Dell E207WFPc
  • PlainBill
    • Feb 2009
    • 7034
    Re: Dell E207WFPc
    Originally posted by killian6pk
    Here are the readings on the small chip on the right.
    Pin 1 = 0.8mv
    Pin 2 = 3.033v
    Pin 3 = 5.07v
    Hope this helps.
    It could be a reset controller; the voltage is right. Examine the chip carefully - are there any signs of a flaw? Also, using an ohmmeter, see if pin 2 on the small chip is connected to a pin on the GPU - the one with the heat sink on top.
    If it is, and you are very brave (or foolish, depending on the results), you can try shorting pin 2 to pin 1 and see if the monitor works.
    PlainBill
    • killian6pk
      • Apr 2010
      • 502
      Re: Dell E207WFPc
      Are you talking about using the buzzer to see if those two (GPU & small chip) are connected? If not what reading am I looking for on the ohm scale. Also when you say shorting pin 1 & 2 you mean on the small chip I take it?
      Have you ever stopped to think and then forget to start thinking again?
      As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
      • killian6pk
        • Apr 2010
        • 502
        Re: Dell E207WFPc
        I checked the small component the soldering looks ok. The marking on the board says U302 if that helps with the Identity of the chip also I got a stronger magnifier and rechecked the number it is 8910P. I have not been able to find a data sheet on that number. The pin markings (on the board) are with the tab up. First leg is #1 Tab is #2 and the other leg #3. These SMD components are a pain in the rear they are so small. Checked pin #2 (tab) and could not find a connection to the GPU. I also checked pin #1 and #3 and found multiple connections for pin #1 and 1 connection for pin #3
        • PlainBill
          • Feb 2009
          • 7034
          Re: Dell E207WFPc
          Well, the device is definitely not a MAX810 reset controller. I'll be doing a little more research this evening, time permitting.
          PlainBill
          • killian6pk
            • Apr 2010
            • 502
            Re: Dell E207WFPc
            Thanks Bill I really appreciate your help. There are several more of this device you circled on the signal board. What should I be looking for in the way of measurements or lettering on the part to tell if maybe one of them is the reset controller?
            • alexanna
              • Mar 2010
              • 1346
              #86
              Re: Dell E207WFPc
              Sorry about that. I realized about 1:00 am that I had not given the problem.
              The monitor does not power on at all, no light or flicker or anything. I will check the component on the back of the board and get back to you on what I find. Thanks for giving me the info on the front side components.
              If i missed this or it's been answerd I am sorry,
              Do the front panel switch LEDs light up?
              When you push the front panel swicth dose it feel like it's clicking?
              • killian6pk
                • Apr 2010
                • 502
                Re: Dell E207WFPc
                No the PLED does not light up. This monitor has a small ribbon cable that goes into a row of pins on each side. There is a black plastic connector over these pins. Originally I tried to take that connector off. After getting it off two of the pins broke off. I tried replacing them with small gauge wire from a resistor lead. That never seemed to work properly.
                I was able to find a signal card for an E228WFPc which is supposed to be the same card. That card was cheap $15.00 (if it saved the monitor). So I bought it. The first time I connected it up to the power board and the button ribbon cable the PLED lit up. The buttons on the board do click like they are supposed to. I was not able to get a picture on the screen. Just to catch you up I found a Fuse on the TCON board that was bad and replaced it. The screen still did not light up and or no picture.
                Bill has been working through various possible problems. If you have any ideas I would be glad to hear them.
                • alexanna
                  • Mar 2010
                  • 1346
                  #88
                  Re: Dell E207WFPc
                  Connector Label Reads:
                  Black = N/F
                  Open (no wire) = NC
                  Brown = DIM
                  Open = +14v
                  Open = +14v
                  Red = 5v
                  Orange = 5v
                  Yellow = Gnd
                  Green = Gnd
                  Are the pins labeled the same on both of the signal cards?
                  You may also want to re measure these voltages,but use the ground wire in the connector for the DMM ground
                  When you measure the n/f pin do it wile pushing the power button.
                  What voltage are you seeing on the DIM pin?
                  • killian6pk
                    • Apr 2010
                    • 502
                    Re: Dell E207WFPc
                    I will check all of that.
                    • killian6pk
                      • Apr 2010
                      • 502
                      Re: Dell E207WFPc
                      This is what I got reading wise.
