Very Very weird Help please if u can
+ More Options
Posts
  • LITEZONER
    GO BOLTS!
    • Mar 2010
    • 223
    I have an ACER AL2032w monitor, shut it down for the weekend, came in Monday, it won't go out of standby (Orange Light) figured bad caps, replaced with Panasonic caps of exact same specs, temp, everything. The old one's were bulging just a bit. still same issue, but here is the weird part, I power on the monitor, orange light still, no logo, nothing, plug in a VGA cable from pc to input on monitor with power on, Monitor Power goes off. unplug vga cable, (signal) monitor comes back on (Orange light) I am thinking power supply, I have no clue how to connect up a voltage drop test on it to see if the signal is just too much for the power supply to handle because it's failing??? what do you think folks?. Thank you in advance for all your ideas and suggestions, all are very much appreciated.
    39 Soldering Iron burns And Counting
    Re: Very Very weird Help please if u can
    Not sure if this model the Led will go from Amber to off when it detects the video signal from the PC, or if it suppose to turn green.
    But first thing we need are the good clear pictures of the boards, please use GO ADVANCED to upload (paper clip symbol) the pictures.
      What series of Panasonic capacitors did you use in your monitor?
      Do you have a digital multimeter?
      • LITEZONER
        GO BOLTS!
        • Mar 2010
        • 223
        the Led will go from Amber to off when it detects the video signal from the PC. It is suppose to go blue on detection of signal. I do have a digital VOM. The caps I used are STSI Part #:EEU-FC1E271
        Panasonic FC-Series Radial Lead Aluminum Electrolytic Capacitor, 270uf, 25v, Low ESR
        SMD Not SMD
        Body shape Radial lead type
        Polarty type Polar
        Rated voltage 25 (V)
        Capacitance 270 (micro F)
        Tolerance on capacitance -20 to 20 (%)
        Tangent of loss angle(max.) 0.14
        Leakage current(max.) 67.5 (micro A)
        Category temperature range -55 to 105 (Cel)
        Body diameter 10 (mm)
        Body length 12.5 (mm)
        Lead(terminal) pitch 5 (mm)
        Rated ripple current-1(freq.) 100000 (Hz)
        Rated ripple current-1 755 (mA)
        Rated ripple current-1(unit) mA r.m.s.(root mean square)
        Impedance-1(frequency) 100000 (Hz)
        Impedance-1(max. value) 90 (m Ohm)
        E.S.R.-2(freq.) ?
        E.S.R.-2(max. value) ?
        Endurance 3000 (h)
        Forming & packaging feature Bulk(no lead wire or terminal forming),bag packing
        Appearance P.E.T. sleeve sheathing(metal case)
          Okay those look perfectly fine, I was wondering if you used e.g. Panasonic NHG which are not suitable, but FC are very good.
          With your multimeter check the output voltages of the PSU are all good. Post a picture of the connector if you need help with this.
          The next step is then to check the LDOs on the main board which can cause lots of strange issues.
          • jetadm123
            • 2169
            Panasonic FC caps are a good choice. However, one of the major mistakes people here make is replacing caps based on sight. In other words, caps don't have to be bulged to be bad. Ideally, you should have replaced all the caps ( you can leave the large 450V one alone as that rarely fails). At this point, the faster you post some photos, the faster you'll get some help.
            • LITEZONER
              GO BOLTS!
              • Mar 2010
              • 223
              The power supply is 4 pins, 18.5V on 2 of them and 0 on the other two, Not sure where the low dropout regulator is or how to go about testing it.
              • LITEZONER
                GO BOLTS!
                • Mar 2010
                • 223
                Pictures
                  These are probably LDOs.
                  Test each.
                  To test:
                  Set meter to DC 20V.
                  Get monitor into non working state.
                  Place black probe in spare screw hole/frame of monitor for your ground.
                  Touch red probe on each pin and note the voltage. Also note if it is particularly unstable or fluctuating.
