Hey everybody! Sorry that my first post is a question, but I've recently ran across your forums with an issue that I had with some shotty caps on an old Sapphire video card. I saw your display section here and thought I'd throw this out there. I saw a post from 2010 on this particular issue, and wanted to see if you guys have any suggestions. My ribbon cable to the far side of the display has come loose, causing the display to show the 3" or so set of green vertical lines down the side of the screen. The more I mess with that cable, the worse it gets. I'm wondering how would one go about attaching this cable back? I'm pretty sure it isn't soldered, and there is no plug. It looks like it would be some sort of glue or something sticky to stick it on. I'll post some pics so you all can see what I'm talking about. Thanks for your help in advance, and I hope to lend some help in the future.
Old Dell 2001FP Ribbon Cable
Re: Old Dell 2001FP Ribbon Cable
This issue is usually bad news for the panel - i.e. not repairable. The ribbon cable is soldered at the factory with special equipement.
You may be able to get the TV fixed temporarily by placing something on the ribbon cable to keep pressure on it. But there's no guarantee that this will work, or that if it does it won't appear again if you move or bump the TV. -
I've had a piece of rubber pressed between it and a metal panel on the back. It fixed it for just a few hours, then it suddenly got extremely worse. That is why I took it apart again to find that it is actually loose from the center of the cable all the way over as you can somewhat see in the pictures. Now, I can't get anything with pressure in just the right spots to clear it up. Oh well, I guess I'll look into replacing the entire thing. Thanks for your help!Comment
I also had a 2001fp with the vertical line problem. Apparently, it's a problem that inherent to this model due to bad welds on the flat ribbon connectors on the LCD panel. Sell the inverter and logic board on Ebay to help offset the cost of another monitor.Comment
I was pretty close to giving up on this, when I stumbled across the heat gun -> pencil eraser "fix." I can see this being a temporary fix since the back of the LCD does get rather hot, and it will just do the same thing. Which made me wonder, why in the world would a manufacturer rely on a heat activated compound on something that gets as hot as these things do. I did some research, and found a couple of articles on what this compound is, and it is rather interesting. Looks like 3M is a major manufacturer of it. It goes by two names from what I've found so far. Z-Axis Conductive film as well as Anisotropic Conductive Film (ACF). Here is a couple of links I've ran across while doing the research.
3M's Product Page
http://solutions.3m.com/wps/portal/3...nductiveFilms/
Flipchips tutorial describing how the stuff works. It's actually rather interesting.
http://www.flipchips.com/tutorial05.htmlComment
I believe the adhesive used is called Anisotropic Conductive Media (ACP). It is made by 3M. It is a glue with tiny metal balls in it. It makes an electrical connection in the Z-axis when the ribbon is pressed on to the board but does not conduct between the connectors in the X and Y axis. I have a similar problem with a ribbon cable that became unglued to the LCD glass in a Sanyo DP42848 TV. I have spent many hours online trying to acquire some of the ACP. It comes in a big roll and it seems you have to be a big company and buy many hundreds or thousands of dollars worth of it. There are special machines that press the cable on to the circuit board while heating the adhesive. From what I have learned so far, it seems there is no way for a one man home repair operation to reattach one of these cables.
If anyone knows of a way to acquire ACP in small affordable quantities or of some other way to reattach a polyimide flat cable, I would like know about it.Last edited by CDGraves; 04-20-2013, 09:54 AM.Comment
by Tr0llHi guys! I realized you have a lot of knowledge here so i am hoping you could point me in right direction with my odd issue.
Original T-con:
First replacement T-con:
I thought it might be t-con and ordered new t-con from china(supposedly tested)... -
Anyone know if the ribbon cables are standard across laptops cases like in a PC, or are they proprietary to each manufacturer? I damaged the one that runs between the MB and the power / HDD / Battery Status Indicator LED Circuit Board. The Dell SKU/DPN: ADM70LED. I just need help finding a replacement. Could I possibly use a similar cable from a donor laptop?
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
Channel: BIOS Requests ONLY!
by NWArkGuyWell, I will be the first to admit that I screwed up...
In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
I have 2 that I have found and have in my possession. ... - Loading...
