Viewsonic VE710b Power on black screen
  • Guti904
    • Jun 2012
    • 71
    • Argentina
    #81
    Re: Viewsonic VE710b Power on black screen
    The vga cable have a ground connector to a screw of the mainboard (not connected right now). Could be this important?
    • retiredcaps
      • Apr 2010
      • 9271
      #82
      When we are doing remote troubleshooting, I have no idea what you are looking at. Thus, clear focused pictures are always a good idea.
      --- begin sig file ---
      --- end sig file ---
      • Guti904
        • Jun 2012
        • 71
        • Argentina
        #83
        I'm taking about the connector from the mainboard that ends in a DB9 blue connector (VGA). The connector has a ground cable. More pics.
        • Guti904
          • Jun 2012
          • 71
          • Argentina
          #84
          Originally posted by retiredcaps
          Check and reseat all your connectors whether you touched them or not. Always plug in a source (i.e. computer display your favourite wallpaper).
          I put back all the connectors and everything looks worse now including the right side of the screen...
          • killian6pk
            • Apr 2010
            • 502
            Hi guys, after search a lot, I found the C5707 transistor, I´ve replaced the two transistors 2 minutes ago, and I tested the power board with the mainboard and the panel board. I power on and the green power led turns on, then the backlights power on about one second and power off and after that power led change from green to ambar and remains in that status. My question is, without the screen connected, it's a normal behaviour or the backlights must be always on and the power led must remain green?
            The reading of both C5707 between leg 1 and 2 is almost 8V when the backlights is on and falls to 0 when turns off.
            If I remember correctly with this type of power board (BenQ design) there is also a small black fuse labeled: BEL 3A 125V http://www.digikey.com/product-detai...1017-ND/614969 I have actually seen a board with two of these fuses and a Transistor Labeled FU9024N http://www.digikey.com/product-detai...024N-ND/358230 I think there are two of these on that board also. I understand that all of these need to be replaced if you are replacing the C5705s. Hope this helps.
            Have you ever stopped to think and then forget to start thinking again?
            As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
            • Guti904
              • Jun 2012
              • 71
              • Argentina
              #86
              I think inverter is working ok with the replacing of the two c5707 (with the source connected now the image appears). The half screen image may be caused by a faulty t-con (mainboard) or a faulty screen (COF). I'm right?
              • etecnics
                • May 2012
                • 9
                • sri lanka
                #87
                it happend on back lamp driver circuit issu replace the ccfl driver transformer ocilator trancistor i think its a c5707 x 4 and .22uf 200v x2 replace this parts and try 100%
                • etecnics
                  • May 2012
                  • 9
                  • sri lanka
                  #88
                  replace ur lcd display,100%
                  • Guti904
                    • Jun 2012
                    • 71
                    • Argentina
                    #89
                    I replaced 2 of the 4 c5706 transistors. Now backlights are working but i've half screen. So, I must to try something new, or the lcd must be damaged, maybe when the power board failed it damage the lcd cof (chip-on-film)? I must stop trying to fix this, and the solution is to replace the entire lcd screen?
                    • killian6pk
                      • Apr 2010
                      • 502
                      Why didn't you replace all 4 of the C5707s? Usually when one or more go bad they all go bad or will go bad just after you replace one or two and then power back up again. You need to replace the two that you did not replace the first time.
                      • Guti904
                        • Jun 2012
                        • 71
                        • Argentina
                        #91
                        Ok, but i'm still wonder if half screen behavior can be due to inverter problem...
                        • Guti904
                          • Jun 2012
                          • 71
                          • Argentina
                          #92
                          The two resistances near the c5707s are shorted also...so I think I must to change everything to leave the power board ok, but I'm concerned about the half screen image...
                          • killian6pk
                            • Apr 2010
                            • 502
                            Get the components replaced, resistors, remaining 2 C5707s and then if you are still having that problem it will be easier tracing it down knowing those problems have been fixed. Also did you look to see if your board has the FU9024N Transistors. I have repaired 2 Dells, A Viewsonic like yours and I believe it was a Gateway that all had the same parts. When I was repairing the Dells the thinking at that time was to replace all of those components. I don't know if that has changed, but I will bet the same advice is still good. Oh and one other I repaired with this board was a BenQ. Still replaced all those transistors.
                            • killian6pk
                              • Apr 2010
                              • 502
                              One other thing when you are changing the C5707s are you paying attention to how the old ones came out. I am not sure it matters, but the orientation might be important. I would make a note on each one that you remove whether it faced in or out with respect to the capacitor.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #95
                                It matters!!
                                • Guti904
                                  • Jun 2012
                                  • 71
                                  • Argentina
                                  #96
                                  I read another post in the forum and say it can be a problem with the cable going to the t-con or that it's damaged. If backlights are working ok right now, I must not leave out the PSU and look elsewhere?
                                  • Guti904
                                    • Jun 2012
                                    • 71
                                    • Argentina
                                    #97
                                    Any idea?
                                    • Rtech
                                      • Jul 2010
                                      • 1095
                                      #98
                                      The resisitors you mention are probably not short, resistors of this type do not go short, and no doubt, you are reading them in circuit, which is causing the anomaly.The fault now that you finally changed the transistors, is more than likely to be the LCD panel itself.
                                      • HTR-Informatique
                                        Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                                        by HTR-Informatique
                                        YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                                        I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                                        On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                                        I also changed the screen because the PC fell and the screen was broken.
                                        I changed the battery with a new and original battery.
                                        I also had corrosion/oxidation on the...
                                        02-09-2025, 06:51 AM
                                      • howardc64
                                        by howardc64
                                        Problem
                                        08-04-2024, 10:36 PM
                                      • VcemPzd
                                        Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                        by VcemPzd
                                        Hello everyone !
                                        My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                        04-28-2025, 10:14 AM
                                      • DaniK
                                        Acer Aspire E5-574-52RH - black screen
                                        by DaniK
                                        I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                                        Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                                        Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                                        Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                                        The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                                        Symptoms are:
                                        - random black screen after displaying Acer logo...
                                        02-21-2024, 06:27 AM
                                      • turmix
                                        AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                                        by turmix
                                        Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                                        The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                                        At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                                        During another reassembly, I made a mistake, and...
                                        01-29-2024, 03:48 AM