                  Report back with the voltage on each pin and the part # on the device.
                  • LITEZONER
                    GO BOLTS!
                    • Mar 2010
                    • 223
                    the lower two units are both 1084 0257AL, The upper unit Much smaller one is 5DHL 1117L
                    The readings are in the picture, some fluctuation, but not much
                    • selldoor
                      Slow Learner
                      • 7870
                      Those look to be ok - can you post good clear focussed pictures of the power board - A bit sharper than the previous ones which are not really sharp enough
                      for troubleshooting. Tops and bottoms please.
                      Did you try a different vga cable. Different input DVI Scart etc.
                      Have you tried it on another pc or another screen on your pc.
                      • LITEZONER
                        GO BOLTS!
                        • Mar 2010
                        • 223
                        My old cable is working now with my back up screen. I will take some better pictures and post on Monday when I get in. Happy Fathers Day to all you pop's out there.
                        • LITEZONER
                          GO BOLTS!
                          • Mar 2010
                          • 223
                          More pics Hi Res. Under mag it looks like there may be something going on just above C144 on the back of the board, Not sure what it is though.
                          • LITEZONER
                            GO BOLTS!
                            • Mar 2010
                            • 223
                            here
                            • LITEZONER
                              GO BOLTS!
                              • Mar 2010
                              • 223
                              and here, new problem, blinking amber light now, This thing is ready for the Hot SHT Tank!
                              • LITEZONER
                                GO BOLTS!
                                • Mar 2010
                                • 223
                                Cannot find this part anywhere, acer does not make it anymore, I wish I did not like this dang Monitor so much Part number is 55.L38VE.003
                                • selldoor
                                  Slow Learner
                                  • 7870
                                  How about a close up picture of it then? - What is on the other side.
                                  I suspect its a super Teapo cap - check its not burst at the bottom
                                  I think you are going to have to replace all the caps on this board as they are teapo (unless you have an esr meter)
                                  Please can you update your profile with country and mains voltage
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    Still no picture of power supply either?
                                    • LITEZONER
                                      GO BOLTS!
                                      • Mar 2010
                                      • 223
                                      Yes I do think that is what happened, there was some stuff on the bottom that appeared to be a solder like substance, it was hard to get off, also it seemed it came through one of the solder connections on a Cap, The solder joint in question is dirrerent that the others, it looks rough and not nice and clean like all the other solder joints. do you know where I can find these caps? TEAPO. Or would a regular electrolytic cap work? does it have to be low esr? The power supply is just a black box, I think you want me to take it apart and post a picture of it?
                                      • LITEZONER
                                        GO BOLTS!
                                        • Mar 2010
                                        • 223
                                        Picture 7 right above C144
                                        • serious_electron
                                          Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                                          by serious_electron
                                          Hello Everyone!
                                          I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                                          06-28-2025, 02:57 PM
                                        • MOSSEP
                                          Monitor Audio RSW12 - Green light but no audio
                                          by MOSSEP
                                          Hi
                                          Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                          Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                          The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                          I have already tried replacing all of the...
                                          01-26-2025, 08:18 AM
                                        • mosfetratus
                                          macbook A2918, orange light off when shut off
                                          by mosfetratus
                                          When i fully shut off mac, orange light goes off and wont react to power button. I have difficult time resetting with combination "shift+control+option and power button", because it rarely works (reason unknown), when i manage to get orange light and then press power button macbook wont turn on and orange light goes off. When i hold combination with power button it turns on, and works fine if put it to sleep mode.
                                          Works with battery and charges, but when i shut off i get this problem.
                                          It had liquid spill. Board has no corrosion, keyboard is working, power button...
                                          05-31-2024, 03:34 AM
                                        • MOSSEP
                                          Monitor Audio RSW12 - Green light, but no sound
                                          by MOSSEP
                                          Hi
                                          01-26-2025, 08:33 AM
                                          by momaka
                                          03-15-2023, 10:17 PM
