FSP035-1PI01 (Viewsonic VX910) inverter transformers?
  • roothorick
    • Aug 2011
    • 5
    I've had a ViewSonic VX910 sitting in my livingroom for the longest time, and I just today took a serious crack at it. Symptom: Power light blinks green. Nothing appears on screen. Determined this to be the fault of the power board.
    After some playing around and testing components, I noticed burn marks around the solder points for the primary winding of T1. So I just desoldered that whole half of the transformer and pulled it out of the circuit. The unit now powers up! Unfortunately, the backlight dies a second in, but I can still see picture if I blast it with a flashlight, so logic is running. Okay, I need a new T1.
    Here's the question though -- can I actually buy these transformers anywhere, or will I have to buy a whole new board? I'd rather not troubleshoot a board I can't fix.
  • PlainBill
    • Feb 2009
    • 7034
    Re: FSP035-1PI01 (Viewsonic VX910) inverter transformers?
    I did a quick search for FSP035-1PI01. Guess what - I found them for sale - as a matter of fact, I found two different versions for sale. One of them uses our old friend, the Royer oscillator. On that one the driver transistors fail and cause the problem you describe. I have no idea what the other version uses, but both are most likely repairable.
    So if you want some help, take a couple of pictures of your power supply / inverter board and attach them to your next post. Use 'Manage attachments' (below the text entry area). I will want one of the top side of the board, one of the bottom side. And it really helps if they are sharp and will lit. Something over 1000 x 1000 pixels is good.
    PlainBill
    • roothorick
      • Aug 2011
      • 5
      So... you think the transformer is good? Since it powers up without T1 in circuit I assumed there was a shorted winding in T1, though I could see how a shorted Q6 and/or Q7 could cause the same issue, and I now see that removing T1 effectively took them out of the circuit too. The other backlight is most likely blown Q8 or Q9, but again, I don't want to further troubleshoot a unit I can't get needed parts for. I suppose the thing to do is lift T2 and swap it into T1's location, I'm pretty sure they're the same unit. Alternately, I could lift Q8/Q9 and move them to Q6/Q7. If it actually stays on but I still have backlight issues, the transformer is okay. If the switcher cuts, the transformer IS shot, and I'm back to square one...
      It's the same board as here. (But with a different, white glue! heh)
      • PlainBill
        • Feb 2009
        • 7034
        Have you ever read Dante's 'Inferno', either in the original Italian, or an English translation? Actually, 'Inferno' by Niven and Pournelle would be more appropriate.
        The cap sets the speed of the oscillator. The cap fails, the oscillator runs wild, and the transistors short. There is a zener diode in the circuit - make sure it is not shorted. The solution is simple - replace the transistors, the cap, and the diode if necessary.
        Yes, I am sure that will fix the problem. As for the parts - the Belinea 101910 monitor uses the same power supply. The schematic and parts list are in the service manual.
        PlainBill
        • roothorick
          • Aug 2011
          • 5
          You're talking about the three-legged diode that looks like a transistor, right? It's good. I actually messed up the screw that holds it down so I need to find a new screw :/ this is turning into a "fun" project.
          So I have a failed cap? Which one? I don't have an ESR meter... or should I just recap the whole thing?
          PlainBill
          I'll see if I can find that service manual.
          • alexanna
            • Mar 2010
            • 1346
            Q 6 through 9 are available. When these fail they usually fail shorted. The tab and the center pin are connected internally.
            These are the sot 23 small transistors on the back of the power supply, they are marked “DK”
            Pictures?
            • PlainBill
              • Feb 2009
              • 7034
              No, the three legged diodes are rectifier diodes. The zener diodes are in the inverter circuit. They probably have identifiers that start with ZD.
              PlainBill
              • lostone
                Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                by lostone
                Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                05-19-2024, 11:40 AM
              • x_orange90_x
                Vizio E55-E1 bad backlights or bad inverter?
                by x_orange90_x
                I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                I don't know how exactly to test the inverter itself. Is it...
                01-29-2025, 09:24 PM
              • Gentian
                APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                by Gentian
                I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                03-06-2023, 07:07 AM
              • valvashon
                Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                by valvashon
                For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                01-04-2024, 01:44 PM
              • Tips
                Inverter 316827000001-R0A transformers
                by Tips
                I have a failed inverter board, 316827000001-R0A from an Acer Aspire Z5700 AIO PC. (I know I am asking this question under TV's and video sources as I believe it is more relevant here than under PC's and I hope that is not an issue)
                The transformers have failed and I am struggling to identify them or find a suitable replacement for them. The only code printed on them is 273001050372 10252. (Please see attached pictures)
                Any advise or suitable compatible replacements would be most welcome, and thank you in advance....
                12-13-2020, 06:15 AM
