Dell E207WFPc
  • killian6pk
    • Apr 2010
    • 502
    Re: Dell E207WFPc
    I rechecked the fuse and nothing appears to be shorting. The fuse still reads as good 0.1 ohm so it must be something else on the panel board. I have looked it over thoroughly several times and can't find another fuse. I have an ESR meter would it be worthwhile to check the smd caps. What should I be watching for number wise if I do that?
    Have you ever stopped to think and then forget to start thinking again?
    As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
    • killian6pk
      • Apr 2010
      • 502
      Re: Dell E207WFPc
      Originally posted by alexanna
      You should post a picture of the Tcon,I will not be able to help you to much more with it.
      But there are others that have repaired problems with them
      Sorry for taking so long to reply, but I did not see this post on my computer until just now. The red dot in the first picture is just below where I replaced the fuse. It is the small white smd just out from the first regulator leg.
      • killian6pk
        • Apr 2010
        • 502
        Re: Dell E207WFPc
        Still waiting for some help with this TCon to see if there is anything else I can check in the way of components. Thanks
        • PlainBill
          • Feb 2009
          • 7034
          Re: Dell E207WFPc
          Look to the left of the connector, there is a square 28 pin IC. That is the controller for the dc-dc converter that provides the various voltages the LCD panel requires. You will notice a number of diodes and ceramic capacitors in that area. In particular the higher value ceramic caps are notorious for shorting. There are two approaches to testing these.
          The simpler (but tedious) approach is to set your DMM to the diode test range and check all the diodes in both directions. Then set it to the 200 ohm range and check the resistance across all the caps. I would guess the caps should measure open on the 200 ohm range, but what you are looking for is a cap (or several caps in parallel) that read much lower that the others.
          The quicker approach is to hook everything together, feed in a signal from a computer so the display should be on and start checking voltages across the largest caps. You are looking for ones that have 0 volts across them.
          PlainBill
          • killian6pk
            • Apr 2010
            • 502
            Re: Dell E207WFPc
            Thanks Bill I will get started on this.
            • killian6pk
              • Apr 2010
              • 502
              Re: Dell E207WFPc
              Bill there were 4 Diodes in the area you mentioned. I have marked them with a red dot. The 3 small diodes with legs on diode setting all registered OF. The 1 regular type diode measured .531 one way and .159 the other.
              OF the caps 4 measured 330.8 except one which was 365.0. There were 5 that measured 74.8 - 71.5. The 21 remaining measured OF . I am including the picture with the red dots on the diodes. There are several others that look the same, but are marked with a Q on the board.
              Now I really need one of these:
              • PlainBill
                • Feb 2009
                • 7034
                Re: Dell E207WFPc
                What is the number (marking code) on the three pin diodes (these are probably dual diodes)?
                Are there voltage test points on the other side of the board?
                The readings of 300+ ohms don't bother me, but the readings in the 75 ohm range seem too low.
                PlainBill
                • killian6pk
                  • Apr 2010
                  • 502
                  Re: Dell E207WFPc
                  All the Diodes with legs read LD3.
                  The other side of the board appears to have all test points. I don't see any components on that side.
                  http://www.datasheetarchive.com/SMD%...datasheet.html
                  About 1/3 to 1/2 way down this page is a DataSheet from CYStech the model listed as BAT54SN3 says that it's top marking is LD3.
                  Let me know what I need to do next.
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Re: Dell E207WFPc
                    I'm getting contradictory information; but it's easy to resolve. Googling BAT54SN3 takes me to a CYSTech datasheet that says the marking code is L44. It's easy to resolve, however. A picture of the pinout is attached. With a meter on the diode test scale you should get a voltage drop 1-3 and 3-2. Depending on the circuit and your meter, you may get a reading 1-2.
                    PlainBill
                    • killian6pk
                      • Apr 2010
                      • 502
                      Re: Dell E207WFPc
                      Ok I will check that later on this afternoon. Have to run out for a couple of hours.
                      • killian6pk
                        • Apr 2010
                        • 502
                        Re: Dell E207WFPc
                        This is what I got measuring the Diodes
                        Diode 1
                        Pin 1-3 = .236v
                        Pin 3-2 = .234v
                        Pin 1-2 = .462v
                        Diode 2
                        Pin 1-3 = .244v
                        Pin 3-2 = .234v
                        Pin 1-2 = .464v
                        Diode 3
                        Pin 1-3 = .234v
                        Pin 3-2 = .235v
                        Pin 1-2 = .465v
                        • PlainBill
                          • Feb 2009
                          • 7034
                          Re: Dell E207WFPc
                          Diode 1
                          Pin 1-3 = .236v
                          Pin 3-2 = .234v
                          Pin 1-2 = .462v
                          Diode 2
                          Pin 1-3 = .244v
                          Pin 3-2 = .234v
                          Pin 1-2 = .464v
                          Diode 3
                          Pin 1-3 = .234v
                          Pin 3-2 = .235v
                          Pin 1-2 = .465v
                          OK, the diodes are good, and match the part you indicated.
