Help with Phillips Philips 150B power supply issue!?
  • sevren
    • May 2012
    • 3
    • New Zealand
    Hey Guys,
    Newbie here not too sure if i even have the this post in the right section. Just posting in regards to my LCD monitor (Philips 150B) internal power supply. I'm pretty sure the Caps are dead. The power led blink every 6 seconds and use to take 4minutes to fire up.. Latest boot time was 45mins lol
    Now what I'm wanting to know is. instead of replacing the caps (because im kinda cbf and don't have $$$) am i able to use an old PC PSU? if so could you guys give me a hand with the pin outs?
    As i wont be needing the back light part of the standard PS because the LCD now resides on top of my old OHP to serve as my Ghetto Home Theater projector lol
    Here's where I've got to so far:
    Pics of standard PS
    Help with what needs to go to BRI, P-ID and obviously what needs to go to ON/OFF? im pretty sure i know where the other pins go to lol
    And the PSU which i have prepped kinda to use. Which is from a fairly new compaq desktop which i scrapped for parts. psu tested working.
    Any help appreciated.
    Cheers in advance
    Richie
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: Help with Phillips Philips 150B power supply issue!?
    The connector in this pic goes to the mainboard right?
    If so, connect up the GND, 12V and 3.3V lines to your ATX PSU and see if it works.
    "ON/OFF" and "BRI" are inverter control signals (lamps on/off and brightness) coming from the mainboard. As you're not using the inverter part anyways, you should be able to just leave them disconnected. What P-ID is.. no idea
    Could you trace where it goes on the PSU board?
    PS: A lot of people on here don't like externally hosted pics. Much less externally hosted pics posted inline.
    Personally, I don't mind as long as they're not on a known malware hoster like imageshack, but to not piss off some of the gurus on here, next time when you post something, click "go advanced" and then "Manage attachments" (below the post editor)
    • sevren
      • May 2012
      • 3
      • New Zealand
      Cheers Scenic for the reply.. I have already connected voltages and grounds.
      P-ID goes to the same places that BRI and ON/OFF go so I'm guessing its for back light control also? Picture is of traces for BRI, ON/OFF and P-ID.
      Am to try it as soon as i get home.
      Thanks again and sorry about the externally hosted pictures.
      Richie
      • sevren
        • May 2012
        • 3
        • New Zealand
        Sorted and working.. Thanks Scenic. ITS ALIVE!
        • Soulzink
          Samsug washing machine. Power supply DC41-00189a board issue
          by Soulzink
          I am trying to fix a samsung washinmachine power supply main board.
          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
          The power supply board reference is the following: DC41-00189a
          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
          04-19-2025, 06:26 AM
        • KYBOSH
          Eufy Floodlight Cam 2 Pro Dead. Power Supply issue...
          by KYBOSH
          I have a floodlight-security camera that recently died on me.
          its hardwired to 115v po115v outlet. One evening it simply died. After some troubleshooting (ensuring it had power and ensuring the electronics were actually functional by supplying 5v via usb port) i realized the power supply must be the issue. The supply was noticably warm to the touch even though it was not powering anything.
          Trying to understand what i was up against i went looking for others with similar issues and anyone who might have attempted a repair. While a few ppl have had the...
          07-01-2024, 06:54 AM
        • Cookybaby
          Samsung UN60ES6500FXZA Power Supply Issue
          by Cookybaby
          Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
          I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
          Make: Samsung
          Model: UN60ES6500FXZA
          Power Supply P/N: BN44-00525A
          Symptoms: The TV was...
          08-20-2023, 12:26 PM
        • alltvrepairs
          Philips 50PUS8555/12 Power supply fault
          by alltvrepairs
          715ga018-p01-006-003s
          Am trying to find a pdf .
          i have no secondary output voltage. So far done the obvious checked supply on primary caps 320v, supply on power supply ic found 22v and cannot see any burnt components.
          tried with meter most components like resistors diodes etc.
          in secondary there are no shorts either.
          This was struck by a lightning and could see a burn under the air gap capacitor.
          Attaching the board.
          Any clues welcome.
          Tks...
          08-30-2025, 08:42 AM