                      Pins are labeled the same on both cards
                      All measurements taken new today with power + signal board connected and Front Button Board connected to Signal Board (PLED was on when power button was on)
                      Black = N/F Power Button off = .9mv Power Button On = 3.044v
                      Open (no wire) = NC
                      Brown = DIM Power Button Off = 2.9v Power Button On = 55.1mv
                      Open = 14v No Wire
                      Open = 14v No Wire
                      Red = 5.07v
                      Orange = 5.07v
                      Yellow = Gnd.
                      Green = Gnd.
                      Hope This Helps
                      • alexanna
                        • Mar 2010
                        • 1346
                        #91
                        Re: Dell E207WFPc
                        Open (no wire) = NC
                        Open = 14v No Wire
                        Open = 14v No Wire
                        Red = 5.07v
                        Orange = 5.07v
                        Yellow = Gnd.
                        Green = Gnd.
                        Hope This Helps
                        It just might!
                        Do you have the backlights hooked up?
                        • killian6pk
                          • Apr 2010
                          • 502
                          Re: Dell E207WFPc
                          No but I will try it with them hooked up. What do you want me to look for?
                          • alexanna
                            • Mar 2010
                            • 1346
                            #93
                            Re: Dell E207WFPc
                            Lookthrough the back of the panel,see if they flash or come on.
                            • killian6pk
                              • Apr 2010
                              • 502
                              Re: Dell E207WFPc
                              Hooked it all up and nothing happened. No flash, no PLED and no picture.
                              • alexanna
                                • Mar 2010
                                • 1346
                                #95
                                Re: Dell E207WFPc
                                Have the ribbon cable to the panel disconnected, but still have the back lights hooked up,try it again.
                                Dose the PLED come back on?Dose anything else change?
                                • killian6pk
                                  • Apr 2010
                                  • 502
                                  Re: Dell E207WFPc
                                  Back lights came on and PLED stays lit. The back lights look like they are shaking. I don't think they are going off and on quickly.
                                  • alexanna
                                    • Mar 2010
                                    • 1346
                                    #97
                                    Re: Dell E207WFPc
                                    So there is a problem with the LCD panel shutting at least part of the power off.
                                    Check and see if you caused a short on the Tcon when you replaced the fuse.
                                    • killian6pk
                                      • Apr 2010
                                      • 502
                                      Re: Dell E207WFPc
                                      Ok. Anything could be possible as small as that fuse was. I think I need laser surgery on my 60 year old eyes. Maybe some magnifier implants.
                                      • alexanna
                                        • Mar 2010
                                        • 1346
                                        #99
                                        Re: Dell E207WFPc
                                        You should post a picture of the Tcon,I will not be able to help you to much more with it.
                                        But there are others that have repaired problems with them
                                        • alexanna
                                          • Mar 2010
                                          • 1346
                                          #100
                                          Re: Dell E207WFPc
                                          Yea I know about the 60 year old body parts, The old saying said rode hard and put away wet,Well I did a lot of that in my younger days
                                          • F R 2568
                                            Dell Latitude 5420 does not start (no post) need help to find the reason why
                                            by F R 2568
                                            Hello all,
                                            this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                            I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                            If the laptop is only connected to the AC adapter (battery removed):
                                            When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                            The power/battery...
                                            01-08-2025, 05:45 AM
                                          • diamon
                                            Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                            by diamon
                                            I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                            Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                            Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                            Pictures of these boards:
                                            Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                            Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                            Dell...
                                            02-28-2024, 12:51 PM
                                          • OntarioTL
                                            Dell 5410 greyed out BT
                                            by OntarioTL
                                            Well I've learned something new today. Of all the Dell laptops I've come across I have never seen bluetooth greyed out, and only to learn this is during the build from Dell factory. I've tried to pull the original BIOS and fix with another dell with the same issue on the forums, however the original was not recovered from the forum upgrade so I cannot do a comparison to attempt the fix on my own.
                                            If someone could help me out with this unit and I'll try the next one as so far I have 2 on my desk with this issue. Thanks in advance!
                                            Dell Lattitude 5410
                                            Service Tag...
                                            07-25-2025, 01:28 PM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • lalle-
                                            Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
                                            by lalle-
                                            Hello!
                                            I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
                                            [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
                                            I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
                                            The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
                                            I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
                                            08-11-2024, 02:01 PM