                          Now we get into something outside my area of expertise. The next logical step would be to hook everything together, hook the monitor to a working computer, and measure the voltages across some of the capacitors, particularly the ones with a very low resistance. Unfortunately, I have only a vague idea of what voltages to expect.
                          PlainBill
                          • killian6pk
                            • Apr 2010
                            • 502
                            Re: Dell E207WFPc
                            I will try that and hope I don't fry myself or the monitor.
                            • killian6pk
                              • Apr 2010
                              • 502
                              Re: Dell E207WFPc
                              I hooked everything up to start taking measurements. First of all I could not get either a DC or AC reading because the DMM kept jumping all over the place. Secondly the back of the TCon board in the area that I was taking measurements in got very very hot so I stopped and turned the power off.
                              • killian6pk
                                • Apr 2010
                                • 502
                                Re: Dell E207WFPc
                                I did some more checking and the attached picture with the 2 red dots is the part getting so hot. It is marked as 3R3. Not sure what to call it to do any checking for a data sheet or anything else. It gets so hot in just a few seconds that you can't touch it. I did a search and this is what I came up with. Looks like the part to me. This parts measures to be the DR73-3R3-R
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  Re: Dell E207WFPc
                                  That is an inductor; itm together with the square chip and the various diodes and caps you have been testing (plus a few more diodes) provides the various voltages the lcd panel requires.
                                  I see two approaches at this time.
                                  1. Remove the caps that showed an unusually low resistance and test them out of circuit. Maybe you will get lucky and find the culprit.
                                  2. Cautiously feel the rest of the components and see if you can find any that are also getting quite hot.
                                  What is the part number of the 'square 28 pin IC'?
                                  PlainBill
                                  • killian6pk
                                    • Apr 2010
                                    • 502
                                    Re: Dell E207WFPc
                                    The part numbers are:
                                    AAT1164C The "T" Could Possibly be an "F"
                                    AG7879
                                    I will check all the components for heat tomorrow before pulling the caps. When I test the caps out of circuit what am I looking for?
                                    • PlainBill
                                      • Feb 2009
                                      • 7034
                                      Re: Dell E207WFPc
                                      AG7879
                                      You are looking for one with a low (around 75 ohms) resistance.
                                      EDIT: I've attached a typical schematic for the power controller. I don't know how relevant this is, but it shows it produces 13.3V, 15V, and -6V. Rather than pulling caps, I'd check for those voltages.
                                      PlainBill
                                      • killian6pk
                                        • Apr 2010
                                        • 502
                                        Re: Dell E207WFPc
                                        I will check these voltages out. Thanks for finding the data.
                                        • killian6pk
                                          • Apr 2010
                                          • 502
                                          Re: Dell E207WFPc
                                          I tried several of the pins for readings, but my DMM was jumping around so much I could not get a reading. The chip and the 3R3 component are both getting so hot you can't touch them with your finger and the same thing applies to the board even through to the back. Is this a short circuit or a bad component? Is one problem related to the other?
                                          • F R 2568
                                            Dell Latitude 5420 does not start (no post) need help to find the reason why
                                            by F R 2568
                                            Hello all,
                                            this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                            I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                            If the laptop is only connected to the AC adapter (battery removed):
                                            When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                            The power/battery...
                                            01-08-2025, 05:45 AM
                                          • diamon
                                            Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                            by diamon
                                            I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                            Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                            Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                            Pictures of these boards:
                                            Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                            Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                            Dell...
                                            02-28-2024, 12:51 PM
                                          • master3112
                                            by master3112
                                            Today, 01:55 PM
                                          • OntarioTL
                                            Dell 5410 greyed out BT
                                            by OntarioTL
                                            Well I've learned something new today. Of all the Dell laptops I've come across I have never seen bluetooth greyed out, and only to learn this is during the build from Dell factory. I've tried to pull the original BIOS and fix with another dell with the same issue on the forums, however the original was not recovered from the forum upgrade so I cannot do a comparison to attempt the fix on my own.
                                            If someone could help me out with this unit and I'll try the next one as so far I have 2 on my desk with this issue. Thanks in advance!
                                            Dell Lattitude 5410
                                            Service Tag...
                                            07-25-2025, 01:28 PM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
