Dell E173fpf - No led coming on
  • quattro alex
    • Mar 2012
    • 92
    Re: Dell E173fpf - No led coming on
    OK I ordered a SG6841 and it arrived this morning. I've started desoldering the old one using (Weller WHS40) flux and braid but I can't seem to get the chip off. I've tried with a chisel tip ~2mm wide set at 300c and also a pointed tip . I've tried to solder on a wire to help me lift one side but this didn't work.
    I've even tried a copper strand around the legs to pull gently whilst desoldering, but now a small section of this is stuck to the heel of the legs. Any suggestions how I can get this chip off?
    Fixed so far: GNR TS902W monitor, Sony Game Gear, Philips FCD565, Arcam Alpha 10, Memorex SA 404amp
    • retiredcaps
      • Apr 2010
      • 9271
      Wow, that was quick. BEFORE installing the new one, can you do the same resistance checks on new IC "out of circuit" to see if GND is shorted to the other pins? I'm particulary interested in pin 6.
      For desoldering, try
      http://www.infidigm.net/articles/solder/#desoldering
      --- begin sig file ---
      --- end sig file ---
      • quattro alex
        • Mar 2012
        • 92
        Current SMPS in circuit
        1-2 = 78.2K
        1-3 = 30K-->130K+
        1-4 = 26K
        1-5 = open
        1-6 = 41ohm
        1-7 = 90ohm --> open
        1-8 = 172ohm -->open[/QUOTE]
        New SMPS out of circuit
        1-2 =79.2k
        1-3 = 190ohm --> open
        1-4 = 190ohm --> open
        1-5 = 148ohm --> open
        1-6 = 130ohm --> open
        1-7 = 110ohm --> open
        1-8 = 166ohm --> open
        Cheers I'll give this a go once you've checked over these values
        • retiredcaps
          • Apr 2010
          • 9271
          1-6 = 41ohm
          Okay, so I did some soldering today, but used my little PC fan to blow away the fumes. However, I still could be affected.
          If the new IC pin 1-6 is infinite resistance, then that implies that the old IC is definitely shorted. Once you remove the old IC, measure it out of circuit to verify. It should read the same unless you damage it during removal.
          • quattro alex
            • Mar 2012
            • 92
            Thanks retiredcaps I will give this a go in the morning. Hope the fumes wear off soon!
              "1-6 = 130ohm --> open" What does it mean? 130 Ohms one way with the probe, and open when you reverse the probe, just try to figure out the reading.
              • retiredcaps
                • Apr 2010
                • 9271
                #27
                My guess is that he has 2 second per update speed multimeter and it takes a while to get the "correct" ohms reading.
                For retiredcaps' bonus points, post a picture of your multimeter.
                • quattro alex
                  • Mar 2012
                  • 92
                  When I put the leads onto the pins it gave me 130ohms initially and then about 1-2 secs later it went to open.
                  Ok so this is the title of the DMM that I used: Laser 3534 Multi Meter/temp Tester - Digital
                  I also have a more advanced multi meter Sealey TA 202 - I haven't tended to use this as there were concerns over it's accuracy which came about when I didn't know much about testing capacitance. Basically I used it on a live (hot) cap and now it doesn't read capacitance, also I am not entirely convinced of the DC voltage readings - these jump up and down a lot. I am going to post it on here at some point. Anyway the resistance readings seem to be ok here they are:
                  New SMPS (out of circuit): Current SMPS(in circuit)
                  1-2 78.5k 0
                  1-3 34.72Mohm 0
                  1-4 11.90Mohm 0
                  1-5 11.86Mohm 11.78Mohm
                  1-6 11.70Mohm 47.4ohm
                  1-7 15.20Mohm 239.3k
                  1-8 92.2K 93.4k
                  Pins 1-2 to 1-4 I believe are 0 resistance because I have a small copper wire which is contacting all the pins on this side when I tried to remove this from the board.
                  • quattro alex
                    • Mar 2012
                    • 92
                    This technique worked well and I removed the copper strand, but I am not sure how much heat went into the chip (it wasn't smoking). Old chip out of circuit values as follows:
                    1-2 80k
                    1-3 0.476Mohm
                    1-4 1.606Mohm
                    1-5 11.28Mohm
                    1-6 11.09Mohm
                    1-7 13.90Mohm
                    1-8 96K
                    Here's a close up of U850's location and the pads - I may need to clean some of those pads up a bit more? Use pointed tip for this?
                    • quattro alex
                      • Mar 2012
                      • 92
                      Ok so I've got the new SMPS at U850 soldered in and now there is no ticking, but also no led lit up. C857 gives a more consistent voltage across it ~12 -~14v . C854 is sitting happily at 340v dc.
                      Next I put the inductor (L853) back in and tested - no ticking
                      Lastly put the resistor (R870) leg back in, tested - now its ticking like before.
                      Throughout the testing the board has not been connected to the chassis or the screen, would this make a difference?
                        Ok, R870 is the fusible resistor which is used to supply the voltage to the logic board, that is why the LED does not light up. So the logic board is drawing too much current so it the power supply goes into shutdown again, the inductor is for the ground return for the inverter circuits.
                        Now we need to find out where the shorted circuits are in the logic board section.
                        You do not need to hook up the ribbon cable to the LCD panel, but you should have the lamps connected to the board.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #32
                          One retiredcaps' bonus point awarded for the picture. The Laser 3534 is a rebadged version of some generic brand multimeter.
                          http://handsun.en.made-in-china.com/...-HM-838L-.html
                          I also have a more advanced multi meter Sealey TA 202. I am going to post it on here at some point.
                          Start a new thread for that one in
                          "Test Equipment Usage, Techniques, and Reviews"
                          and I'll try to help out.
