Compaq WF1907 Turns On Then Off After Few Seconds
  • Craigt4113
    • Jul 2011
    • 10
    I am new to the forums and a beginner to electronics repair. I have a Compaq WF1907 19" LCD Monitor I picked up already broken. I opened it up and saw no visibly bad caps. I have replaced a few caps already but to no avail. I have the rest on order and should be here in the next few days. I am starting to think though from what I have been reading that it isn't so much the caps but maybe a transistor, transformer or maybe a CCFL. I am here to get some opinions on the matter from you guys. The power supply is marked as follows:
    E59670
    PTB-1808
    6832180800P01
    I have add a 2 pics of the board for visual reference.
  • Craigt4113
    • Jul 2011
    • 10
    Re: Compaq WF1907 Turns On Then Off After Few Seconds
    Sorry forgot to mention in the main body of the post that when it turns on there is an image for abotu 2-3 seconds then black while the green indicator light remains on. I also noticed that the top CCFL seems to be a bit dim.
    Thank You,
    Craig T
    • PlainBill
      • Feb 2009
      • 7034
      The problem is called 'Two seconds to black'. The dim CCFL is an important clue. Inverters have protection circuitry which will shut down the inverter if the current through any CFL is too high, or if the voltage across any CCFL is too high (current too low).
      One common failure is a bad solder joint at the CCFL, another is an aged CCFL.
      Do you have any spare CCFLs available, or a 'test' monitor you can use for testing?
      Another possible cause is shorted turns in the inverter transformer. Compare the resistance between the two terminals at each end. They should match to within 3%.
      PlainBill
      • Craigt4113
        • Jul 2011
        • 10
        Thank you for the quick reply, I have already checked and re-soldered both transformers on the board before I posted this, so that can probably scratch that off the list. Now when you say check the resistance of the end terminals do you mean the ones I have marked in red in the below attached picture? There are a total of 8 terminals on that transformer the other terminals I have marked in blue.
        When you say a bad solder joint at the CCFL do you mean at the terminal on the board or where the wire meets the actual CCFL?
        I do have another 19" different brand monitor I can test this on, I just hook up the CCFL's of the other one to this power supply correct and see if the lights stay on?
        Thank You,
        CraigT
        • sabre504
          • May 2010
          • 449
          • United Kingdom
          Where you have marked the trans in red ,
          measure resistance between the top 2 pins then do the same on the bottom
          2 pins and compare readings .
          I would expect readings of 650 ohms and above and they should be within 3% of each other .
          • Craigt4113
            • Jul 2011
            • 10
            thank you sabre, I got 582 on the lower 2 in the pic and 581 on the top 2, so that doesn't see to be the problem
            • sabre504
              • May 2010
              • 449
              • United Kingdom
              Bit lower than expected but seems ok
              • PlainBill
                • Feb 2009
                • 7034
                Thank You,
                CraigT
                Good news on the transformer.
                The best approach at this point would be to hook the 'test' LCD panel to this power supply and see if the CCFLs stay on. If they do, that eliminates the inverter. After that, one at a time replace the test CCFLs with a CCFL from this panel. If you get 'two seconds to black' only when one of the top CCFLs from this panel is connected, you have identified the problem - it's either the wiring to the CCFL or the CCFL itself.
                There are two leads going to each CCFL - Drive (the wire with thicker insulation) and return. Common problems include arcing through a hole in the insulation of the drive lead, arcing through the end support at the drive end of the CCFL, a failed solder joint at either end of the CCFL, and a frayed wire at either end.
                PlainBill
                • Craigt4113
                  • Jul 2011
                  • 10
                  Thank you, I will give this a shot today and let you know what I find out.
                  • Craigt4113
                    • Jul 2011
                    • 10
                    Ok so here is what I have found out so far, In the lower CCFL unit there is 1 dead unit and the top CCFL package both units are a pinkish color. I was unable to test the CCFL's in another rig cause I forgot I had shipped that one out already. So if one bulb is completely dead would that effect the rest? Any ideas where to go from here?
                    • PlainBill
                      • Feb 2009
                      • 7034
                      A total relamp may be required.
                      The protection circuits are detecting the open (dead) CCFL and shutting down the inverter. The pinkish color indicates the CCFLs are near their end of life.
                      PlainBill
                      • Craigt4113
                        • Jul 2011
                        • 10
                        Thanks bill, I forgot I had a another LCD in the spare bedroom and I cracked that one open. I hooked up the CCFL's and same thing pink on 2 dead 1 and ok 1. So you are right I would have to do a total re-lamp and since I can not find these lamps I am going to part out the power supply and video board and e-bay it =). Thank you all who helped me on this I appreciate it very much and have learned alot.
                        • wesson
                          • Feb 2012
                          Same problem ,. same monitor where is the CFL , i have my monitor taken apart and about to check the spots in red with my multimeter
                          • jayoung
                            • May 2011
                            • 172
                            The spots in red are for testing the transformer secondaries.
                            The ccfl's are in the lcd panel, you have to take it apart to actually inspect / remove them.
                            • wesson
                              • Feb 2012
                              ok thank you very much
                              • eleazar_1812
                                • Aug 2012
                                • Mexico
                                Hi I have a problem with an identical monitor is the same plate. My problem is that when connected directly to the power LED lights up and stays flashing, but not turn on or off. What could be the cause?
                                • Ober
                                  • Aug 2012
                                  • 67
                                  I dont know anything about this problem, but if you hadnt already seen it, theres a Sticky about this subject at the top of this forum (Troubleshooting Computer Display section)
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    Hi - Does you screen flash on at all - if not you are not really on the 2 seconds to black problem referred to by ober. There is still a lot of useful stuff in there, but you need to do other tests first.
                                    We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
                                    Examples of what is needed
                                    https://www.badcaps.net/forum/attach...1&d=1290283049
                                    https://www.badcaps.net/forum/attach...7&d=1280167246
                                    It will be useful if you can say a bit about yourself - skills tools etc.
                                    Do you have a Multimeter and soldering equipment
                                    • Napalm2002
                                      • Dec 2013
                                      • 3
                                      • Usa
                                      Where can I find the replacement ccfl's? Are they cheap enough to buy and fix this monitor?
                                        • 31009
                                        http://stores.ebay.com/lcd-led-parts
                                        • twonk9098
                                          Lenovo Legion 5 high fan spin turns off after 34 seconds
                                          by twonk9098
                                          I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                                          I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                                          I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                                          I have tried a few new bios but exactly...
                                          07-14-2024, 11:19 AM
                                          HP Compaq Compaq SG3-240ES Compaq SG3 220 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Compaq SG3-240ES can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-240ES boardview and Compaq Compaq SG3-240ES schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-12-2024, 03:44 PM
                                          HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
                                          HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower Compaq Pro 6005 B59 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower boardview and Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                                          09-12-2024, 03:36 PM
                                          HP Compaq Compaq dc7900 Compaq Q9400 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Compaq dc7900 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq dc7900 boardview and Compaq Compaq dc7900 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-12-2024, 03:30 PM
