DELL 2007wfp - 2 Secs to black w/flickering
  • Armandorf
    • Mar 2012
    • 27
    • Argentina
    Re: DELL 2007wfp - 2 Secs to black w/flickering
    4001Rxxxxxxxx is the type i need? i have wasted so many time, at least i ve learned
    • selldoor
      Slow Learner
      • 7870
      Are you sure it measures as OPEN and not as 0.00. we are only expecting it to be less than 1 ohm so meter should be on ohms20 or less.
      What do the primaries on the old one measure
      Can you unsolder it again and post pics of the bottom of both the old and new.
      align them with the positioning pin at the same end.
      I also notice there is some damage to the cap - does it just extend to the outer plastic?
      • Armandorf
        • Mar 2012
        • 27
        • Argentina
        yes the damage is only in the cover, i did it when i removed the old transformer that had an open winding, i dont have a good transformer out of the board, but i can desolder one of the other two original transformers.
        comparing readings in the board without desoldering:
        1st original 0.03ohm
        2nd original(middle)0.04ohm
        3st new open, infinite resistance
        i believe the originals have 0.8ohm in each winding becuase:
        middle pins are joined in the board. i suppose that the board is putting the 2 resistances(p1 to p3 and p2 to p4)in paralel, giving half the original resistance value for each winding)
        anyway i think i will be desoldering it to check for sure
        • Mac Nut
          • Mar 2011
          • 11
          • US
          Originally posted by Armandorf
          3rd transf
          1-8 resistance: 1.040 K
          4-5 resistance: 52.3 K(200K scale)
          Interesting... I have a 2007wfpb that's doing the same thing. ...and the same transformer is bad. I wonder if there was some sort of error in the design or if this is purely a chance happening?
          T801:
          1-8:1076Ω
          4-5:1089Ω
          T802:
          1-8:1089Ω
          4-5:1095Ω
          T803:
          1-8:No reading
          4-5:1078Ω
          • Mac Nut
            • Mar 2011
            • 11
            • US
            I have been doing some searching using google and I'm not finding any transformers that mach the 4001r714050 exactly, should this 4001K do the trick? Or is the 15K resistance enough different that it would cause problems?
            • selldoor
              Slow Learner
              • 7870
              #26
              Unless your meter is broken there is no such thing as "No Reading".
              I think that the 1500 resistance would trigger a shutdown but it may depend on the circuitry - the primary also seems different.
              Perhaps update your profile with country and voltage.Someone near you may
              have a spare?
              • Armandorf
                • Mar 2012
                • 27
                • Argentina
                #27
                Im moving my stuff to other place so till tuesday im stuck.
                later I will desolder the new transformer
                at first I thought that a faulty ccfll overcharged the transformer with that ccfl. but they glow. probably is the inverter only.
                finding an inverter board complete can be the solution.
                • Mac Nut
                  • Mar 2011
                  • 11
                  • US
                  #28
                  Then I must be doing something wrong... I'll fiddle around with it some more today. Line and locale info updated btw
                    If your meter reading doesn't change from not having the probes touching, then I would consider that "No Reading".
                    • Mac Nut
                      • Mar 2011
                      • 11
                      • US
                      #30
                      Right. My meter's default reading with the probes not touching is "1" on the left side, and nothing changes when I test those pins. I'm assuming that means the connection is open, yes?
                        Yep... that's open. Try testing on 2M range (or 20M or 200M if your meter has it), but it's definitely failed.
                        • Mac Nut
                          • Mar 2011
                          • 11
                          • US
                          #32
                          Yep, not a single reading from 200 to 2000K
                            It's dead, Jim!
                            • Mac Nut
                              • Mar 2011
                              • 11
                              • US
                              #34
                              Well, now we have two people that need these units. I wish my Google-fu was better for this sort of thing, but I can't find any trace of the 4001R transformers anywhere. ...Of course Google probably ain't the best place to looks for specific electronics components, but I don't know where is.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #35
                                Re 4001R
                                https://www.badcaps.net/forum/showpo...59&postcount=9
                                --- begin sig file ---
                                --- end sig file ---
                                • Mac Nut
                                  • Mar 2011
                                  • 11
                                  • US
                                  #36
                                  I shall search this man out.
                                  • LAS
                                    • Sep 2011
                                    • 144
                                    Hi Mac Nut - I will send you a PM.
                                    • LAS
                                      • Sep 2011
                                      • 144
                                      Mac Nut - is this the one?
                                      • selldoor
                                        Slow Learner
                                        • 7870
                                        #39
                                        That is the same as Armandorf's board 20$US at shopjimmy.
                                        • LAS
                                          • Sep 2011
                                          • 144
                                          This is the board that came out of my 2007wfp that had a terminal problem with the video board.
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • Chivo77
                                            DELL LATITUDE 5420, ST 20TFKN3, LA-K491P REV:2.0 (A01) powers on and die about 15 secs later, no video
                                            by Chivo77
                                            hello friends, I have a DELL LATITUDE 5420---MODEL P137G, ST 20TFKN3 LA-K491P REV:2.0 (A01) and its quite a challenge. It powers on with the battery disconnected, lasts on for about 15 secs, and then shuts off. It does the same with battery only (no adapter). With battery and adapter it sometimes starts after hitting the button several times. It displays nothing in every case. Since only the Boardview is available, I guided myself with schematics similar to this laptop (I'll add them down).Some measurements:
                                            1- After receiving power SIO_SLP_S0# goes high and never changes.
                                            2-every...
                                            07-03-2025, 09:20 AM
                                          • Akhlz001
                                            by Akhlz001
                                            09-20-2025, 07:15 PM
                                          • Shobos
                                            Dell E6420 XFR Rugged starts to boot but after 3 secs shuts down.
                                            by Shobos
                                            Hi, I bought 6420 XFR that tries to boot but shuts down after about 3 seconds, CPU gets warm, fan starts.
                                            So far I have tested all rails wich are good, BIOS flashed with CH341, 3.3,5, main rail present. multiple ram sticks tested. Sometimes it might stay on for longer like 4-5 seconds but not always, theres no picture whatsoever. Also on some rare occasions the caps lock flashes 1 time by itself.
                                            NOTE: I am using bench power supply not dell charger with ID pin and NO battery present, kinda doubtful this would cause this issue.
                                            Any help is welcome. Thanks !
                                            07-29-2025, 03:53 PM
                                          • master3112
                                            by master3112
                                            07-29-2025, 01:55 PM
