LG Flatron W1934S, 2 sec to black issue
  • senndogg
    • Dec 2011
    • 383
    • Albania
    Hello to everybody and welcome to my first post. i am an electronics amateur and i find this forum very useful, used it very often, like an unknown user, but today i have to post my problem.
    i used the search button regarding my topic but nothing relevant came.
    i followed the "2 sec to black" bible, but im a bit stuck.
    the monitor is a LG 19" wide. the backlight goes off after 2 secs. it is reccaped, tried new ccfl but the problem persists. i followed also the pdf service manual but im stuck at the "instantaneously pulse wave on pin1, pin3, pin15 of IC501 at the moment of restart". i get 5Volts and 14.7 volts at most of the power caps.
    thank you.
  • alexanna
    • Mar 2010
    • 1346
    Re: LG Flatron W1934S, 2 sec to black issue
    When you substituted CCFLs,
    Were you able to use 2 known good bulbs? And did you have all the connectors on the inverter populated with a CCFL?
    • senndogg
      • Dec 2011
      • 383
      • Albania
      yes. it was taken from a working Samsung. just the same problem. but i used only one bulb.
      • alexanna
        • Mar 2010
        • 1346
        I possible try to use 2 known good CCFs.
        It is possible to have more than one bad CCFL
        • senndogg
          • Dec 2011
          • 383
          • Albania
          when i made the test i disconnected the two CCFLs and tested the two inverters with the known good working samsung ccfl.
          thanks for the reply but i dont have many monitor related gadgets in my small garage. i can put my hands on my own green ccfl pc case light decoration, but it has other kinds of connectors.
          • senndogg
            • Dec 2011
            • 383
            • Albania
            after doing some searches in this forum, i must question: if the hot circuit is open, the transformer senses a fault and shuts off, right? so if the CCFL is faulty or improper the "2sec to black" will still occur?
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              Hi did you search "W1934S" there are other members who have had similar problems with this monitor?
              • alexanna
                • Mar 2010
                • 1346
                Yes.
                On the great majority of monitors, if the inverter detects an open circuit or notices excessive voltage the inverter circuit will shut down to try to prevent damage. That is what we call 2 second to black.So one or more missing CCFLs can cause the inverter to shut down.
                There are many things that can cause a 2 second to black problem.
                Some of the common ones,
                Bad capacitors
                Inverter transformer resistance problem
                CCFLs and are their wiring.
                • senndogg
                  • Dec 2011
                  • 383
                  • Albania
                  thank you, today i will try 2 original brand new CCFLs. i suspect that the upper one has defective wiring.
                  • senndogg
                    • Dec 2011
                    • 383
                    • Albania
                    thanx to everyone, specially to alexanna and selldoor, for this fantastic forum.
                    my problem is resolved, a wiring failure in the upper CCFL
                    By senndogg at 2011-12-27
                    i changed the wiring, soldered it, plugged and everything OK!
                    thank you guys! you're awesome!
                    • zeusbv
                      • Feb 2012
                      Originally posted by alexanna
                      Yes.
                      Bad capacitors
                      i have the same problem but the display and ccfl are on for 2 sec then the ccfl are of and the lcd remains on
                      can I measure the ccfl ?
                      • alexanna
                        • Mar 2010
                        • 1346
                        On some it is possible to measure the return lines, and if a bad CCFL is present a difference in voltage can sometimes be noticed.
                        However I am not willing, or unable to go into that at the moment.
                        I recently fractured a vertebra in my lower back, so I a am about worthless as ---- on a boar hog!
                        If the capacitors do not show any bulging, and are not on the problem [Replace on sight list].
                        And you have verified that the secondary windings in the inverter coils are within the 3% range. It's time to either substituting known good CCFLs, are open up the LCD for a visual on the bulbs.
                        • senndogg
                          • Dec 2011
                          • 383
                          • Albania
                          i wish you get well soon alexanna.
                          • Behemot
                            • 4845
                            • CZ
                            This stinks guys. Got exactly the same 2 secs, changed first transformer, changed second transformer, still the same problem. ATM running with CCFLs from 22'' display just fien so the problem is here. Very interesting is that I now got 8 transformers, several of them with resistance around 615 ohm, several around 930 and some around 940 ohm…WTF? do doubts it goes bad with „tollerances“ like this…you have to manualy pick up the closest ones.
                            Anyway, it is way too suspicious that two different monitors show the same CCFL soldering problem. Some planned obsolescence? Or Inolux has SO bad manufacturing quality?
                            ADD// yes, it was bad joint, there was some discharge between the wire and the CCFL going on
                            • wizard13
                              Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                              by wizard13
                              I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                              I have checked the forum and the available documentation but could not find a solution specific to my issue.
                              • Brand & Model: Dynabook Satellite Pro C50D-B-100
                              • Part Number (P/N): PYU13E-00C00PFR
                              • Serial Number (S/N): 22028896H
                              • System Configuration (SC): A1PYU13E1127
                              • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                              • Power Input: DC 19V –
                              02-28-2025, 02:43 AM
                            • Ancient1
                              Strange LG TV issue : Image vertical lines in black screen
                              by Ancient1
                              Hi
                              Asking for a friend.
                              I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
                              but here its the opposite !
                              TV has new T-con = same issue
                              A missing panel voltage would have global effect
                              So , what should one do ? how can I find where the fault is ?
                              Thanks !...
                              02-05-2025, 03:37 PM
                            • ChIck3n
                              Dell u2311h 20000 seconds to black issue
                              by ChIck3n
                              So I've had this monitor for probably a decade now, and it's finally starting to fail. Began with a little sporadic flickering, then eventually started going black (power LED stays blue, can still see image on screen with flashlight). A power on/off fixes it for a bit, but then it happens again. Once it got to the point I was dealing with this every few minutes, I opened it up and just replaced all the caps (minus the big one) on the power board with new Panasonic ones. All the old caps tested fine on an ESR meter, and this worked for 5 days. But the screen just went black again today, so...
                              09-09-2024, 11:44 AM
                            • Stephen
                              MacBook Pro 13" 2017 A1708 Black screen issue (not flexgate)
                              by Stephen
                              This is not a flexgate issue.
                              The lcd turns on and functions fully and fine. When installing or even attempting to install an OS the screen goes black and doesn't turn on. We swapped the LCD with a testing LCD (that works) and it too is also black. After the computer cools down it turns back on and show the screen again and then it goes black when it gets hot. Sounds like a CPU issue to me (since these do not have their own dedicated GPU) but I may be wrong. Has anyone experienced this with this model? Battery is good btw. also I disconnected the battery and it still does the...
                              06-10-2021, 09:09 AM
                            • sgcampion
                              Asus rog strix scar 17 G733QR display Issue(flicker, black/white))
                              by sgcampion
                              My Asus laptop started flickering from time to time and more and more in last months. First the screen was going black but sometimes if I moved the screen it would work again, other times I needed to plug/unplug the laptop or close and open the lid to make it work again.
                              In last days I see that if I move the laptop lid to about 45 degrees it will flicker or get white or black screen(it's random, sometimes white sometimes flickers etc). I was trying to troubleshoot it myself but seems like it's either the cable or the display....
                              10-24-2023, 09:39 AM
