Hp 1940 flicker
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    #41
    Re: Hp 1940 flicker
    So far so good then- whilst budm has referred to the grey caps and his knowledge is far superior to mine, it is the first time I have noticed anyone make that suggestion. Unless you have an esr meter or cap tester I dont think you can test them, you can look for bulges or leakage, but I have never known anyone replace this type of caps.
    Heat is a monitor killer so additional ventilation will certainly do no harm.
      Re: Hp 1940 flicker
      Please read this thread about the tuning caps used in Royer Oscillator circuits:
      https://www.badcaps.net/forum/showthread.php?t=19878
      As Jasgriff found out after damaged new transistors he had replaced.
      • Hunt
        • Jun 2009
        • 31
        #43
        Re: Hp 1940 flicker
        There is a comment somewhere that people have fitted fans to monitors.
        Is there a suitable place on the monitor to pull 12v or even 9v (make less noise) DC to run a fan off?
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          #44
          Re: Hp 1940 flicker
          I am sure there are places where you can pull 12 v or even 5v off the power supply but wonder if it would be too much for it. I would suggest a usb powered fan run off the pc as your not likeley to have one on without the other. If you dont want to tie up a usb you could run 12 v or 5v off a molex
          connector inside the pc
          • Hunt
            • Jun 2009
            • 31
            #45
            Re: Hp 1940 flicker
            Originally posted by Hunt
            Well it has been nearly a week since I re-soldered all the underside joints in the area of the four transformers and near all the discoloured section of the board.
            No flickering yet and I believe the use of the monitor is reprehensive of when it was faulty.
            My only concern now is the comment above about... "Also check the two rectangular body gray caps for value and leakage otherwise you may blow up your transistors."
            How do I test for the above?
            I'm also wondering if drilling more holes in the metal cover of the same size (finger safe) as already exist but on the adjacent side to aid cooling?
            Then putting more finger safe holes in the plastic back cover?
            Thanks for your help so far people.
            I have fully reassembled the repaired monitor and have used it in a three-monitor system now for a week or more and I am very pleased with the results.
            I have not added a fan. However, I have provided more cooling holes to the metal case and to the plastic back cover.
            Pictures attached.
            P.S. As I write this, I'm sure the monitor made a click. Any ideas what this could be?
            • ratedK
              • Dec 2012
              • 21
              Re: Hp 1940 flicker
              I opened up my HP L1940T expecting to find a bad cap but it was nowhere to be found, everything I could test read as it should. Thank you badcaps
              Simply refreshing the solder joints worked like a charm. My board didn't indicate BenQ, but the same solution worked for me just the same.
              https://www.badcaps.net/forum/images/smilies/fruit.gif
              Since I have a pair for dual screen setup I'm thankful that I didn't have to replace two screens. Most Awesome.
              • Hunt
                • Jun 2009
                • 31
                #47
                Re: Hp 1940 flicker
                My HP 1940 lasted till now with only the odd flicker perhaps once a week. I just went blank and came back up ok.
                Now though it has a constant flicker with the green light going on and off.
                I have done a re-solder just in case it was a simple problem again but it has made no difference so I think the monitor has had its day.
                3 years extra life is very good thanks to this forum
                Problem is they do not seem make the old format monitors now.
                Of to see what is available secondhand...
                  • 31214
                  Re: Hp 1940 flicker
                  you give up to easy!
                  see if it powers up with the cfl tubes unplugged.
                  these HP's overdrive the tubes - i'v had one with one of the lamps cracked from heat.
                  • fixit007
                    Samsung flicker - BN44-00932T board or else?
                    by fixit007
                    I picked up this TV that the prior owner said - just died.
                    Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
                    Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
                    Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
                    05-04-2024, 06:14 PM
                  • howardc64
                    UN65TU7000 strobing / flicker
                    by howardc64
                    Good picture but has ~200Hz+ faint flicker/strobing over entire screen. Also has a single green vertical line. Can mask out t-con signals (2pins) to stop flicker/strobing but 1/12 of screen will be all colorful vertical lines (single green vertical line is in this section)
                    Since can mask t-con signal to disable part of the screen and stop flicker/strobing. Obviously not backlight.
                    Panel has 4x driver boards each responsible for 1/4 of the screen. 3 tabs on each board. Each tab responsible for 1/12 of the screen. the 2 outer most tabs has additional horizontal gate control...
                    03-26-2023, 04:37 PM
                  • sgcampion
                    Asus rog strix scar 17 G733QR display Issue(flicker, black/white))
                    by sgcampion
                    My Asus laptop started flickering from time to time and more and more in last months. First the screen was going black but sometimes if I moved the screen it would work again, other times I needed to plug/unplug the laptop or close and open the lid to make it work again.
                    In last days I see that if I move the laptop lid to about 45 degrees it will flicker or get white or black screen(it's random, sometimes white sometimes flickers etc). I was trying to troubleshoot it myself but seems like it's either the cable or the display....
                    10-24-2023, 09:39 AM
                  • russianbar
                    SONY KD-65XE7002 Screen Flicker
                    by russianbar
                    This isn't my video but it's a fair representation of the fault I have, starts with slight screen flicker as the set warms up which happens every 5 seconds or so that gets more regular until more or less constant https://www.youtube.com/watch?v=Un8cAjUtOvA was thinking T-Con but open to any other ideas as seems to be quite a common fault on these
                    04-10-2025, 03:11 PM
                  • TechGeek
                    How To Stop CRT Flicker
                    by TechGeek
                    [PART 1 OF 2]
                    Ever gotten a CRT monitor and noticed an irritating flicker?
                    Here's how to get rid of it (or at least make it far less annoying).
                    Method 1: Increase Refresh Rate
                    1) Get to your display settings. This varies from OS to OS.
                    For Windows (95 to 2000, XP to 7 with Icons Mode, XP to 7 with Classic Start Menu
                    (NOT Classic Start))
                    1) Open the Start Menu
                    (For 95 to 2000 and XP to 7 with Classic Start Menu)
                    Click "All Programs", then "Accessories", then "Control...
                    12-14-2019, 09:05 PM
