Crt might be overheating
  • NormanSaxon86
    • Mar 2012
    • 64
    I have a Monitor problem that some here know about. I was reading and found that my Crt might be overheating because it is to close to the tower and dest shelf.
    So I have the back off on my CRT and it is working fine. I think the are flow is better.
    Any mod or idea so I can use my back cast on my CRT without it overheating my Flyback.
    Thanks for everyones help
    Re: Crt might be overheating
    I think the least of your concerns is your CRT overheating. The flyback will be fine.
    • NormanSaxon86
      • Mar 2012
      • 64
      Share with me then. It seems to be the only problem I have found.
      • Krankshaft
        • Jan 2007
        • 2328
        What is occurring on the CRT leading you to believe something is wrong?
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          @Krankshaft - as Tom66 says above there are problems! Unfortunately there are 3/4
          threads all for the same monitor so you would need to read them all.
          • 999999999
            • Sep 2006
            • 774
            Yeah, way too little info presented. If you want some mod to combat heat, on the PCB there are some ICs which probably use somewhere in the range of 5VDC. Trace the power supply pin for that to determine if it's robust enough for a couple hundred mA more power and if so, tap into that and wire a fan to it, using a saw to cut a hole in the monitor cabinet to mount it for better ventilation.
            If locating and determining a power rail suitable is beyond your willingness, remotely power the fan with a separate PSU.
            • NormanSaxon86
              • Mar 2012
              • 64
              Well my monitor runs great out of the plastic back. But when I put the monitor together it would get hot and then turn off. I looked at the board and I can see some burns or heat discoloring, IDK. I think that the monitor should have a better vented case.
              • NormanSaxon86
                • Mar 2012
                • 64
                Yes thanks for the help, I when and did everything everyone posted, but it seems that my board was getting hot near the flyback and I had bad solder joints.
                This thread I wanted to start because I would like to stop my monitor from over heating. I think it runs better out of the plastic weird enough so I plan on research monitor cooling.
                • NormanSaxon86
                  • Mar 2012
                  • 64
                  That sounds cool have you ever seen a monitor with it own cooling system or would the power it takes to run the system make more heat then it is cooling down.
                  I had bad solder joint but the only time my screen would cut out is if I have the back plastic on. When I took the back plastic off everything would run fine.
                  I still get like a green yellow haze over the screen I am not sure why other then bad joint. Could it be damage from the discolored board?
                  • 999999999
                    • Sep 2006
                    • 774
                    A bad solder joint will tend to get worse over time. I recommend resoldering anything suspect, and maybe you don't need a fan at all, only to drill a few vent holes on the top and near the bottom of the casing.
                    The power used for a fan would be negligible, you should expect at least a 10C to 20C drop in temperature if not more, depending on fan size and RPM.
                    However, I have to wonder how old this monitor is and how much time it's worth... decent CRT monitors haven't been sold for consumer applications in many years, it might be ready to die of old age soon so the time modding it is wasted, plus LCD monitors (esp LED backlit) use so much less power that they may come near paying for themselves over a few years of use.
                    • NormanSaxon86
                      • Mar 2012
                      • 64
                      I re-soldered every joint that did not have a shine. The bottom of my board looks mint. I am going to hold off on the fan and holes for now, I hope it runs normal from now on.
                      My monitor is getting old I use it on my back room system. I have a big screen Sony lcd also. I want to wait for 3D monitors to come down and work the bugs out. My CRT has clear picture most of the time I can't see putting up my money yet when I need to pay off loans.
                      • popeye
                        • May 2011
                        • 155
                        "I still get like a green yellow haze over the screen"
                        If the crt is a phew years old that cast is because it is low emission two things you can do apart from new crt is have someone boost the crt with dynoscan or short out the heater coil on the tube base it will last a little bit longer but really needs replacing.
                        • tony359
                          Faulty CRT AKF12/Philips CM8500: bad flyback?
                          by tony359
                          I have a CRT (Acorn AKF12, based on the 240V version of the Philips CM8500) which has stopped working. It's making a high pitched noise but not too high. I know this is symptom of a faulty flyback.
                          What happens when a flyback fails? I see that the main voltages out of the PSU are not reaching rated values, as if there is a short.
                          There are supposed to be 125V/26.5V/15.5V outputs but I am reading something like 48V, 10V and 8V. If I unplug the PSU from the rest of the PCB, I can measure the expected values.
                          Can it be a short somewhere...
                          08-22-2023, 04:39 PM
                        • Ven
                          Dell Latitude 3510 Overheating & Fan Control Issue – Need Help
                          by Ven
                          Dell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
                          Issue Description:
                          1. CPU Overheating to 100°C
                            • When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.​
                            • When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
                            • However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
                            • I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
                            • Thermal
                          02-12-2025, 03:57 PM
                        • Nagyesz
                          Dell inspiron 13 5000 - Doesn't turn on, overheating
                          by Nagyesz
                          I have a Dell laptop with me, a DELL inspiron 13 5379. It doesn't turn on. After some investigation, I found that the charger is delivering 0-3V instead of 19.5V, and this voltage fluctuates constantly. Additionally, two ICs are overheating. I searched for these ICs, and it seems they are likely related to the issue of not having 19V.
                          Should I inject voltage somewhere, or should I replace the ICs right away?
                          So, PU4301 is overheating, and the surrounding area is hot, possibly just because of this IC.
                          07-13-2024, 11:27 AM
                        • retrotechrestoration
                          Looking for a flyback transformer for an Eizo TX-C7 MA-791 17" CRT
                          by retrotechrestoration
                          I just saved this magnificent RGB input Eizo Flexscan TX-C7 MA-791 from the local e-waste...good news, the tube works and the board looks great...the bad news, it sounds like the flyback is shorted. (Turns on...perfect picture...systemic high voltage crackling heard while the picture flickers...then it blows the 5A fuse in my isolated A/C power supply.)
                          Anyone have any leads on possibly finding a replacement? (photo shows the flyback model numbers)​...
                          03-22-2024, 06:50 AM
                        • Tomylee
                          Nintendo 2DS XL – Orange light, no blue light, signs of overheating
                          by Tomylee
                          Hi everyone, I have a Nintendo 2DS XL that shows the orange charging light when plugged in, but nothing happens when I press the power button — no blue light, no screen, no sound.
                          Here's what I've observed:
                          All ribbon cables are properly connected
                          Battery is present and in good condition
                          No reaction even with screens disconnected
                          There's a visible burn mark / overheating sign on the metal shield, right above the CPU
                          I’m suspecting an issue with the CPU, PMIC, NAND, or a power...
                          06-26-2025, 02:33 PM
