Re: Dell 2007FPB teardown
If it's so cheap, sure. You can actually use the whole replacement board, if it's sold as working.
Half of the computer problems is caused by bad contacts
. Luckily i tried to perform the continuity test and luckily it beeped so no short circuits and Flex is ok. Also I tried Continuity test on 3A Fuse, It also seems to be blown out. With your Attacked Clear picture, I now have the Resistor codes. Will buy new resistors and then replace them . Thanks Again, I was really searching for an image for the resistor codes. everywhere they are covered with white glue.
