Another Dell 2007FPb problem
  • spaceman
    • Jan 2009
    • 52
    Display: Dell 2007FPb
    The issue is that the screen has a white filter across it and I can't see anything visibly wrong with any of the boards. I'm hoping that it is the inverter board and not the lcd itself, which is what I'd appreciate some expertise on.
    If it is an easy fix, then I'd be happy to swap some components, but if it is much more, then I'll probably end up buying replacement boards. After all, these are at my work and time is a factor.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Another Dell 2007FPb problem
    Trying cleaning and reseating all your connectors. Hookup a source and see if the picture improves as opposed to the test signal.
    --- begin sig file ---
    --- end sig file ---
    • spaceman
      • Jan 2009
      • 52
      Cleaned all the ribbon connections and checked all of them, applying signal had the same result, and contrast/brightness settings were fine.
      Anything else I should try? Where would this sort of problem originate?
      • selldoor
        Slow Learner
        • 7870
        Is there a factory reset on the on screen display menu.
        What actually happens when you turn the brightness right down and the colour right up
        I see the boards are populated with elite caps and whilst I have not seen this fault before it could be that a change in voltage somewhere due to faulty caps would cause it. If it was mine I would change all the elite caps
        • spaceman
          • Jan 2009
          • 52
          Didn't see a factory reset, but the brightness/contrast settings were on 50 out of 100 and they did act as they were suppose to, but they didn't help with the problem at all.
          • Rtech
            • Jul 2010
            • 1095
            Check to see if there is a fuse blown on the T-Con Board.
            • toti24
              (NEED HELP)dell precision m4600 problem after bios flash (unbrick)
              by toti24
              dell precision m4600 laptop
              i7 2760qm
              8gb ram 750gb HDD
              intel hd 3000 integraded and nvidia quadro 2000m
              pleasea bear with me english isnt my language and ill try to be as clear as possible
              note i live in mexico in a very small town..
              thank you.
              laptop got bricked (freeze at dell logo) i managed to unbrick it but now am facing a problem...... let me explain what and how it happened.
              the brick happened when i was installing win 10 using usb.
              used rufus and officia microsoft.iso
              it finished copying files from usb...
              03-06-2022, 08:39 PM
            • multimesut
              Dell 2007FPB Yellow Light Problem
              by multimesut
              Hello friends,
              A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard....
              11-13-2024, 07:00 AM
            • SDNarcia
              Dell 15R-5521 keyboard problem (KBC?)
              by SDNarcia
              Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
              As additional information,...
              07-20-2024, 10:47 PM
            • Achille15
              Dell N5110 problem
              by Achille15
              so, I have this laptop Dell Inspiron N5110 with a heating problem on both CPU (I7-2680qm) and GPU (GT 525m), I tried many solutions, like changing thermal paste every month, using thermal pads on CPU and GPU, even using thermal pads on CPU nearby coils; but nothing worked, just minutes after booting the laptop shuts itself down so I thought it might be a short problem, so I decided to check what's going on, so I went online and some tutorial (general one) said to check inductors in order to find the shorted circuit, after checking (CPU removed), I found the culprit to be...
              03-29-2025, 04:41 PM
            • masoksian
              Dell latitude e7470 not turn on .power buton on off and Run Power problem
              by masoksian
              I am dealing with the problem of turning on and off my Dell e7470 notebook.
              The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
              The system does not turn on, there is no post.
              I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
              The problem continues in the same way.
              I tried to turn on the Fn key, nothing came to the screen....
              02-15-2025, 12:08 PM
