcd monitor (only the lcd screen). I will remove the backlights and try it with this board...but the noise seems to come from the side of the main transformer, but cannot say the sound coming from it, but its from that sector...Comment
If the cables will reach you may not need to dismantle it fully.Please upload pictures using attachment function when ask for help on the repair
The mainboard sends to the power supply the on signal, but receives the correct voltage from the power supply?? I mean, if i disconnect the mainboard is posible to see in the screen the message (no signal?) without the intervention of the mainboard? (I'm asking supposing I can send the on signal to the power supply bypassing the correct pins or something like that...)Comment
CN6 goes to the Logic Board, is there any markings on the bottom of the Board to tell you what is supposed to be on each pin ?? with only six pins, it is likely that they are 2 x ground, maybe 2 x 5/12volts,1 x Dim/adjust, and 1 x BLON/ENA,Using the latter and ground you can apply approx 3v,maybe from a battery,Power the Power board ONLY,and have lamps plugged in, and if the Board is 100% the lamps will light.Comment
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by domuAs per subject, on power up display shows no image, but white
flickering screen. Strangely, it only happen after power was lost
when it was on. After power returns - white screen only, but if
disconnect power for 12-24 hrs, and connect then again monitor
works normally.
Any clues how to go about it would be greatly appreciated.-
by grimacelordHello,
I have an HP 15-eh1070wm laptop that came to me for the same reasons I am starting this thread. The charging LED appears when the laptop power adapter is connected and the power LED appears when pressing the power button, but nothing appears on screen.
First thing I did was take off the bottom panel and remove the battery and then press and hold the power button for 30 seconds and then reinstall the battery and power on. The fan spins and this time, the back light illuminates and a brief message appears on the screen for about 1 second saying something along like,...-
Channel: BIOS Requests ONLY!
by joaquinmjuanHello, I have a Canon TS8350 printer. The problem is that when I turn it on, "CANON" appears on the screen, but it never goes away. You can leave it on for a whole day, and it doesn't go away. Does anyone know how to fix this? I've tried unplugging it, but nothing. I've also tried holding down POWER, but nothing. In fact, once it turns on, it can't be turned off with the Power button. I've also held down Power and then plugged it into the Power supply, and the power light flashes once and doesn't turn on, but then when I press Power again, it turns on. Currently, it's a nearly new paperweight,...05-07-2025, 12:26 AM
by AlicatHello,
Stopped by this site trying to fix my parents Panasonic Plasma TV.
Model number is TH-50PZ85U
Power comes on and the red power light stays on solid.
Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
I also hear a few clicks.
I also think my parents said there was a thunderstorm and the TV failed after that.
Section 6 in the service manual talks about power and no screen,...10-30-2024, 10:09 AM - Loading...
