Hi guys, I have read, I think, just about every thread re the 2 second problem. Some folks have recapped virtually everything in sight and cured the problem, some have done the same and the problem is still there. Virtually all the symptoms point to the inverter section shutting down. It is doing this because it dosnt like the CCFL's but is it being oversensitive and if so how does replacing the caps cure this?. Without doubt the bad caps are not as "efficient" as they were, and this I guess, means that power supply lines now have excess ripple or noise on them and maybe this increases the chance of the inverter circuitry thinking the CCFL's are flaky. An interesting poster cured the problem by applying en extra decoupling cap directly across the IC responsible for brightness and general inverter operation. Getting to the point then, is it fair to say that the purpose of recapping is really to prevent the inverter from shutting down prematurely on detecting a possibly marginal CCFL that could perhaps last a few more years? I may have missed it but it would be good to see some power rail Oscilloscope pics, of before and after recapping. I have currently a packard Bell Callisto on the bench in pieces awaiting the arrival of new capacitors. The 2 second till dead problem was initailly "fixed" by reducing brilliance levels, but that lasted just a couple of days. Anyway, really interesting and thought provoking stuff on this site..
Two second then Black..What is actually happening?
Re: Two second then Black..What is actually happening?
The Cliff's Notes version of 'Two Seconds to Black is there are multiple possible causes.
You mentioned one - excessive noise on the power supply rails caused by deteriorating filter caps.
A second cause can be an aging CCFL. As they age the current increases; the inverter controller regulates the total current through the CCFLs and monitors the current through each CCFL.
A third cause is a broken CCFL. The inverter controller detects the excess voltage and shuts down.
A broken lead to the CCFL can trip the protection by two methods - if the current is unable to find a path, the voltage will rise and trip the overvoltage protection. If an arc to the metal occurs, the return current for that lamp is lost, so the controller responds by increasing the drive, thus tripping either the over voltage or over current protection.
Another cause is a bad (shorted or open) transformer.
The final cause can be a bad component on the protection circuit - for example, a leaky diode.
Adding a bypass cap at the inverter controller won't really interfere with the protection circuits - rather it prevents a false indication of an error.
The recommended troubleshooting method for 'Two Seconds to Black' is fairly simple.
Look for a reddish hue on the panel when the backlights first come on.
If the capacitors are obviously bad -either bulging, or show excessive ESR with a tester, replace them.
If the caps appear to be good, substitute known good CCFLs for those in the monitor (just hook them up externally).
If test CCFLs are not available, check the resistance of the transformer secondaries.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. -
Thanks Bill, I have seen references to the reddish hue in one of your posts before. Are you saying that that indicates a bad CCFL or one that is about to go that way. The monitor I am working on at present did show that effect some time back but seemed OK after about 10 mins of being switched on.Comment
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
I will toss in another possibility that I ran into once.
it is possible a failing transistor will do the 2 second thing... I recently did a benq made dell with the problem... the following fixed it:
1. resoldering the inverter transformers
2. recapping (it had capxons, so it was a "by default" thing to me)
3. replacing the inverter transistors.
the first two didn't fix it... the third did, but the first and second will help ensure a long term fix (bad transistors is often a symptom not a cause per-se).
every case is different, so good luck!sigpic
(Insert witty quote here)Comment
Thanks for the responses. Some major progress this end. Based on the assumption that the inverter shuts down when it sees excessive CCfL current, I thought about reducing this and at present I have the monitor going again just by inserting some high voltage disk ceramics in SERIES with the CCFL leads. The monitor has been running for about 2 hours now. Nothing gets hot, all seems stable. I will write this up properly if the "fix" seems good after say a few days.Comment
by caseyjay_48I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,... -
by ttmi100xGreetings everyone,
I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
Upon closer inspection...6 Photos-
by x_orange90_xI just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
I don't know how exactly to test the inverter itself. Is it... -
by GentianI have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...03-06-2023, 07:07 AM -
by valvashonFor some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...1 Photo - Loading...
