Viewsonic VX2255WMB Grey Screen
    Hey I just found an old broken monitor that a friend of mine gave to me awhile ago. I wanted to try to see if it is possible to repair it. I'm new to monitor repairing and I've been reading up on them for the past couple of days. The problem with my monitor is that, I would turn it on and the blue power light turns on. The screen turns on shortly after with a grey screen for 3 seconds and would then shut off and the blue power light turns red.
    I've disassembled the monitor down to the logic board and I've check the capacitors and they seem to look fine (no blown capacitors) so I still do not know the problem. I have very small and basic knowledge of circuits but any help would be appeciated! Thanks
    http://img.photobucket.com/albums/v7...e/DSC09742.jpg
    http://img.photobucket.com/albums/v7...e/DSC09743.jpg
    http://img.photobucket.com/albums/v7...e/DSC09744.jpg
    http://img.photobucket.com/albums/v7...e/DSC09745.jpg
    http://img.photobucket.com/albums/v7...e/DSC09746.jpg
    Heres a couple of pictures, if you need any higher quality photos of anything just ask!
    Re: Viewsonic VX2255WMB Grey Screen
    Attach the pictures using 'Manage Attachments' - below the text entry area.
    PlainBill
      I've been trying to upload them but it keeps giving me, "Your submission could not be processed because a security token was missing."
        Follow my sig file instructions below exactly.
        --- begin sig file ---
        --- end sig file ---
          PlainBill
          attached
            Okay i got it, here are higher quality pictures.
              U7 and U10 are voltage regulators on the main/logic board.
              Measure all 3 pins (ignore the fat tab). List the part number as well for each regulator. Report it like
              U7
              AL1117-33
              pin 1 = 0.0V DC
              pin 2 = 3.29V DC
              pin 3 = 5.01V DC
                Okay im a bit new at this, but how do i measure the pins, where do i put the probes?
                  Usually black probe on a mounting screw (ground) and the red probe on each pin (leg). Be careful not to "slip" and touch something else while measuring.
                    i just noticed that the middle pin of the U7 regulator happens to be unconnected. Is this just how it is designed or would it be the defect?
                    I took the measurements of U7 and U10
                    U7
                    L1117LG-1.8 2A6831A96
                    pin 1 - 3 i measured 0V for all
                    U10
                    50117 K-G 63836
                    pin 1 = 0V
                    pin 2 = 0V
                    pin 3 = 0.014V (and dropping)
                      By design.
                      U7
                      U10
                      50117 K-G 63836
                      pin 1 = 0V
                      pin 2 = 0V
                      Hmm, all 0.0V.
                      On the power board, measure the DC voltage of each connector pin that connects the power and logic board. Use a ground screw on the power board for your black probe. Report your findings.
                        I'm I suppose to measure this pins while it is plugged in?
                          Did you measure the voltage regulators with power on? It has to be with power on.
                          Yes, you need to measure all the pins with power on.
                            U10
                            pin 1 = 0V
                            pin 2 = 1.88V
                            pin 3 = 3.3V
                            U7
                            50117 K-G 63836
                            pin 1 = 0V
                            pin 2 = 3.3V
                            pin 3 = 4.86V
                              Those readings look good. I'm dead tired and exhausted so I may not be thinking clearly, but see if you have 2 seconds to black. It is explained in posts #19 and #20 at
                              https://www.badcaps.net/forum/showthread.php?t=10419
                              tiredcaps - off to bed
                                Funny it seems that I find a post with the same monitor I am working on as of now! So I guess its been worked on before and I found its past history.
                                https://www.badcaps.net/forum/showth...ight=VX2255WMB
                                I don't think i have 2 seconds to black, as i cannot see any images after the white screen shuts off.
                                  What should i look for specifically?
                                    Let's verify something from an earlier post. You mentioned a 'White' or 'Gray' screen that went away when the power LED turns red. What happens if it's hooked up to a computer?
                                    The problem sounds like a bad connection to the LCD panel, a problem with the panel board (TCON), or a problem with the GPU.
                                    PlainBill
                                      I have the sAme results when plugged in my computer. My computer is able to recognize the device (the little usb input sound) but it would not change any symptoms.
                                        Originally posted by retiredcaps View Post
                                        By design.
                                        Hmm, all 0.0V.
                                        You still need to do this and list findings
                                        Also
                                        WITH POWER OFF and unplugged for 5 minutes test the secondary windings on the inverter transformer - see post no 20 in the 2 sec to black guide mentioned above.