                          I have some more suggestions, but need to run off now. To be continued unless you find the problem before I get back.
                          • quattro alex
                            • Mar 2012
                            • 92
                            Am I right in thinking that the logic components are right side of the Resistor I lifted the leg on?
                            Thanks i'll give this a go.
                            Thanks for all your help so far - I feel like I am learning a lot already. Once I've got this one fixed I have my old Philips monitor to fix (2 secs to black issue)
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              #34
                              Correct.
                              Suggestions.
                              1) Check U801, U802, and U851 for shorts. For U801 and U802, you can do a simple resistance check between all 3 pins to see if they are shorted. Measure the resistance between pins 1-2, 1-3, and 2-3.
                              2) For U851, find its datasheet and measure the resistance between each pin and GND.
                              3) See if D857 is shorted.
                              4) Check Q501, Q502, D303, D304, D305, D306.
                              5) Check D854 and D855 (back on power board).
                              6) If none of the above are obviously shorted, I have another list.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #35
                                Start a new thread for the Philips, but to give you a head start
                                2 seconds to black can be
                                a) bad caps
                                b) bad ccfls
                                c) bad ccfl wiring (especially the return wiring)
                                d) bad secondary windings on the inverter transformer
                                More details starting with post #19 at
                                https://www.badcaps.net/forum/showthread.php?t=10419
                                Also, see budm's Inverter tester using old CFL
                                https://www.badcaps.net/forum/showthread.php?t=19987
                                • quattro alex
                                  • Mar 2012
                                  • 92
                                  U801
                                  1-2 0.960K
                                  1-3 0.964K
                                  2-3 2.106K
                                  U802
                                  1-2 0.382K
                                  1-3 0.960K
                                  2-3 1.344K
                                  U851 aka AC '1506-50'
                                  GND= pin 3
                                  3-1 2.1ohm
                                  3-2 0.972K
                                  3-4 0.970K
                                  3-5 0.000
                                  D857 (MM48 K34) - Diode mode = 0.53v one way reversed = 0.134v
                                  Q501 (A1AE27)
                                  G-D O.L
                                  D-S 0.920Mohm
                                  G-S 0.466K
                                  Q502 (W1A)
                                  B-E 19.40Mohm
                                  B-C 19.30Mohm
                                  E-C 0.830K
                                  Q201 (W1A1 4d)
                                  B-E O.L
                                  B-C 17.76Mohm
                                  E-C O.L
                                  Q202 (W1A1 4d)
                                  B-E O.L
                                  B-C 12.38
                                  E-C O.L
                                  D854
                                  1-2 0.00
                                  1-3 0.00
                                  2-3 0.00
                                  D855 (43A) Diode mode
                                  Test 1 w/ Sealey TA202 DMM
                                  0.664v correct way
                                  0.785v reversed
                                  Test 2 w/ Laser DMM
                                  777 correct way
                                  O.L reversed
                                    The D854 does not make sense:
                                    "D854
                                    1-2 0.00
                                    1-3 0.00
                                    2-3 0.00"
                                    It is showing all shorted, but you indicated that you do get the output DC voltage with the load disconnected, then the inverter is connected back, the voltage is still OK, but when the resistor for the Logic board is connected to the power supply output, the power supply would go into ticking mode again.
                                    This D854 is the main rectifier Diode with common Cathode (2 Diode in one package).
                                    • quattro alex
                                      • Mar 2012
                                      • 92
                                      Hi Budm - when I tested the original D854 SRF10-10 it also showed as shorted on all pins. Is something in circuit causing this. I was also quite careful when soldering in the new one as these are more sensitive to heat than caps?
                                      The other thing I am wondering is the original had a plastic body whereas the replacement has a metal back and it's code is MBR10100CT. Is this replacement wrong?
                                      • selldoor
                                        Slow Learner
                                        • 7870
                                        #39
                                        0.664v correct way
                                        0.785v reversed
                                        Test 2 w/ Laser DMM
                                        777 correct way
                                        O.L reversed
                                        I dont think the Sealey can be trusted? - try it again using resistance 2000ohms - not diode test.
                                        Also retest The D854 make sure you get down to metal and there is not a coating of burnt flux.
                                          The MBR10100CT is not isolated tab, the metal tab is connected to the common Cathode which is the output side of the rectifier, the heat sink is connected to ground, so basically you short out the winding of the transformer with the Diodes! Please remove it. I should have asked if you replaced wit the same P/N.
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • master3112
                                            by master3112
                                            07-29-2025, 01:55 PM
                                          • F R 2568
                                            Dell Latitude 5420 does not start (no post) need help to find the reason why
                                            by F R 2568
                                            Hello all,
                                            this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                            I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                            If the laptop is only connected to the AC adapter (battery removed):
                                            When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                            The power/battery...
                                            01-08-2025, 05:45 AM
                                          • nimbus2000
                                            Dell Optiplex 7040 MT ,saw smoke coming out
                                            by nimbus2000
                                            Dell Optiplex 7040 MT (Service Tag S/N DSNJ992)
                                            Built a PC on this used motherboard(DELL MIQ170R Swordfish DDR4 MT 14057-1). At first, when I plug in power cable(without even pushing start button) fans immediately start working at normal speed then after 4-5 seconds it starts working at full speed and stays that way until you manually turn it off by holding power button. While fans are working nothing shows up on screen.
                                            Also tried turning it on without CPU and RAM. Acts same. As soon as power cable is plugged in fans working at normal speed then goes to full speed after a while......
                                            02-23-2023, 10:52 PM
                                          • diamon
                                            Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                            by diamon
                                            I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                            Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                            Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                            Pictures of these boards:
                                            Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                            Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                            Dell...
                                            02-28-2024, 12:51 PM
