Riddle me this: iMac DV
  • MD Willington
    • Sep 2004
    • 702
    Picked up an iMac DV 400 (graphite with DVD) for $10 USD, works fine with the external monitor, but that takes up too much room.
    Most of the stuff I've read online if FUD or WAG's, some elude to the "analog board", shorted flyback transformer... pram battery...
    Well anyway whatever it is the display is totally hosed, the screen comes up the wrong color, its mushed and the picture looks like a smudged pastel work of art..
    Any of you guys ever fix one of these... It's a neat little system and I'd like to get it working...
    Thanks guys/gals!
    MD
    Ya'll think us folk from the country's real funny-like, dontcha?
    The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Riddle me this: iMac DV
    a picture is worth a thousand words.
    just fixed 2 monitor related issus on imacs.1 was solder joints on the crt socket board.
    other was a weak crt.
    • MD Willington
      • Sep 2004
      • 702
      I'll try to get a picture of it ASAP.. one thing I did spy is a large KMM cap on the analog board, it has a vinyl disc on the top that is slightly bulged, but I've seen the plastic tops on large caps like that before with the cap's can flat underneath... but maybe it's a possibility. Those things get kind of warm inside.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        gently push on the top.
        if its just the plastic puckered a bit it will push down easily.if its hard the cap is bulging.
        bet you have a dead crt.not that big of a deal if you can do minor circut mods so you can set bias/drive when you are done.
        • MD Willington
          • Sep 2004
          • 702
          I read a post where an Apple Tech (not sure what thats worth all they do is swap parts) was trying to get the machine to work with the internal monitor unplugged and an external monitor plugged into the vga port. The device would absolutely not post unless the defective CRT was still attached to the system... not exactly sure what he did though to try it.
          • MD Willington
            • Sep 2004
            • 702
            Sorry for not getting a picture of the monitor, quite busy at the moment.
            • MD Willington
              • Sep 2004
              • 702
              Okay no picture but this happens:
              Brightness and contrast at factory cause huge saturation, I have to peg them back to a dar sort of greenscale image.
              Pincussion is hosed, I can get the left side straight but the left side is still convex outward, same thing happens going the other way.
              • arneson
                • Sep 2005
                • 1267
                Horizontal damper diode can do this. It may be descrete right under the output or it may be built in.
                A lot of times If the high voltage section gets whacked, it is recomended to replace many of the components in the area that could have been stressed.
                Jim
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  i doubt the damper is causing the geometry issue.
                  it could still be in the h-out stage though.
                  if you get a big smearout when turning up contrast try checking/adjusting g2/screen.
                  i still vote for a junk crt and maybe corrupted eeprom.
                  • MD Willington
                    • Sep 2004
                    • 702
                    Well, I think I just need to find a nice used LCD and not worry about the CRT...
                    • arneson
                      • Sep 2005
                      • 1267
                      $10, can't cry about that.
                      Jim
                      • MD Willington
                        • Sep 2004
                        • 702
                        Nope.. it has both OS9 and OSx on it too!
                        • ryogadan78
                          iMac A1418 - No LED, no power after overvoltage on Ethernet port
                          by ryogadan78
                          Hi guys, I need your help again.
                          I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
                          When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
                          06-10-2025, 03:49 AM
                        • Stephen
                          iMac M1 DFU restore issue
                          by Stephen
                          iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
                          this is the message it gives me with the error
                          Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
                          Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
                          03-07-2025, 12:19 PM
                        • Stephen
                          iMac 27” 2020 Boot issue
                          by Stephen
                          Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
                          08-16-2024, 09:32 AM
                        • tommy97
                          iMac Pro 2017 A1862 SSD Upgrade & Recovery mode
                          by tommy97
                          we've got iMac Pro 2017 which having a problem with SSD, iMac come with 2 SSD's 1TB, it was having a problem with the SSD so we get the replacement, installed in and iMac is stuck in recovery mode, tried to restore it & revive, nothing worked - error 4010. After installing old drives now we're having the same problem that the device is in recovery mode. Previously after swap of the SSD iMac worked on the old SSD however after attempt of revive on the new SSD machine stuck in recovery mode, I can go to DFU but the same result with error 4010.
                          Any ideas what might've...
                          04-20-2024, 04:48 AM
                        • howardc64
                          by howardc64
                          Problem
                          08-04-2024, 10:36 PM
