Repairing a FujitsuSiemens LSL3230T
  • DMCrimson
    • Feb 2012
    • 58
    • Finland
    Re: Repairing a FujitsuSiemens LSL3230T
    Well, I find it hard to believe those diodes were faulty after all - replaced them, plugged in, listened to chirping for a while and re-measured those 4 diodes with similar results. Any more ideas? Or should I just go and get a replacement unit if there's one available on eBay...
    There was mention about startup cap - also that it rarely goes bad.
    • retiredcaps
      • Apr 2010
      • 9271
      Did you measure the diodes as I asked in post #18. Did you measure them out of circuit to verify?
      --- begin sig file ---
      --- end sig file ---
      • DMCrimson
        • Feb 2012
        • 58
        • Finland
        Nope, I should've done that though. If we start from assumtion that the diodes are indeed broken (again), what would you suggest is busting them?
        • DMCrimson
          • Feb 2012
          • 58
          • Finland
          Now, that startup cap - would it be C803 (that yellow rectangular) MPXGMF40/100/21 metal film cap?
          • Scenic
            o.O
            • Sep 2007
            • 2642
            Nope. The startup cap is normally a 35-50V 22-47uF electrolytic (somewhere in that range usually).
            From the pic of the PSU board in the first post, I'd say the startup cap is C806 (right below the optoisolator and above the little PCB that sticks up)
            • DMCrimson
              • Feb 2012
              • 58
              • Finland
              #26
              C806 is 10uF 100V and it's been swapped already...
              • DMCrimson
                • Feb 2012
                • 58
                • Finland
                #27
                I'm beginning to wonder if the transformer itself is faulty - it has markings as follows:
                Code:
                SPW-134 A
                E140167
                LSE-B3 0839F3
                clicking/ticking might be due to failing insulation, so if I was to replace it, what are the specs? Search over the net yielded nada.
                • DMCrimson
                  • Feb 2012
                  • 58
                  • Finland
                  #28
                  A month with no ideas... I'm thinking of sourcing a new PSU board.
                  Regarding that PSU, I'm wondering if I could use a different board - as long as the connectors are the same?
                  Oh, on other thread, Rusty informed me that the cap is 50V 10uF, but the one I have is 100V - would that matter?
                  • DMCrimson
                    • Feb 2012
                    • 58
                    • Finland
                    #29
                    Managed to find a 50V 10uF cap, will need to try that tonight.
                    • DMCrimson
                      • Feb 2012
                      • 58
                      • Finland
                      #30
                      Swapping that cap for a known good one didn't work out - the transformer still ticks. Could the resin inside it be failing?
                      • killian6pk
                        • Apr 2010
                        • 502
                        Take ohms readings on the transformer. Pin 1 to Pin2; Pin 1 to Pin 3 etc. Until you have all the combinations of pin 1. Then start with Pin 2 and do the same and then on to Pin 3 etc. Number them any way you want. Just report back what readings you got. Remember power off.
                        Have you ever stopped to think and then forget to start thinking again?
                        As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
                        • DMCrimson
                          • Feb 2012
                          • 58
                          • Finland
                          #32
                          Primary side (AC) has 4 pins
                          measurements:
                          1-2: 0,2 ohm
                          1-3: ~5 Mohm
                          1-4: ~5 Mohm
                          2-3: ~5 Mohm
                          2-4: ~5 Mohm
                          3-4: 0 ohm
                          secondary side has 6 pins, but can be treated as 3 pins as they're soldered in groups of two:
                          zero all around.
                          • DMCrimson
                            • Feb 2012
                            • 58
                            • Finland
                            #33
                            Could it be the feedback via opto? My neighbour told me the monitor ceased working all of sudden with no warning at all.
                            • wc_robot
                              • Aug 2012
                              did you ever figure this out? I have the same problem on a Dell 21" LCD monitor, and the power board is almost identical to yours... same board number E131175 on the front, slightly different layout, few minor changes (e.g. 100uF 450V cap instead of 120uf 450V). I also tried replacing some components I suspected failing (the big cap, a few diodes on the AC high voltage side, etc), no luck.
                              Most significantly, when powered, mine is also clicking (about 100 times per second). I'm almost certain it's the yellow LSE-B3 transformer. When power is removed, it clicks at a rate directly related to the voltage in the large cap as it drops--slower and slower over about 10s while the big cap goes from fully charged (mine only gets to 164V) to empty. Due to the weird frequency of the clicking, I'm suspecting one of the smaller caps is charging up then the transformer shorts internally, and that cycle repeats.
