Dell E177FPv - No signs of Life
  • alexanna
    • Mar 2010
    • 1346
    Re: Dell E177FPv - No signs of Life
    If you have an ohmmeter a very simple quick test would be to see if its shorted.
    If you have another capacitor of the same values try changing it
    • jetadm123
      • 2169
      Diodes D12 and D13 (right above U6 and U7). Can you verify they feed the input of U6 and U7? Check to see if one of them is open or shorted.
      • jayoung
        • May 2011
        • 172
        C62 is a 22uf 25V capacitor. I have a spare 22uf 50V Panasonic FM series if you think that would be OK. The resistance between the positive and negative leads in circuit is 755 ohms.
        Voltage and Resistance on the diodes:
        D13 - 1.19 - 1.25 VDC TOP
        1.71 - 1.77 VDC BOTTOM
        39500 OHMS
        D12 - 5.17 VDC TOP
        10230 OHMS
        • alexanna
          • Mar 2010
          • 1346
          The voltage is way too low on the input of the left regulator, but I don't know why. At the moment I am out of ideas.
          The higher voltage cap would work if you decide to try it.
          • jsog
            • Feb 2011
            • 220
            That 1.71 - 1.77 V on both diodes looks odd. Is that with the black probe on a ground like the screw hole to the right of U6?
            • jetadm123
              • 2169
              #26
              Okay, here's what I'm thinking:
              U6 appears to be an adjustable regulator. Using your methodology, the top pin is the input voltage (5 volts). Middle pin is the output (3.3 V). Bottom pin is the adjustment pin (2.1 V). The bottom pin requires two resistors to set the output voltage. It looks like everything is working as you're getting the 3.3volt output. At the output of U6 should be a small cap.
              I'm assuming that the output of U6 feeds the input of U7, which in your case is reading appprox 1.2 V instead of 3.3 V. Now, if something's wrong with the small cap, then it's logical to assume the input to U7 will be affected.
              To determine if the output of U6 is connected to the input of U7, with power off and your meter set to resistance, place one probe on the middle pin of U6 and the other probe to the top pin of U7. If you get zero ohms, then you've verified they are connected. To find out which cap is connected to the output of U6, perform the same test as above, except place your probe on the various caps "+" lead to determine which cap will give you zero ohms. Try replacing this cap to see if it solves your problem.
              • alexanna
                • Mar 2010
                • 1346
                #27
                Well after some sleep and dreaming about your monitor!
                After you did the recap and assembled everything it worked for a while, Makes me wonder about a poor connection.
                With everything hooked up and power and a signal applied, try gently flexing the logic board in various places, I would pay close attention to areas around the voltage regulator with the low input voltage.
                For me a plastic chopstick works great, but anything that's well insulated would work, just gently poke around see if the voltage changes.
                • jayoung
                  • May 2011
                  • 172
                  #28
                  For me a plastic chopstick works great, but anything that’s well insulated would work, just gently poke around see if the voltage changes.
                  I got home from work today and hooked up the power and video board along with the front control board. I pushed on the video board around all areas with no change.
                  The voltage is way too low on the input of the left regulator, but I don’t know why. At the moment I am out of ideas.
                  I replaced C62 with the 22uf 50V Panasonic FM. I also reflowed the solder on the two diodes and the two voltage regulators.
                  All of the voltage readings were taken with the black probe on a screw hole.
                  After replacing the C62 capacitor and reflowing the two diodes and the two voltage regulators, I re-assembled the monitor without the lcd and the power LED came on when pressed. I finished assembling the monitor and the backlights came on, but no video. I re-seated the ribbon cable from the front control panel and everything seems to be working now. I am typing this message using the monitor and it has been up and running for about 45 minutes now. I will continue to use it for a bit to see if anything changes before snapping the front cover back on (it was a bear to get off in the first place).
                  A VERY big thank you to alexanna, jetadm123, and jsog for all their help. I'm not sure if it was the capacitor or a loose solder joint at one of the two diodes or two voltage regulators since I did not test the monitor between performing all of those fixes.
                  • Bowline
                    by Bowline
                    06-11-2025, 10:13 AM
                  • master3112
                    by master3112
                    07-29-2025, 01:55 PM
                  • someonenotyou
                    Dell Vostro 3501 - no signs of life after BIOS read
                    by someonenotyou
                    Hi.
                    I have a laptop Dell Vostro 3501 which did not POST. When connected to power supply and turn it on, the keyboard backlight would turn on but nothing else. Sometimes there was 1 BEEP code indicating problems with BIOS.
                    Then I disassembled it to read the BIOS chips. It had 2 - 64mbit and 128mbit. I connected CH341A (with 3.3v mod) to both of the chips (still soldered on main board) and read them.
                    After I reassembled laptop back and tried to turn it on. Now there is no sign of life. Not even keyboard backlight.
                    Then I took the motherboard out...
                    01-27-2025, 05:15 AM
                  • F R 2568
                    Dell Latitude 5420 does not start (no post) need help to find the reason why
                    by F R 2568
                    Hello all,
                    this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                    I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                    If the laptop is only connected to the AC adapter (battery removed):
                    When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                    The power/battery...
                    01-08-2025, 05:45 AM
                  • diamon
                    Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                    by diamon
                    I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                    Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                    Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                    Pictures of these boards:
                    Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                    Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                    Dell...
                    02-28-2024, 12:51 PM
