lp2407 aka fpd2485W No Power
  • UniT3d
    • May 2011
    • 43
    #41
    Re: lp2407 aka fpd2485W No Power
    Hmmm .....
    I'm making simple assumptions here. Assuming your unit is crossing over 5 years old or more, replacing all secondary capacitors now is highly recommended. Caps does not have to be swollen/domed to be borked.
    Those linear regulators can get borked by many reasons and one of it is out-of-specs capacitors on the secondary. Wouldn't want those newly regulators to get borked again in a few months ..... hmmm?
    Based on your regulator output lists above, I'd say chip 3 and chip 4 are way off the mark and needs replacements.
    • geep
      • 40
      Well one of these monitors lp2407 landed in my my hands. The symptoms include no back lighting no image with flashlight. It is powering on and off and staying on with the touch button when signal from PC is applied and does its little chime sound when turned on. I have replace all the caps with a kit of eBay all nichicon and Panasonic caps. I did the test explained in this thread and when testing power from the power supply to inverter board i am getting
      1-26.1
      2-26.1
      3-0
      4-0
      5-5.1
      6-0
      7-3.2
      8-0
      pin 7 dose not seem to be right any ideas
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        #43
        You also need to test the voltage regulators as mentioned earlier.
        A good guide on finding testing and posting results is here:
        https://www.badcaps.net/forum/showpo...29&postcount=1
        • geep
          • 40
          here are my voltage regulator outputs
          u601 Ld117a-133ATK
          1=0
          2=3.27
          3=5.20
          u602
          AIC 1084 33pm 67918
          1=0
          2=3.28
          3=5.20
          u603
          AZ117D 1.8E1 639n42
          1=0
          2=1.79
          3=3.28
          u604
          7CJL 17 18L
          1=0
          2=1.78
          3=3.26
          u605
          LD117a-133ATk
          1=0
          2=3.26
          3=5.19
