hp w1907
  • larryjones
    laptopguy
    • May 2012
    • 7
    • united states
    hp w1907
    hp w1907 would not power on,replaced the 16v 470uf cap because it was leaking,but the one i ordered was smaller in size.Will the smaller one work for me?
  • Jasgriff
    • Feb 2012
    • 578
    Re: hp w1907
    Sometimes other brands might be thinner but taller. As long as you have the correct capacitance and voltage then you should be ok.
    What make did you order?
    Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
    How to resize your pictures guide click HERE
    Retiredcaps Ideal post example click HERE
    • larryjones
      laptopguy
      • May 2012
      • 7
      • united states
      Re: hp w1907
      rubycon the one that was pulled out was a su'scon
      • mariushm
        • May 2011
        • 3799
        Re: hp w1907
        What series of Rubycon?
        As with any manufacturer, they produce various series, some more general purpose and not really recommended for power supplies...
        • larryjones
          laptopguy
          • May 2012
          • 7
          • united states
          Re: hp w1907
          ok i installed the rubycon and it powered up but picture is destorted with no black
          • mariushm
            • May 2011
            • 3799
            Re: hp w1907
            You might have other capacitors going bad but not yet swollen or visibly bad. Also, the cable that connects the video board to the LCD might be improperly attached.
            Check it, and post pictures with the boards as clear as possible if you can.
            • larryjones
              laptopguy
              • May 2012
              • 7
              • united states
              Re: hp w1907
              cap i relpaced
                Re: hp w1907
                Originally posted by larryjones
                cap i relpaced
                What series of Rubycon capacitor did you use? For example, you get Rubycon ZL(H/G/J) and YXF/G which are good for an LCD monitor. But you also get Rubycon YK, for example, which is -not- suitable.
                • larryjones
                  laptopguy
                  • May 2012
                  • 7
                  • united states
                  Re: hp w1907
                  my bad the new one was a Nichicon HN 16v 470uF and just replaced the one beside the first one and the picture is getting better, now to replace the third one as shown in the picture
                  • larryjones
                    laptopguy
                    • May 2012
                    • 7
                    • united states
                    Re: hp w1907
                    powers good, works great, one issue,when a black screen is shown,it more red than black.any clues anyone
                    • selldoor
                      Slow Learner
                      • 7870
                      Re: hp w1907
                      Check again the cable from video board to panel and also whatever cable to connect to the pc - check for bent broken pins - try a different cable
                      • larryjones
                        laptopguy
                        • May 2012
                        • 7
                        • united states
                        Re: hp w1907
                        thank you ill try that
                        • HappyBob
                          • 3
                          Re: hp w1907
                          Hi Larry,
                          How did your repair of the HP 1907W monitor turn out? Last you reported you had backlight but color issues.
                          • Rtech
                            • Jul 2010
                            • 1095
                            Re: hp w1907
                            One of the most infuriating things on the Forum,is for people to devote their time and expertise on trying to help, and then the OP goes AWOL(Absent Without Leave) so to speak,and so Posts like this don't have any closure,and nobody knows what happened next.The greatest thing on the Forum,is for people to get help,successfully repair their Monitors,and say 'ITS WORKING AGAIN'.
                            The HP 1907 does have Backlight problems,usually associated with the top set of lamps,due to poor soldering and not good quality wire used on the return wires.Sometimes a failing Lamp can give a Pink screen and needs replacing,BUT if the Black Screen is more Crimson than Pink,then the only time I have seen this,was caused by faulty capacitors on the Logic Board.
                            Suggest you outline the fault symptoms you have,What happens with the Power Lamp ??is there an Image on the Screen etc etc, and I am sure you will get help.
                            • bulkchart32
                              i think i accidently ordered non-polarized 10uf caps for my original xbox. will this cause a problem?
                              by bulkchart32
                              i ordered a lot of caps from digikey to repair my xboxs. one thing i ordered was 50NXA10MEFC5X11-ND caps and i think they are not polarized. will this cause any kind of a problem? i really don't want to order new caps just because of this.
                              06-16-2025, 03:09 AM
                            • kingiii
                              downloaded bios is smaller than the original bios dump
                              by kingiii
                              Can someone help me explain how to fix the original bios when downloaded and exacted bios is much smaller than the original one?
                              Thank you very much
                              06-07-2025, 04:21 PM
                            • myavocation
                              Pioneer SP-SB23W soundbar: no audio-out fix
                              by myavocation
                              This post is specific to the Pioneer SP-SB23W, also known as the "Andrew Jones Edition" soundbar. Andrew Jones being well known in the audiophile engineering industry for superb audio designs. My reason for stating this is if you are looking for an inexpensive 2.1 channel TV soundbar, this one rivals many 5.1 systems -- and without littering a room with speakers (sub-woofer is wireless, can be hidden anywhere). As a 9 year old device, they should be pretty cheap on the used market -- perhaps dirt cheap if no audio-out. Bought mine off of Craigslist cheap.
                              So here's the...
                              01-29-2022, 07:42 PM
                            • AJ847.63e
                              LGA 1700 Socket Replacement Tips & Tricks
                              by AJ847.63e
                              Hi All,
                              Just wanted to see if I can get some advice on techniques and equipment I should use to try replace the socket on a Gigabyte H610M h v2ddr4 I have.
                              I was planning on using a heat mat I have that's used for phone, tablet screens, as a base heater than use hot air with a square nozzle on top. Yes I should get a proper preheater but I'm not in the position to go spend 300+ bucks on something I will use every 6 months if I'm lucky. Next expense I need to get is a decent programmer like the RT809H but again it would get used infrequently so hard to justify.
                              07-24-2025, 06:57 PM
                            • nobbnobb1
                              Cheap Aliexpress Capacitor: Much smaller than original. Safe to use?
                              by nobbnobb1
                              I am trying to get a set of Creative T40 computer speakers to work again of which I believe the problem is bad caps (470uF @ 35V). So I get a generic set off Aliexpress. The brands are meaningless, but if anyone cares it's a "Chongx"
                              When they arrive, to my surprise it's much smaller than the originals. These are 8mm x 15mm whereas the OE is 10mm x 20mm. Unfortunately my meter does not test capacitance but I'm guessing there's no way this meets spec at 80% the size.
                              ​​​​​​Thoughts? Is it still worthwhile or safe to try and install these to see if...
                              04-19-2024, 04:31 PM
