Another Viewsonic VP201 repaired thanks to badcaps forum!
  • vibrolax
    • Sep 2011
    A co-worker gifted me with a broken Viewsonic VP201 LCD display. The power light was green, but nothing appeared on the display. A google search using its model number and "repair" brought me to the badcaps forum thread 95163.
    Upon disassembly I found 1 bulging 680 uF 25V cap and an open F2 fuse. I measured 17.75V from the power supply.
    I ordered a complete cap set and fuses from Mouser.
    Last night I replaced both 680 uF caps (Ltec), and the 150 uF 400V (Taicon) high side cap, as they were the only ones with China/Taiwan origin. I left the Nichicon 22 uF and 47 uF's alone, mostly because I didn't feel like digging them out of the white adhesive goop. Then I replaced the fuse - my first surface mount PCB repair.
    I reinstalled the power supply board, inverter board, and the inverter shield then applied power to the panel. The "No signal" icons appeared - the first sign of success! PSU output voltage was still 17.75V. I reinstalled the main board and power supply shield, then buttoned up the case. Connecting it to the computer confirmed its successful resurrection from the dead.
    Some Mouser part #'s for your convenience:
    576-0466002.NR 63V 2A Littlefuse
    647-UPZ2G151MHD6 400V 150 uF Nichicon aluminum electrolytic cap
    667-EEU-FR1E681 25VDC 680 uF Panasonic aluminum electrolytic cap
    Thank you, badcappers Wrog and PlainBill, for making this an easy fix.
    Jon
  • point5
    • Mar 2012
    • usa
    Re: Another Viewsonic VP201 repaired thanks to badcaps forum!
    Thanks for Posting this with the part numbers, I have a VP201 that powers on for about 10-15 minutes then goes dark. Turn it off for a while to cool down an it comes back to life for a short period. Looks like the culprit is a bulging 150uf 400v cap on the power supply board. The board shows signs of heat (browning) around this cap as well. Hopefully replacing it will solve the problem.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      I dont know your background but would advise care in desoldering in this area.
      The cap can hold a charge of up to 400volts in the us perhaps 260volts.
      If it is faulty it may not discharge correctly.
      • lostone
        Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
        by lostone
        Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
        First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
        When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
        05-19-2024, 11:40 AM
      • chronic519
        Mats / mods: detected and repaired GPU fault. Cant seem to test after!
        by chronic519
        Hello.
        GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
        Found issue with a RAM block
        Replaced, green lines gone.
        Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
        Used a good card to test and same results low errors 32+.
        I am just search for some form of command to do a full test on the GPU.
        I just ran the mats command with my good GPU and passed after roughly 40 min.
        The repaired one, ran...
        05-20-2025, 07:56 PM
      • StefanNg
        Viewsonic VX2718-PC-mhd SG2701B01-8
        by StefanNg
        Hi, Badcaps.
        I am troubleshooting a monitor
        Viewsonic VX2718-PC-mhd.
        Panel model SG2701BSG2701-8
        Symptoms is no image.
        This panel has 2 panel board connected by a U-ribbon.
        When I disconnected the ribbon, I get a perfect half screen image.
        I took some test point voltage, when ribbon disconnected.
        HVAA 8.38v
        FVDD12 1.21v
        FDD33 3.3v
        VIN 11.79v
        VAA 16.85v
        VGHF 30.16v
        VGL -8.02v
        CK1_I ~ CK8_I 1.403v
        CK1_L ~ CK8_L 8.26v
        When I connect both panel board
        HVAA, VGHF, and CKx_L...
        05-17-2025, 01:43 AM
      • Stephen
        A2338 M1 Not turning on - Repaired slightly but still having issues
        by Stephen
        Repaired a customers computer, had a faulty APL 1097 chip and replaced, all well, not shorted anymore, however I am finally getting 12.28Volts on PPBUS_AON, however it stays at 12.28 and doesn't increase to the normal 12.60 Volts. I read that this is the cause
        • If the voltage is approximately 12.28-12.35V, it may indicate a communication issue between the SOC and PMICs, or corrupt firmware.
        ​Can someone point to me what would be the next step to fix this. I can feel we are getting close to fixing this board, however this is a data recovery and we need to fix the computer to recover the data....
        02-26-2024, 02:25 PM
      • gurj1979
        MacBook Pro 820-01987- condensation damage repaired but has sensor issue
        by gurj1979
        Hi guys.
        Got a customer MBP 2020 which has a dad of corrosion from condensation, resulted in no power at all.
        I replaced the corroded components and repaired the traces. Restored power and now Iccan get to login screen.
        But when the CPU gets warm (not hot) and fan gradually starts spinning faster and then MBP turns off. Pressing power button turns it back on for couple of seconds then it turns off again.
        Seems sensor related, but it won't even let me get as far as running the built-in ASD.
        I can get back to you later with the components...
        08-01-2023, 02:38 PM
