[Samsung SyncMaster 713BM] No display and blinking power light.
  • XP1
    XP1
    • Dec 2011
    I have an LCD monitor, Samsung SyncMaster 713BM-S (Silver), that does not display anything. When I turn it on, the green power light flashes continuously.
    I took it apart (getting the plastic panel off was the most difficult; have to use a flat screwdriver and slowly pry the side latches outwards).
    I see one bulging Samxon capacitor [1000 uF, 25 v, U8A, 105°C8, GF(M)] on the power supply.
    Can anyone infer if this is a power supply capacitor problem, or is it something else?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: [Samsung SyncMaster 713BM] No display and blinking power light.
    1) Capacitors (C designation on the PCB board) die from age, heat, and shoddy build quality. Capacitors DO NOT have to be visibly bloated in order to bad. They can be out of tolerance uF (a 1000uF measures 20uF) and/or have high ESR (ohm). A multimeter will be insufficient to test for ESR. For that you need an ESR tester which costs between $50 and $300.
    Most members here will recommend that you replace ALL capacitors with reputable brands from reputable sellers. Brands like Rubycon, Panasonic, and United Chemicon are suggested. A list of recommended caps can be found at
    https://www.badcaps.net/forum/showthread.php?t=2280
    2) One bad cap is enough to stop the lcd from working. Samxon GF series is a problematic series so I suggest replacing them ALL.
    3) Here is an example on how to find suitable replacements ...
    https://www.badcaps.net/forum/showpo...4&postcount=19
    --- begin sig file ---
    --- end sig file ---
    • XP1
      XP1
      • Dec 2011
      Thanks.
      I found the Samxon GF datasheet here:
      https://cdn.badcaps-static.com/pdfs/...f9651347cb.pdf
      I will get a Blue ESR tester.
      • JRyan
        Samsung TV UN60J620DAF blinking power light
        by JRyan
        Saved this TV from the trash but it will not power on the red power indicator light blinks 6 times with no display. I've attached pics of the power board(1st pic) and mainboard(2nd pic). I don't see any blown caps on pb like I expected so what do y'all think is the issue?...
        09-03-2023, 07:56 PM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • huzo
        HP 470 G5 blinking amber light no power
        by huzo
        The board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
        So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
        I've tried flashing the bios...
        interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V...
        06-08-2023, 04:08 PM
      • ipatch
        troubleshooting microsoft surface pro 4 no power no led charge light
        by ipatch
        hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
        10-05-2023, 11:59 AM
      • russpall
        LG 39ln540v - red light flashes twice, no power to LED driver?
        by russpall
        Hi there,
        I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
        The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
        08-27-2024, 01:07 PM
