Hey guys, I have this 2005fpw it powers on and the power lights stay on. It says there is no input. I have tried it on other pcs with other cables and still nothing. I took it apart and found a few burn marks on the circuit board and the back of the display. the two burn marks on the back of the display are from contacts from this board.. but it didnt burn the board in those spots but there was some black stuff on those contacts.. the burn on the ciruit board is under the discolored piece.. I dont know what they are? theres 6 of them Could this be fixed?
Dell 2005fpw
Re: Dell 2005fpw
1) Post a picture of the logic/main board (where the DVI/VGA inputs are).
2) Do you have a multimeter?--- begin sig file ---
--- end sig file --- -
--- end sig file ---Comment
Re: Dell 2005fpw
Okay, the pic is a bit blurry, but I count 6 voltage regulators.
1) Put your multimeter on 20 V DC if manual range.
2) Put your black probe on a ground screw (any one on the logic board will do fine).
3) Put your red probe on each voltage regulator pin EXCEPT the big fat tab. If the middle pin is "cut" and not touching the board, we want to measure that pin as well.
4) Report the part number for each regulator.
5) Report all your findings like the following example,
U101 - part number AL1117-33 - pin 1 = 0.00 V, pin 2 = 3.3 V, pin 3 = 5.0 V
6) Post a picture of the entire power/inverter board (not cropped like in post #1)--- begin sig file ---
Re: Dell 2005fpw
Is the screen all white?
If yes, that multicolored connector on the logic board connects to a panel board. The panel board runs the entire length of top of the monitor. There may be an open fuse on that panel board. A good fuse should measure less than 1.0 Ohms.
Alternatively, that connection or cable could be loose and need cleaning or reseating.--- begin sig file ---
Re: Dell 2005fpw
On the power board, there is a CON201 (the connector). It has a legend.
Measure all the DC voltages and report it like the following.
pin 1 - legend says 12V - recorded reading = 11.99 V
pin 2 - legend says 5V - recorded reading = 5.01 V--- begin sig file ---
Re: Dell 2005fpw
U506 - EF3AD 1117AS33 - pin 1 = 0.00 V, pin 2 = 0.00 V, pin 3 = 121.6 mV
U605 - DF3AD 1117AS25 - pin 1 = 0.00 V, pin 2 = 2.47 V, pin 3 = 4.67 V
U606 - BA033 57 92 - pin 1 = 4.95 V, pin 2 = 10 mV, pin 3 = 3.32 V
U607 - DF4AD 1117AS18 - pin 1 = 0.00 V, pin 2 = 1.76 V, pin 3 = 3.30 V
U608 - BA033 57 92 - pin 1 = 4.67 V, pin 2 = 15 mV, pin 3 = 3.31 V
U610 - EF3Ad 1117AS33 - pin 1 = 0.00 V, pin 2 = 3.25 V, pin 3 = 4.94 V
pin 1 - 12v = 11.7 V
pin 2 - 12v = 11.7 V
pin 3 - gnd = 0
pin 4 - gnd = 0
pin 5 - 5v = 4.57 V
pin 6 - 5v = 4.97 V
pin 7 - gnd = 0
pin 8 - 5v = 4.97 V
pin 9 - on/off = 2.80 V
pin 10 - ready = 600 mV
pin 11 - dimm = 170 mVComment
Re: Dell 2005fpw
pin 3 - gnd = 0
pin 4 - gnd = 0
pin 5 - 5v = 4.57 V
pin 6 - 5v = 4.97 V
pin 7 - gnd = 0
pin 8 - 5v = 4.97 V
Re: Dell 2005fpw
yes it will need replacing
yes there are things you can check, but I leave all that to the others who are already helping you
we should have seen that transformer in your first post LOL,
so I went back over your pictures and saw this, and it dont look right
needs checking outComment
I have a Dell E5470 that powers up and boots windows no problem. Using a non-standard universal type charger, it shuts down immediately if moved, (power short in that charger or AC power jack) because the battery has no charge and isn't charging orange/white lights blinking on the front. When first powered up, BIOS power alarm stated that it could not detect the voltage setting and I had to dis-able the message to get past this. It got into Windows fine, as long as not moved, so I dis-assembled it looking for a cold solder joint on the power jack that I thought might be lifting off the MB, but...
by ttmi100xGreetings everyone,
I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
Upon closer inspection...6 Photos-
by F R 2568Hello all,
this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
If the laptop is only connected to the AC adapter (battery removed):
When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
The power/battery... -
by diamonI have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
Pictures of these boards:
Dell Latitude 5520 https://www.ebay.com/itm/256052956663
Dell Latitude 5530 https://www.ebay.com/itm/125844181534
Dell...4 Photos -
by OntarioTLWell I've learned something new today. Of all the Dell laptops I've come across I have never seen bluetooth greyed out, and only to learn this is during the build from Dell factory. I've tried to pull the original BIOS and fix with another dell with the same issue on the forums, however the original was not recovered from the forum upgrade so I cannot do a comparison to attempt the fix on my own.
If someone could help me out with this unit and I'll try the next one as so far I have 2 on my desk with this issue. Thanks in advance!
Dell Lattitude 5410
Service Tag...-
Channel: BIOS Requests ONLY!
- Loading...