                              My windings on side 2 are the same -- 0 ohms.
                              As for the 4 pins on side 1, i also get 0 ohms on 3-4, and 0.2 ohms on 1-2, but for all your ~5 Mohm values I have 148 Kohm
                              Let me know if you've solved your problem yet & how. If I can find a suitable replacement for this T, I'll try it out. Thanks!
                              • Rtech
                                • Jul 2010
                                • 1095
                                #35
                                The integrity of this transformer,not this Model,but where it is in the circuit, has been questioned a number of times,NOT just for this board,but in many different ones.As far as I know none have been found faulty,and as yet after working on over 400 Monitors,I have yet to see one go faulty !!!.I have no schematic for this,but I suppose it will be pretty standard,and the secondary feeds Schottky diodes ??,and I would certainly take them out of the Board,a) to test them,and b)to power on with them out and see if the symptoms change.
                                I also suppose that there is a Mosfet fed by a SMPS chip,and if necessary I would also take that out,and this may help to check it :-
                                http://www.4qdtec.com/mostest.html
                                • DMCrimson
                                  • Feb 2012
                                  • 58
                                  • Finland
                                  #36
                                  Thanks Rtech. I'll need to check the diodes (did you mean those 1N4148's I already changed?) and the mosfet - thanks for pointers
                                  wc_robot: There's an ongoing auction @ ebay, which has suitable board - I think that might be for you: http://www.ebay.com/itm/Hannspree-HF...8&cmd=ViewItem as the seller will only ship to states.
                                  • DMCrimson
                                    • Feb 2012
                                    • 58
                                    • Finland
                                    #37
                                    Oh: would you tell the model of Dell monitor you have?
                                    • Rtech
                                      • Jul 2010
                                      • 1095
                                      #38
                                      The Schottky Diode, maybe more than 1, are NOT the 4148s, but will be mounted on a Heatsink, and it is probably the one nearest the Transformer.They are usually 3 leg devices,and the secondary of the Transformer will normally go directly to the outside pins on the device.
                                      • DMCrimson
                                        • Feb 2012
                                        • 58
                                        • Finland
                                        #39
                                        Rtech: I've measured them earlier onboard, post #17, but will redo.
                                        • Rtech
                                          • Jul 2010
                                          • 1095
                                          #40
                                          If they measured well, then take them out and then power on as suggested earlier and see what you get ref the clicking.
                                          • osrex
                                            LED DRIVER KEEPS DYING
                                            by osrex
                                            Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
                                            i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
                                            i have no datasheet at all for the LED lights, all i have is its length.
                                            long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
                                            as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
                                            05-05-2025, 03:36 PM
                                          • howardc64
                                            Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                                            by howardc64
                                            Problem
                                            Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                                            Model & Board Pics
                                            Conflicting Spec
                                            Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                                            https://www.shopjimmy.com/vizio-gj-2k1...
                                            10-10-2024, 01:16 PM
                                          • charif
                                            Audio Driver for Thomson P14C4BK128
                                            by charif
                                            Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
                                            I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
                                            The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
                                            Here are the details:
                                            • Model: Thomson P14C4BK128
                                            • Operating System: Windows 10 64-bit
                                            If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
                                            Thanks in advance for your help!
                                            04-30-2025, 05:41 PM
                                          • bohaboha
                                            how to install gl usb2.0 uvc camera device driver on windows 10
                                            by bohaboha
                                            Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
                                            but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
                                            any help?
                                            01-26-2025, 08:33 PM
                                          • Daveleone
                                            UN55D6900 BN44-00428B partial led driver circuit failure
                                            by Daveleone
                                            Hello TV experts! I have a UN55D6900. The successfully TV turns on, and the backlights light up, and I get a picture, but there is a section that is dim. I took it apart and 1 out of 4 segments of backlight LEDs are not lighting on both sides of the TV (in other words, the same segment is out on both LED strips).
                                            I tested the LED strips with my LED tester and all of the LEDs light properly, so I believe the problem is with the PSU/LED driver board (BN44-00428B). The voltages at CNM810 (between PSU and main board) look ok to me. The voltages at CNL801A and CNL801B look off for one...
                                            07-23-2021, 06:31 PM
