Okay so, how do you identify CCFLs?
  • roothorick
    • Aug 2011
    • 5
    We've got a bunch of KDS monitors with the CCFLs going out -- two of them have bit it entirely and the other four are looking rather worse for the wear. My game plan is to recap the inverter section, replace the CCFLs and call it a day. At least, it was, until I noticed that CCFL diameters differ by fractions of a millimeter
    Seriously? How the hell am I supposed to measure that? Or do these tubes usually have their size written on them somewhere?
    The monitor model number is K-6MWB. The back of the panel bears the name "PROVIEW TECHNOLOGY COMPANY LIMITED" and both a model no "PV156WLCM" and a product no "M156B1-P01". If anyone just so happens to know the right CCFL size, throw me a bone.
  • jetadm123
    • 2169
    Re: Okay so, how do you identify CCFLs?
    If you're dealing with "fractions of a mm" diameter wise, then your best bet would be to visit ccflwarehouse.com. Usually, it's the length of the ccfl that holds people up and not the diameter. Call them as they are very helpful and can provide a recommendation. However, I think that since these are 15" monitors, it's probably not cost effective to replace the ccfl's and caps, not to mention the fact that they're probably at the end of life anyway.
    • retiredcaps
      • Apr 2010
      • 9271
      Note that ccflwarehouse sells "bare" ccfls and "pre harnessed". Pre harnessed is way easier to install, but costs more.
      Replacing ccfl tubes requires a lot of patience and delicate handling. See their tutorial at
      http://www.ccflwarehouse.com/lasotu.html
      --- begin sig file ---
      --- end sig file ---
      • roothorick
        • Aug 2011
        • 5
        New monitors would be $90 a crack. They're not that hard to take apart and I could do a full capkit on this monitor board in about oh, thirty minutes maybe? I'm slick with a soldering iron. And end of life? These were bought brand new at the end of 2008. I expect a useful life of AT LEAST a few years after the warranty runs out.
        • jayoung
          • May 2011
          • 172
          ccflwarehouse.com sells ccfl's through their website and also through e-Bay under the seller name of plazmo_industries. I ordered from them just recently. If you follow their directions when you purchase the ccfl's, they request the following - the make and model of your monitor, the diagonal measurement of your screen, and the horizontal measurement of your screen. I actually disassembled the monitor and measured the length and diameter of the actual ccfl's. I measured the length with a ruler and the diameter with digital calipers.
          In terms of the cost through the e-Bay sale - they are about $8 each with $4.99 shipping for the first one (free for additional). If there are 4 ccfl's that are going to be replaced along with the capacitors, the repair could run about $40 for each of them plus your time. The following is the e-Bay sale that I used.
          http://www.ebay.com/itm/250474949765...fvi%3D1&_rdc=1
          • alexanna
            • Mar 2010
            • 1346
            From what i understand when you measure the length of the CCFLs,measure just the glass part.If there is just a couple of MM difference in lengths go with the smaller measurement.
            ccflwarehouse shows an illustration on measurements here
            • jetadm123
              • 2169
              After 3 years, it doesn't suprise me that the the caps have gone bad. And yes, just re-capping the power supply would be low cost. However, since the ccfl's are also failing after only 3 years, then it would make sense that all 4 ccfl's be replaced. Since it sounds like these are your workplace monitors, now you have to include your labor rate, which I'm guessing is not free. It's 30 min to replace the caps, but how long will it take you to replace the ccfl's? I'm sure the total will still be less than $90, but how much less?
              • retiredcaps
                • Apr 2010
                • 9271
                Are these monitors on 24/7?
                Do they have brightness and contrast set at 90/75 respectively?
                • ttmi100x
                  HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                  by ttmi100x
                  Greetings everyone,
                  I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                  The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                  Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                  Upon closer inspection...
                  07-31-2024, 06:36 PM
                • mikey5791
                  Help on Samsung Syncmaster T220 dead ccfl lamp
                  by mikey5791
                  This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
                  Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
                  10-18-2020, 03:17 AM
                • thesame
                  DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                  by thesame
                  Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                  The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                  02-27-2024, 04:31 AM
                • silver60618
                  Lenovo Legion 7 - Help Identify IC
                  by silver60618
                  Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
                  I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
                  Any help would be appreciated...
                  07-02-2025, 12:16 PM
                • chth96
                  How can I identify varistor which have been blew up?
                  by chth96
                  I mistakely pluged 100v japanese retro game console to 220v outlet.
                  So It seems that glass fuse and varistor have been blew up.
                  I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                  Is there any way to identify varistor type in my sega saturn PSU?
                  Any reply would be appreciated.
                  EDIT:
                  It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                  11-26-2023, 08:52 AM
